02-22-2013, 01:35 PM
#7441 |
Oddometer: 412
Dude yes I could just unplug the sensor and then do what? look at it? sing to it perhaps? maybe fondle it a bit? I dont have a replacement sensor to swap it with, and as the bike is under warranty it would be senseless to buy one and go through the process myself only to have KTM repeat it all at some later date if this turned out not to be the problem ... So I think Ill stick with plan A, and just let the KTM boys swap the sensor and see if that fixes the problem - sounds simple to me ... |
#7442 |
Ex: RideWithMe
Oddometer: 503
Fair enough, but there's still a filter there next down the line inside the tank and filters get dirty and block, and contaminated.
― George Carlin - Never argue with an idiot. They will only bring you down to their level and then beat you with experience. 2013 KTM 690 Enduro R ![]() Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY BygDaddee screwed with this post 02-22-2013 at 01:59 PM |
02-22-2013, 01:46 PM
#7443 | |
when in doubt GAS IT
Oddometer: 1,662
I think what BD is try to say is none of the other models of 690 enduros have a oil pressure sensor so why bother with one now , It's obvious that it is stressing you out , it is not needed and it is some thing else that can go wrong , in your case has gone wrong , A lot of us here use the KISS method Which KTM has not , it is an Enduro bike after all. |
02-22-2013, 01:57 PM
#7444 | |
Oddometer: 412
Down the track perhaps ... Agree re' KISS principle - might be good to somehow transfer that message back to the engineers in Austria ...
02-22-2013, 01:59 PM
#7445 | |
Kool Aid poisoner
Oddometer: 4,850
Hmmm, maybe that's what they had in mind all along.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
02-22-2013, 04:51 PM
#7446 | |
on the mend
Oddometer: 977
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding. All posted pics < 6/30/12 deleted courtesy of Apple
02-22-2013, 05:02 PM
#7447 |
Ex: RideWithMe
Oddometer: 503
Hahah, hopefully I'll get through a few filters before that happens.
― George Carlin - Never argue with an idiot. They will only bring you down to their level and then beat you with experience. 2013 KTM 690 Enduro R ![]() Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY |
02-23-2013, 02:08 AM
#7448 |
Oddometer: 594
Now if only Crankshaft would get his wiring harness out together with some nice ecu setups that eliminate all safetygadgets like clutchgrip preassure switch, sidestand switch and what not...
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813 ![]() M Motoadventures
02-23-2013, 05:21 AM
#7449 |
Cranky Old Fart
Oddometer: 2,330
My fork mods worked great! Nice and plush.
![]() Still working with the rear shock. I got the PDS spring to fit. However, not happy with the action. Ends up with too much preload. That defeats the goal. I may just have to pay for the rear to be revalved. Holy crap that shock almost doesn't need a spring. On the bench I could barely get it to stroke. ![]() On a related not- Those with Safari Tanks. Have you ever considered or found a second valve to put on between the tank and the Safari valve by the reservoir? Stretching that poor hose when raising the subframe to access the shock is brutal. I've used hemostats to pinch the line. That's hard on the line. I was thinking of a small ball valve near the base of the tank. Hmm, Maybe reuse the disconnect I removed from the injector line. I got my wide pegs all made up. I'm still milking out a 30+ year old can of Malcolm Smith Silver Husky Frame paint. I've never found a replacement for it yet.
Tom 2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC To Think is to Create!http://my2wheels.com/forum/cmps_index.php |
02-23-2013, 07:09 AM
#7450 |
Seeker
Oddometer: 2
tank bolts
Does anyone have a lead on where to buy tank bolts for the 690. KTM twin and rally raid are back ordered until April
02-23-2013, 07:28 AM
#7451 | |
Cranky Old Fart
Oddometer: 2,330
FWIW Twins did get them in stock a week sooner than the Backorder date that was listed.
02-23-2013, 07:53 AM
#7452 |
bush league
Oddometer: 39
any quick fix for movement in tank? bolts are and have always been checked tight. Need to fix before sandblast rally.
It appears the play is in the bottom bolts assy. I bought rally raid top bolts but didn't use because stock ones fit better. Thanks! |
02-23-2013, 07:56 AM
#7453 |
Torque Stick
Oddometer: 3,868
I believe it was PartsMaker? here on adv had a good solution to the easily worn lower tank bushings. Maybe check the Vendors section. I am very happy with mine.
02-23-2013, 08:58 AM
#7454 | |
Guns are for pussies
Oddometer: 13,783
My 690 is already running far better than it ever did, so my project is a success. It's going to get it's trial by fire at the Sandblast rally in South Carolina a week from today!
Just say'IN |
02-23-2013, 01:16 PM
#7455 | |
Oddometer: 594
![]() Really glad for you!
