Old 02-22-2013, 03:00 PM   #1
craydds OP
craydds's Avatar
Oddometer: 1,157
Project 1976 Yamaha YZ400
I just bought a '76 YZ400! I know, it's a sickness. It seems to be all original and unmolested, except for the gas tank. (pics to come later). Seems rare to find an old dirt bike (or any old motorcycle) that has not been tampered with, or TRASHED. The gas tank has been painted flat black - possibly to hide some bondo repaired dents? We shall see. The rear shock has NO damping, none, it is gone. I'll do a shock rebuild search, see if anyone does rebuilds, or possibly can tell me how it's done. Yeehaw, another project!
edit: Is there a YZ400 thread? I did not do a search.
ABC #12947
'75 R90S
craydds screwed with this post 02-22-2013 at 03:02 PM Reason: thread?
craydds is offline   Reply With Quote
Old 02-23-2013, 05:18 AM   #2
craydds OP
craydds's Avatar
Oddometer: 1,157
YZ thread!
Let's start a Yamaha YZ thread to include ALL the YZ's. I now have two, a 1980 YZ50 and my brand new old '76 YZ400. Remember, they were the FIRST with the MONOSHOCK. That was so cool! Elsinores were nice, Suzooks were good (I had a 125 and a 250), but the YZ's had that monoshock.
ABC #12947
'75 R90S
craydds screwed with this post 02-23-2013 at 05:19 AM Reason: ,
Old 02-23-2013, 07:11 PM   #3
heliyardsale
Always looking for Dirt!
heliyardsale's Avatar
Oddometer: 413
Ha! I bought the same bike last week! Here is mine stuffed in my car! I also have a 76' YZ100C and the YZ125X.
Bad photo of the clan!
An Alaskan bush pilot once told me "every great adventure begins with piss-poor planning"
Heli (Doc Mike)
heliyardsale screwed with this post 02-23-2013 at 07:17 PM
heliyardsale is offline   Reply With Quote
Old 02-23-2013, 07:14 PM   #4
heliyardsale
Oddometer: 413
Here is my YZ125X
Heli (Doc Mike)
Old 02-24-2013, 08:27 AM   #5
craydds OP
craydds's Avatar
Oddometer: 1,157
Originally Posted by heliyardsale View Post
Here is my YZ125X
Wow! That 125 is NICE. I like that gas tank for the 400 shown in the post above. I saw one on ebay but I was unsure about it. I got a Clymer's manual with my YZ400, it SUCKS - conflicting info, etc; I bought an "official" YZ400 service manual from ebay - a gamble, but shall see if it is any better. I see that Racetech can rebuild shocks, may give them a call: http://www.racetech.com/page/id/64 . Got the bike home yesterday and it FIRED on the second kick. Started doing some cleaning up, going to lube everything, etc. I need a rear fender... ebay again? The project begins. (I will get some pics today.)
ABC #12947
'75 R90S
Old 02-24-2013, 08:50 AM   #6
craydds OP
craydds's Avatar
Oddometer: 1,157
YZ400 manual
Bought this manual on ebay - http://www.ebay.com/itm/260908536395...S:3160&vxp=mtr.
Dirt, ugly, but it's ALIVE:
ABC #12947
'75 R90S
Old 02-24-2013, 08:58 AM   #7
craydds OP
craydds's Avatar
Oddometer: 1,157
Will get some things cleaned up, lubed, and adjusted today. Take it for an easy test ride in the desert. A 400 cc 2-stroke! Bet it will have AWESOME power.
ABC #12947
'75 R90S
Old 02-24-2013, 12:27 PM   #8
heliyardsale
Oddometer: 413
Lolls pretty good! Don't lose the silencer, they cost huge $$$ to replace.
Heli (Doc Mike)
Old 02-25-2013, 03:54 AM   #9
craydds OP
craydds's Avatar
Oddometer: 1,157
Need Monoshock Help
Rear wheel off. Axle, dirty but in good condition otherwise:
Rear wheel is good:
Everything covered in many years of dirt. Rear monoshock bolt ready to come out:
Swingarm loose. Look at that "inner fender", it's a piece of rubber floor mat:
Another view of the rear "inner fender". Anyone have a source for the correct part? ebay? :
The front monoshock bolt needs to be removed:
That nut is too TIGHT. I cannot get it to budge. Any tips on how to loosen it?
ABC #12947
'75 R90S
craydds screwed with this post 02-25-2013 at 04:47 AM Reason: spell
Old 02-25-2013, 07:29 AM   #10
crg infidel
Oddometer: 37
First and foremost, Sweet Bike!!! That is gonna be a ton of fun!
It might be helpful to get some heat on that nut, but not so much you burn up your rubber. You could try a wet rag around the rubber bits, and a little propane torch to warm up that nut. (please be ready to put out fires; I'd hate to hear a horror story )
I grew up with old ring-ding Yamahas, and they are great bang for the buck!
Good luck!
crg infidel is offline   Reply With Quote
Old 02-25-2013, 11:16 AM   #11
craydds OP
craydds's Avatar
Oddometer: 1,157
Good luck!
I will try and work it loose this evening. Get out my torch... and fire extinguisher. Ha!
ABC #12947
'75 R90S
Old 02-25-2013, 12:01 PM   #12
dooder
Oddometer: 28
I can't tell from the pic... It's not reverse threads is it?
Cool bike!
dooder is offline   Reply With Quote
Old 02-25-2013, 12:27 PM   #13
craydds OP
craydds's Avatar
Oddometer: 1,157
Cool bike!
I thought about that. I looked closely, but I'm blind in one eye... can't see out of the other. I could try to thread a nut onto the exposed threads to verify right vs. left hand threads. I will double-check that this evening.
edit: I zoomed in close on the photo in iPhoto, threads look like right-hand. It is hard to tell, will check tonight.
ABC #12947
'75 R90S
craydds screwed with this post 02-25-2013 at 12:38 PM Reason: photo
Old 02-25-2013, 07:11 PM   #14
adventuro
Oddometer: 16
If nothing else works you could try a nut splitter, better than screwing up threads on the shock...btw I still have my 78 yz400 that I bought new.
adventuro is offline   Reply With Quote
Old 02-26-2013, 12:41 PM   #15
craydds OP
craydds's Avatar
Oddometer: 1,157
shock progress
I was ready to buy a nut splitter! But, I used penetrating oil and my torch - slightly scorched the rubber - and got the shock OFF:
It was really HARD to get that nut to bust loose and I did mess up the threads a bit. Nothing that a die can't fix:
Will clean up the shock and send it off to Racetech - http://www.racetech.com/page/id/64.
Next step - I want to take the swingarm off. Same thing again - the swingarm bolt will NOT come out:
ABC #12947
'75 R90S
Times are GMT -7.   It's 09:51 PM.
