Old 02-23-2013, 11:46 AM   #16
Pete-NZ
Pete-NZ's Avatar
Oddometer: 784
Originally Posted by Nano0k View Post
The standard front wheel bearing on a XR650 is a 6003 - 2RS . 35mm OD 17mm I.D . i tried to look on Mcmaster and SKF for a needle . sound like there is no bearing suited for my job. so im thinking about 3 option :
1. re-machining the wheel hub for a bigger bearing option
2. disassemble the bearing/sleeve unit and make a larger straight shaft mounted on custom bearing block fixed on the arm
3. remake a double sided swing arm whit stock Honda wheel axle
the wheel on my car had 6203 berrings 17mm OD... I replaced them with 3/4" (19.05mm) berrings that
had the same OD.. The wheel is of a Suzuki FXR 150 rear..
It maybe possable for you to do the same....
but theres a lot to be said for a double sided arm...
Heres my arm..
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is online now   Reply With Quote
Old 02-23-2013, 12:03 PM   #17
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 492
Thumb
For a first project you've really got it going on.
Nice fabrication.
Lots of swivel joints and clamps that eventually will need to be pinned, and your bike frame points could (should) be stronger.
I'd like to see some of Claudes bolt on outer swing arm designs.
It will roll the axle under if you corner too hard on the lefthanders.
Great build so far!
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 02-23-2013, 12:35 PM   #18
Pete-NZ
Pete-NZ's Avatar
Oddometer: 784
Originally Posted by D.Bachtel;20793049
It will roll the axle [I
under[/I] if you corner too hard on the lefthanders.
Great build so far!
Don in Nipomo
diddn't like to crittersize..but that was my thought also...
with the axle mounted above the arm..any side load will
beable to apply a twisting force to the arm and/or bend the
mounting bracket inwards...
but other than that its a VERY well made car with good attention to detail...
Old 02-23-2013, 01:15 PM   #19
Nano0k OP
Oddometer: 7
Critique mainly build solution. i mean im a 27 years old machinist teamed whit 25 years old millwright / welder . we young but trying to get all expertise people can teach us and take the good part of it. all about learning, understanding and get better.
i don't know about Claudes bolt design but he seen to be a mentor for lot of builders here. share a link :)
Nano0k is offline   Reply With Quote
Old 02-23-2013, 03:36 PM   #20
claude
Sidecar Jockey
Oddometer: 3,990
Note that the swingarm pictured does not go with the rest of the pictures. There would be a different axle and material added for the bolt on outdie half. Hope you get the overall idea though. This assembly was on a KLR 650 Outfit we built.
Claude
http://freedomsidecars.com/
Old 02-23-2013, 05:15 PM   #21
XL-erate
Oddometer: 154
Hi nano0k,
There's some very nice work there, nice fabrication! I will offer a bit of critique regarding swingarm.
In your first and second pics on Pg 1 here, that swingarm is a very long tube; I believe too long. You'll be dealing with twisting forces along the whole length of that tube, caused by the leverage action of wheel's diameter twisting tube rotationally along its length from side thrust when cornering in either direction. That is, the wheel from top to bottom of its diameter acts like a long lever to twist the single swingarm tube along its length from cornering forces. Hard right hand turn would make the tube want to twist wheel top toward body; hard left would want to twist wheel under sidecar body [think I got that right].
Check out 70's Chrysler Corp. 'Torsion Bar Suspension' and you'll see that the twisting forces in a similar tube/shaft are even used to replace the entire front suspension and springs in a full sized vehicle!
The longer the tube or shaft is the more it will have torsional twist. A shorter torsion tube has a lower twist rate, and a thicker-walled tube or a solid shaft has less twist along its length. Your 3/16"-.1875" wall tube isn't especially stout for resisting the twisting forces in this application of a single-sided swingarm tube withstanding the entire cornering force in a sidecar.
In addition you have the leverage factor side to side [front to rear along its length] acting on that long single swingarm tube, making it want to bend near the forward mounting point and/or along its length due to cornering forces. Again, with leverage as with torsional twist, shorter is definitely better to control unwanted motion. Gussets and triangulation can help somewhat where possible and again a thicker-walled tube is obviously less prone to bending.
See the single-sided swingarm in upper-right pics that Claude posted: it has a rectangular/square profile and much heavier dimensions overall, plus it's very much shorter. All of that will help resist torsional twist, and in his example, all but eliminate it. If it was 1/4" - 0.25" walled square/rectangle stock it would be even better, and solid stock is a possibility too. Increasing diameter or external dimensions also helps with torsional rigidity and resistance to twist or bend. The square profile would also help resist the bending load front to rear, as compared to round tube.
Not saying yours won't work but I'd sure keep an eye on it during some rigorous testing and be sure and subject it to some maximum cornering forces with chair heavily loaded with ballast before trusting it on a long ride with passenger and kit. Have fun!
XL-erate is offline   Reply With Quote
Old 02-23-2013, 05:35 PM   #22
XL-erate
Oddometer: 154
And by the way, a side comment regarding this guy Claude. In my book he's top of the heap stuff!
Not long ago I chatted with him about a simple mechanical idea, could have been fully covered in 15 minutes chit-chat. He knew from the beginning there was no chance to make even one thin dime profit in his business from our conversation. Add to that, I was a total stranger to him, and it wasn't that good an idea in the first place.
We hung up the phones 5 hours later!
Mighty fine guy no doubt, and trustworthy.
Times are GMT -7.   It's 11:23 PM.
