Old 02-22-2013, 05:02 AM   #7396
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,147
Originally Posted by Gros Buck View Post
Yep, but pray your hose (or clamps) will never fail, 'cause the day it fails so close to the exhaust: KABOOM !!!
Paul Jr
Have you ever noticed the original hose route or where it clamps to the injector? Only inches from the filter. ;)
Sent from outer space with my Thunderbolt with Tapatalk.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike is offline   Reply With Quote
Old 02-22-2013, 05:57 AM   #7397
migrator
migrator's Avatar
Oddometer: 209
winner winner, chicken dinner... Thanks!!
The little bracket on the kickstand got pushed down.
Originally Posted by BK.RD.RNR View Post
It may not be the switch at all. When mine did the same thing, I just adjusted the position of the magnet on the kickstand, and tightened it back up. I was careful not to overtighten the screw as I did not want to risk breaking the mounting point (if that is possible or likely). I did not have another problem with this issue after the adjustment.
The other thing I did when it happened while out riding was to put the kickstand up/down a few times and try again. that usually did the trick.
Easiest to figure out where placement of the magnet should be while the bike is on a stand with the sidestand up.
Hope this helps.
IBA - 34422
migrator is offline   Reply With Quote
Old 02-22-2013, 09:11 AM   #7398
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Originally Posted by Hoots View Post
since buying the 690 (and spending a lot more on it than I would the TE630), I have come to realise that this bike is not in fact likely to be a more solid and reliable package than the 630 ...
Sell it and buy something more reliable before it loses too much value...
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio is offline   Reply With Quote
Old 02-22-2013, 09:28 AM   #7399
Baja Dad
Baja Dad's Avatar
Oddometer: 2,034
NOT !!!!!!!!!!!!!!!!!!!!!!!
2nd best bike I have every owned!!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-22-2013, 11:51 AM   #7400
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,810
Sweet! I got one right!
BK.RD.RNR is online now   Reply With Quote
Old 02-22-2013, 12:12 PM   #7401
Kirkster
Parts Murderer
Oddometer: 296
Originally Posted by Seth S View Post
Did both the front bulb and rear bulb stop working or just 1?
They both seem to be out... I will be pulling the bulb this weekend...
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 02-22-2013, 12:25 PM   #7402
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
Originally Posted by RideWithMe View Post
I've been having a look through the standard service schedule from the 2013 690 Enduro and find it odd that cleaning or replacing the fuel filters aren't listed as a standard service item at either, 1000k, 10,000k, or 20,000k. It does mention doing a fuel pressure check so I imagine they are expecting you would pick up any issues from the pressure reading, but I think I'll go with a regular replacement of the screen and filter maybe 5,000k or at least 10,000k.
Why would you replace the screen, it's a cleanable part, just like the oil screens. Pull it off, hit it with some compressed air and slap it back on.
Old 02-22-2013, 12:57 PM   #7403
Baja Dad
Baja Dad's Avatar
Oddometer: 2,034
Originally Posted by hoots View Post
tks noyah - this is being worked through under warranty, and i believe that a sensor replacement is next on the list in what is essentuially a 'therapeutic trial' ...
dude, just un plug it !!!!!!!!!!!!!!!!!!!!!!!
Old 02-22-2013, 01:35 PM   #7404
Hoots
Hoots's Avatar
Oddometer: 1,589
Originally Posted by Baja Dad View Post
Dude, just un plug it !!!!!!!!!!!!!!!!!!!!!!!
Dude – yes I could just unplug the sensor – and then do what? – look at it? – sing to it perhaps? – maybe fondle it a bit? – I don’t have a replacement sensor to swap it with, and as the bike is under warranty it would be senseless to buy one and go through the process myself – only to have KTM repeat it all at some later date if this turned out not to be the problem ...
So I think I’ll stick with plan A, and just let the KTM boys swap the sensor and see if that fixes the problem - sounds simple to me ...
Hoots is offline   Reply With Quote
Old 02-22-2013, 01:35 PM   #7405
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,959
Fair enough, but there's still a filter there next down the line inside the tank and filters get dirty and block, and contaminated.
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee screwed with this post 02-22-2013 at 01:59 PM
BygDaddee is offline   Reply With Quote
Old 02-22-2013, 01:46 PM   #7406
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,128
I think what BD is try to say is none of the other models of 690 enduros have a oil pressure sensor so why bother with one now , It's obvious that it is stressing you out , it is not needed and it is some thing else that can go wrong , in your case has gone wrong ,
A lot of us here use the KISS method Which KTM has not , it is an Enduro bike after all.
Mudguts is offline   Reply With Quote
Old 02-22-2013, 01:57 PM   #7407
Hoots
Hoots's Avatar
Oddometer: 1,589
Conversely, if the oil sensor is not in fact the problem and I remove it and the oil pressure is not maintained and ... etc etc etc ... for $16K bike under warranty this is not going to be a good course of action ...
Down the track perhaps ...
Agree re' KISS principle - might be good to somehow transfer that message back to the engineers in Austria ...
Old 02-22-2013, 01:59 PM   #7408
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
First enough, but there's still a filter there next down the line inside the tank and filters get dirty and block, and contaminated.
I replace my filter every time I replace the pump. Hmmm, maybe that's what they had in mind all along.
Old 02-22-2013, 04:51 PM   #7409
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,209
Planned obsolesce - us auto builds started in the 70's, going global.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 02-23-2013, 02:08 AM   #7410
Evil Invader
Evil Invader's Avatar
Oddometer: 697
Now if only Crankshaft would get his wiring harness out together with some nice ecu setups that eliminate all safetygadgets like clutchgrip preassure switch, sidestand switch and what not...
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Times are GMT -7.   It's 12:10 PM.
