02-01-2013, 01:55 PM
#271 |
Oddometer: 240
I recently bought a Xmoto with a Staintune exhaust, which is annoyingly loud. But I also got the stock exhaust, and have been thinking about reinstalling it. The last few posts would quickly convince me, except that I don't know what I'm doing...
Forgive my total ignorance, but is this a simple bolt on procedure? Is there any remapping necessary, etc? |
02-01-2013, 01:56 PM
#272 |
Lost but laughing.
Oddometer: 4,578
Just a simple bolt on only.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
02-01-2013, 02:39 PM
#273 | |
Oddometer: 857
So many roads...........So little time..!!! 2005 BMW R1150GS Adv - Black 2005 BMW R1150GS Adv - Silver 1998 Honda XR250R |
02-01-2013, 03:53 PM
#274 |
Oddometer: 240
Thanks guys, think ill give it a try
02-03-2013, 02:40 AM
#275 |
"Moto Porn"ographer
Oddometer: 3,808
Email Stephan for the current prices mate
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
02-04-2013, 09:15 AM
#276 |
Can I change this?
Oddometer: 266
To replace the stock exhaust to the stock header, you will need an exhaust gasket. All else is simple, although you need to remove the Remus bracket to get the stock bolt back in (at least I did).
I put 2 db reducers in the Remus and still prefer the sound of the stock, but this time I reinstalled the stock can and left the Remus header. Header is slightly shorter and doesn't fit fully into cut outs in stock muffler. I have used a shorten exhaust gasket, clamped and sealed the potential leak points, but will probably need a better solution this summer. To tell which header you have, the stock header shrinks in size from block to muffler inlet and the Remus grows in size. My current record is 112 MPH on dash which is about 105 true (stock muffler and stock header). In addition to the better designed Remus header, I am doing a PC V, so I may be able to eek out an additional 1 MPH Going up on the front 1t helped me not hit rev limiter in 6th.
There is no such thing as bad weather, only inadequate clothing. |
02-04-2013, 09:18 AM
#277 |
Can I change this?
Oddometer: 266
Also, most Staintunes have DB reducers - if yours is missing. My dyno tune on a Staintune on an SV650 showed better power with the insert installed.
02-05-2013, 05:29 PM
#278 | |
Oddometer: 240
Thanks for this info. But I'm a dummy, assumed the "S" was Staintune but its definitely Scorpion. So, if I have the stock header, which I assume mine is cause it says BMW on it, I don't need a gasket, just bolt the old muffler (pipe) on? Thanks for your patience :) |
02-05-2013, 05:55 PM
#279 |
Can I change this?
Oddometer: 266
stock header to stock exhaust pipe DOES take a gasket between the two.
02-05-2013, 06:43 PM
#280 |
Oddometer: 240
02-14-2013, 05:52 PM
#281 |
Oddometer: 240
Got this gasket in today, intending to reinstall the factory exhaust system. It's bent and looks beat up.
I hate to send it back and wait 2 more weeks. Do you think it's usable or not? ![]() ![]()
02-14-2013, 07:10 PM
#282 | |
n00b sums it up.
Oddometer: 227
![]() (if it's not the one for the end of the can to the header pipe then disregard my comment...) |
02-14-2013, 07:35 PM
#283 |
Dusty and Thirsty
Oddometer: 1,303
yep, that is the gasket that goes between the head pipe and the silencer, I would use it.
Rob Swartzwelder, Southern AZ I'm not real fast, but I do have a dog named Dakar! 97 M900, 07 G650 XChallenge,11 KTM 990 ADV R 2011 North up the CDR Sierra Vista AZ to Paonia CO and Back through Moab UT |
02-15-2013, 12:40 AM
#284 |
Oddometer: 857
I'd send it back, it's farked
02-24-2013, 11:31 AM
#285 |
Oddometer: 142
SR-Racing Exhaust
Does anyone know if there is a SR-Racing dealer in North America. I just bought a X-challenge that came equipped with the Remus pipe that I find too loud and am looking for a quiter solution, I am in Canada.
