Old 02-20-2013, 02:48 PM   #1
indr OP
Oddometer: 1,197
Best way to clean air box (fine silt and sand)
I have it off the bike, opened up and fully disassembled. There is fine silt and sand in between the nooks and little squaring on the walls of the box.
I've tried hot water and dish soap (didn't work). I've tried WD-40 (works but very slowly).
I'm going to try Pine-Sol next but would like other ideas, too.
indr is offline   Reply With Quote
Old 02-20-2013, 03:31 PM   #2
Vankaye
n00b on the move
Oddometer: 223
pressure washer?
If that's not possible I would submerse it in soapy water and go at it with a small brush. Maybe use a heatgun to put and 90* angle on a toothbrush.
Vankaye is offline   Reply With Quote
Old 02-20-2013, 04:52 PM   #3
ibafran
villagidiot
Oddometer: 1,287
Run it thru the dishwasher. If that doesn't do it, take it to the magic wand car wash. Truck needs a wash anyway, right? Silt might be sticking because the plastic has some sort of static charge. Find an anti-static pad and touch it to that? That's all that I can think of?
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 02-20-2013, 05:47 PM   #4
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,235
Air filter cleaner. Test it first before spraying the whole thing down to make it doesn't melt it. Then a bath with Dawn dish detergent and it should be good to go.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 02-20-2013, 11:28 PM   #5
black_labb
Oddometer: 44
May be a bit odd of a suggestion, but sodium percarbonate (nappysan/ diaper cleaner) works quite well to remove just about anything without any mechanical rubbing. It is most active in hot water. just soak it in hot water/sodium percarbonate, it's pretty impressive stuff.
black_labb is offline   Reply With Quote
Old 02-21-2013, 07:30 AM   #6
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
Anchor it to a sizeable rock, and drop it in a local stream for 24 hours.
Old 02-21-2013, 08:04 AM   #7
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,340
dishwasher
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 02-21-2013, 10:32 PM   #8
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,562
Dishwasher, or Simple Green and an old toothbrush.
Flashmo is offline   Reply With Quote
Old 02-21-2013, 11:45 PM   #9
indr OP
Oddometer: 1,197
No dishwasher access. Will take it to nearby magic wand car wash.
Old 02-25-2013, 12:31 PM   #10
JensEskildsen
Oddometer: 1,012
Use kerosene it "dissolves" the glue-like dirt. After that use a brush, and finish of with hot water and/or pressure washer.
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 02-25-2013, 04:29 PM   #11
el queso
toda su base
el queso's Avatar
Oddometer: 685
I use Carb cleaner and a bristle brush.
el queso is offline   Reply With Quote
Times are GMT -7.   It's 06:09 AM.
