Old 02-26-2013, 04:22 AM   #7456
Christophe
weekend warrior
Christophe's Avatar
Oddometer: 82
Originally Posted by MeinMotorrad View Post
Exactly the same as my 2012. I was going to try to prise them out but didn't bother in the end. I've got that rust too. I just greased the hell out of everything and put it back together. I'll check every time I change tyres and again near the end of the warranty period. If it's not good then KTM can fix it
There's hardly any grease on the front wheel either.
I guess they changed something with the 2012 model... with my 2011 the spacers usually fall off on their own while changing the tire.
Christophe is offline   Reply With Quote
Old 02-26-2013, 05:58 AM   #7457
lightfighter
where does this go?
Oddometer: 2,299
BD squadron 3 going on...
http://advrider.com/forums/showthread.php?t=866131
lightfighter is offline   Reply With Quote
Old 02-26-2013, 12:33 PM   #7458
Honkey Cat
Tailights Fade!
Oddometer: 1,152
Originally Posted by lightfighter View Post
How much brighter is that headlight?
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 02-26-2013, 01:05 PM   #7459
Baja Dad
Baja Dad's Avatar
Oddometer: 2,040
1000 times !!!!!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-26-2013, 02:16 PM   #7460
lightfighter
where does this go?
Oddometer: 2,299
Yeah, it's pretty bright. Appearantly it's bright enuf to anger people on the east coast all the way from AZ.
I didn't take any yet, but I was gonna fire up the stock light off an accessory lead and take comparison shots just cuz i geek out like that.
Old 02-26-2013, 02:27 PM   #7461
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,794
Originally Posted by PatSmith View Post
I just bought a used 2012 690 with 800 miles. I know that the forks will have a break in period that will reduce the stiction. I do not want to start changing things until the forks are broken it. About how many road miles will the forks and shock need before they are broken it?
You need to put about 50,000 miles on the stock forks before the internals are damaged enough to have a nice smooth ride.
Seth S
Seth S is offline   Reply With Quote
Old 02-26-2013, 02:33 PM   #7462
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,878
That's funny. I was loosely considering putting my 08's forks on the 2012 because I finally got the clickers tuned in a way that I like... after 30k miles.
BK.RD.RNR is offline   Reply With Quote
Old 02-26-2013, 02:42 PM   #7463
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,193
You guys are brutal!
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger"
My2Wheels
dad2bike is offline   Reply With Quote
Old 02-26-2013, 03:16 PM   #7464
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
You're kidding ... Or you're not playing hard enough maybe ??? At 50000 miles, my forks will be enterely destroyed.
Let say there's a big difference after 2500 miles off road. Then it smooths gradually. Retrofit every 10000 miles. Seals every 5000 miles, or every seasons. Match with the annual seals change.
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 02-26-2013 at 07:35 PM
Gros Buck is offline   Reply With Quote
Old 02-26-2013, 03:28 PM   #7465
SKINNY
SKINNY's Avatar
Oddometer: 667
My 2012 forks were much less harsh from brand new than my 2008 was after several thousand miles...
The 2008 & 2012 have the shorter travel, but the 2012 has different compression damper adjustments and internals....
at any rate, it's better than the 2008 ever was...
SKINNY is offline   Reply With Quote
Old 02-26-2013, 07:48 PM   #7466
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 449
I'm going to try to do a warranty claim in a few weeks. I'll post up what happens.....
In other news....
Nice review of the 690 I found here:
http://www.enduro360.com/2012/11/10/...duro-r-review/
thorinoakenshield is offline   Reply With Quote
Old 02-27-2013, 09:26 AM   #7467
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 869
Originally Posted by dad2bike View Post
My son TJ rode Ginger & I rode Big Orange over to Vibranator before lunch.
WOW! I can't say enough good about Don over a Virbanator/Ricor.:Pom
We did a bunch of experimenting before & after lunch at his place.
Finished results:
Big Orange now has a set of the regular Vibranators. Took my bars vibes to near nothing. Man I wish I had done this long ago.
Ginger started with the regular units. I rode her around the parking lot and still noticed considerable vibes.
After lunch we went back and changed up to the heavier units. Takes a huge Tap to do the end of the bars. I probably should have cut off some of the bar ends. They now stick out an inch. More clearance for the levers I guess. :p
I'm gonna say the heavy ends reduced my vibes about 70% on the 690.
Couldn't tell if you posted it somewhere, could you tell me which model Vibranators you ended up putting in the 690?
sdd04 is offline   Reply With Quote
Old 02-27-2013, 09:45 AM   #7468
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,193
Since we did all the install at his shop, no packaging or paperwork that I can reference for you. Hmmm. I don't see them on the Site. These are the newest coming out of them. I'm thinking we were helping on the R&D. Don & I tapped the bar ends to fit them. I chose NOT to cut off my bars. That puts them out an additional inch from the ends. I did have to do some bending on my Cycra guards to get them to fit correctly. The ones I have are about 6oz each and thread into the bar ends. We did to go to longer end bolts than would have been supplied. That was more for my wishes than his. I did the standard inside the bar units on the 950 & my sons EXC.
My2Wheels
Old 02-27-2013, 11:57 AM   #7469
sdd04
Oddometer: 869
Thanks for the info. Guess what I'll do is call them when I'm ready to order and talk to them about it.
If you had it to do over, would you cut the bars down?
Old 02-27-2013, 12:01 PM   #7470
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,193
Nope. I usually add a 1/2 inch spacer anyway.
Sent from outer space with my Thunderbolt with Tapatalk.
My2Wheels
Times are GMT -7.   It's 02:06 AM.
