Old 02-22-2013, 08:58 PM   #91
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 761
Originally Posted by FinnDuro View Post
The common issue I've heard from my 690 riding buddies is the harsh choppy feel of the standard 690E/R front end. Wears down your wrists, they say, and I would agree from the test rides I took.
Anyway, a couple of those guys swear on this DIY compression stack revalve:
- remove the compression valve from the forks
- measure the OEM comp stack shims, mark down the order, diameters and thickness of each shim
- the magic: change all 0.15mm thick shims into 0.10mm thick shims, keeping otherwise same diameters and order
- re-assemble and enjoy the plush ride
I have a 2012 690 Enduro (250mm travel)and have had the front forks partly re-valved. I weight 78kg in my birthday suit. Haven't ridden it yet, will do tomorrow and let you know my findings. I had told the suspension guy that it was too harsh on the trail, ruts, bumps, stutters/corrugations. Worked well if you were leaping off jumps but then there was still a bit of harshness about it. So, just the 24mm diameter shims changed this time, suspension guys recommendation, different thickness and qty.
Shim setup:
Was-----------Now
24 - 0.15 -----24 - 0.10 x 2
16 - 0.10 -----16 - 0.10
24 - 0.15 x 2--24 - 0.10 x 2
20 - 0.15 -----20 - 0.15
18 - 0.15 -----18 -0.15
16 - 0.15 -----16 -0.15
14 - 0.15 -----14 -0.15
9.5 - 0.30-----9.5 - 0.30
Update:
Took the bike for a ride and now the front forks go up and down when riding over corrugations/stutters. Woohoo!! Finally suspension that works. I can start to hold a line going around gravel roads that are corrugated. It's not perfect or "superplush" but it's a start in the right direction.
So will stay with this setup for a month or so till I decide what else needs doing.
I do need to ask the suspension guy i used why he replaced the first 24mm 0.15 shim with 2 x 24mm 0.10 shims.
All I can say is if you do not have a 690 suspension guru near by, just get your KTM bike shop to start replacing the 0.15 shims with 0.10 shims.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond screwed with this post 02-23-2013 at 03:45 PM
Dotbond is online now   Reply With Quote
Old 02-23-2013, 10:25 PM   #92
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
how much float are you running in the mid valve?
did you do anything to the rebound stack?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 02-24-2013, 09:18 PM   #93
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 761
No idea on the float sorry. What ever is standard i assume. But I will ask him tomorrow.
Didn't touch the rebound stack. Do you have any thoughts on the rebound?
I will be seeing the suspension guy in about a months time so he can check the bike out and advise me what to do even further.
2012 KTM 690 R
Old 02-25-2013, 07:41 PM   #94
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Well i guess the only thing to do is tear into mine and start from scratch and baseline measure everything, plug it into restacker app and go from there
Sent from ADVmachines.com via Tapatalk
Old 08-06-2013, 11:23 AM   #95
funsummer
funsummer's Avatar
Oddometer: 102
Any further news on this shim adjustment and what oil weight/ height you blokes running?
funsummer is offline   Reply With Quote
Old 08-26-2013, 06:42 PM   #96
coarsegoldkid
coarsegoldkid's Avatar
Oddometer: 599
I have a '13 690 End R. Where do you source the 0.15 shims?
coarsegoldkid is offline   Reply With Quote
Old 09-18-2013, 03:38 AM   #97
daveburton
Oddometer: 179
Lowering 690
Hi,
I have a 690 with 40mm Koubalink and about 30mm through the clamps. I need to drop it a further 25mm. How would I do that with the suspension. Spacers,shims, progressive springs.
I'd appreciate any advice chaps,
cheers dave
daveburton is offline   Reply With Quote
Old 10-20-2013, 10:20 AM   #98
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 893
bumping this one.
I can ride my bike with no handlebars, no handlebars, no handlebars - Jamie Laurie
The Letter J is online now   Reply With Quote
Old 10-21-2013, 12:18 PM   #99
coarsegoldkid
Oddometer: 599
Originally Posted by daveburton View Post
Hi,
I've done the same as you. I wouldn't do any more than that. You will lose too much ground clearance. The risk of banging the rear link or the rear brake master is much greater. I'm thinking of changing out the 1 5/8 Kouba for a 1 incher. It will be slightly taller but when I load up the saddlebags and such I'll likely be back to where it is now.
However I do believe that if you call around to suspension specalists you'll find someone that can shorten the rear shock shaft and find a shorter spring. Maybe even the front can be done the same too.
'05 BMW R1200RT
'13 KTM 690 Enduro R
Ride tales
Utah / Colorado http://tinyurl.com/lcy2yhu
Mexico http://tinyurl.com/lhgznun
coarsegoldkid screwed with this post 10-21-2013 at 12:27 PM
Old 10-21-2013, 12:28 PM   #100
coarsegoldkid
Oddometer: 599
What I would also like is get more compliance in the high speed compression of the front forks. Where does one source the shims? Part numbers?
'05 BMW R1200RT
Ride tales
coarsegoldkid screwed with this post 11-06-2013 at 09:46 PM
Old 11-10-2013, 09:35 PM   #101
coarsegoldkid
Oddometer: 599
Adjusting Sag on the 690 Enduro R
The owners manual for the 690 Enduro R has instructions for adjusting the sag for the shock. I laughed to myself when the instructions say to remove the seat and side cover and remove shock. I think they forgot to mention a few other items to access the shock. No instruction for adjusting the sag for the forks. Seems odd. Any thoughts on this?
'05 BMW R1200RT
Ride tales
Old 11-11-2013, 03:39 AM   #102
ktmmitch
Oddometer: 578
Fork Sag
On a standard 690 you have to remove the fork caps and either add or remove the plastic preload packers.
Or you can fit the KTM Hard Parts preload adjustable fork caps for EXC
ktmmitch is offline   Reply With Quote
Old 11-11-2013, 07:14 AM   #103
Hipster
Hipster's Avatar
Oddometer: 1,775
I've been buying my shims from here http://www.racingsuspensionproducts.com/shim/shim.html
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 11-11-2013, 12:45 PM   #104
coarsegoldkid
Oddometer: 599
Thanks ktmmitch however those preload adjustable fork caps are no longer available as far as I can tell. I'll adjust with the spacers.
'05 BMW R1200RT
Ride tales
Old 11-11-2013, 12:46 PM   #105
coarsegoldkid
Oddometer: 599
Thanks Hipster
'05 BMW R1200RT
Ride tales
Times are GMT -7.   It's 11:32 PM.
