Old 02-25-2013, 06:27 PM   #3151
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,375
Originally Posted by duffs View Post
Those also look remarkably similar to the new BMW units for the 2013 F800GS (presumably same as R1200GS units)... any idea who manufactures them?
Hella makes them, 14W. OEM for BMW 63 17 7721320 and now it seems for KTM.
They are more Fog lights than anything else, the only thing I like is the lens which makes them on-road compatible I suppose.
tallguy-09 is offline   Reply With Quote
Old 02-26-2013, 07:29 AM   #3152
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
Model 30 on Sale
Model 30 light on Sale 25% off
Normally $60.00 each now $45.00
Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair) of Lights.
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Length: 70mm , Diameter 55mm
  • black durable coating
  • o-ring sealed housing
  • one meter wire lead
  • includes flat mount (stainless) mounting bracket
  • glass shatter resistant lens
  • Sold individually
Old 02-26-2013, 07:47 AM   #3153
scooterGdawg
Oddometer: 512
any pics of any of these lights mounted on a burgman 650?
http://myscootlife.blogspot.com
scooterGdawg is offline   Reply With Quote
Old 02-26-2013, 08:41 AM   #3154
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
Not sure it's a 650
Old 02-26-2013, 08:53 AM   #3155
scooterGdawg
Oddometer: 512
nah, thats a 400......
I'll have to look at the 650 closer, and see how i can mount them...
was hoping someone had already figured it out for me..
thanks
Old 02-26-2013, 10:56 AM   #3156
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
thanks
Are looking to be seen or primarily to see?
The bolt holding the front fender (in front of the fork) is an easy spot to mount lights.
Thats a big scoot.
Old 02-26-2013, 11:30 AM   #3157
scooterGdawg
Oddometer: 512
mostly to be seen..... that is a recessed bolt tho..
Old 02-26-2013, 11:41 AM   #3158
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
Yes it is.
Remove said bolt.
Measure the depth of hole from edge of hole to bottom. Or just get a toothpick and mark the depth onit
Go to the local hardware store and find a bushing that the bolt fits into but the outside is smalller than the fender hole. Choose the bushing length that is longer than the recessed fender hole is deep.
The base of the light mount will use the bushing as a mounting surface.
Lowe's has a great selection of nylon bushings in all kinds of interesting sizes.
Old 02-26-2013, 02:37 PM   #3159
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 695
Originally Posted by sanjoh View Post
Yes it is.
Remove said bolt.
Ace Hardware has some really nice chrome bushings, pricey, but you only need 2, they also have nylon. Be sure to pick up a couple of longer metric bolts while you're there, Ace has stainless bolts with socket cap or button heads.
Bob Weis
04 K12RS - Hannigan Hack
You rarely see a motorcycle parked outside a psychiatrist's office.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-26-2013, 04:06 PM   #3160
beechum1
beechum1's Avatar
Oddometer: 4,818
Send a message via AIM to beechum1 Send a message via MSN to beechum1 Send a message via Yahoo to beechum1
Or a shoulder bolt from McMaster....
www.bajastarz.com \\\ 94 XR650L, 85 GL1200A
Rally Moto Kit /// Vendor Thread
Old 02-26-2013, 09:15 PM   #3161
RTinNC
RT to GS in NC
RTinNC's Avatar
Oddometer: 898
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Sold individually
OK .... this put me over the edge and I ordered! At $45 with "inmate" discount I could resist no longer. Hope to mount them up similar to the suggestion on that Burgman using Caliper bolt with a bushing and longer bolt on my GSA. Also opted for the amber or yellow lens guards only because I believe the amber lights are more noticable in the daytime.
Hope they are as good as everyone says!! Thanks!!
Ed Apelian
Ride Safe & Enjoy the Ride
2006 R1200RT - Silver/Gray
2002 R1150GS- Sold Replaced with 2012 R1200GSA Magma Red!
RTinNC is offline   Reply With Quote
Old 02-27-2013, 03:46 AM   #3162
JayD
JayD's Avatar
Oddometer: 386
Model 30 light on Sale 25% off[/URL][/COLOR][/SIZE][/B]
[/SIZE]
Sanjoh,
I went to your site to order a set of 30s but didn't see the box to enter the discount code to reduce the price from
45.00 down to 40.00 each for inmates
Did I not go far enough thru the process?
JayD is offline   Reply With Quote
Old 02-27-2013, 03:51 AM   #3163
RTinNC
RT to GS in NC
RTinNC's Avatar
Oddometer: 898
Originally Posted by JayD View Post
[/B]
Sanjoh,
Exactly ... the coupon code box in about step #3 in check out. You will see it and it worked fine for me. Just follow the check out steps on the site. Simple to use site too.
Ed Apelian
Old 02-27-2013, 04:58 AM   #3164
scooterGdawg
Oddometer: 512
awesome....just the answer i was looking for.......
Old 02-27-2013, 09:21 AM   #3165
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
Does anyone know the width of the mount between the ears/tabs of the light?
Times are GMT -7.   It's 04:45 PM.
