02-26-2013, 06:34 PM
#16021 |
Oddometer: 1,876
got a pic? the disc shouldn't move at all. the float comes from the calipers. if this really is a problem i just want to know whats up...
Ride 365 LLC Braaaap! |
02-26-2013, 09:13 PM
#16022 | |
Oddometer: 31
The Disc does float, ever so slightly. Grab yours and give it a tug forwards or backwards. It will move a bit. The rivets allow it to move to as it heats up. Definitely not the calipers. |
02-27-2013, 02:32 AM
#16023 | |
Tigers R great.
2002 Tiger955i in black, 69000 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, KTM600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
02-27-2013, 02:45 AM
#16024 | |
Tigers R great.
I think you're being too fussy.
02-27-2013, 02:48 AM
#16025 | |
Oddometer: 31
02-27-2013, 05:19 AM
#16026 | |
Oddometer: 1,876
02-27-2013, 06:54 AM
#16027 |
Oddometer: 2,482
Some floating discs have a spring-washer contained within the buttons and some don't. Just because the disc moves or rattles doesn't make it worn out. You guys are starting to sound like a bunch of Harley riders.
'09 Triumph Tiger1050 '96 Ducati 900SS '02 Suzuki SV650S (hers) |
02-27-2013, 07:04 AM
#16028 | |
I'd rather be riding
Oddometer: 2,612
cam chain tensioner noise at cold starts
So let me ask this question differently: If you have this noise at start up (and eventually it graduates to being there all the time) and you do nothing about it, is this going to create any damage to the engine? If so, isn't this something that Triumph should take care under warranty? |
02-27-2013, 07:24 AM
#16029 | |
Oddometer: 2,482
If left uncorrected, it will damage the engine. It can be as minor as casing damage, from the chain whacking the inside, which generates metal fragments. Or, it can be as serious as total tensioner failure, which would allow the cam timing to skip and bend valves and possible other engine damage.
02-27-2013, 07:59 AM
#16030 | |
armchair asshole
Oddometer: 2,691
02-27-2013, 10:03 AM
#16031 | ||
Oddometer: 2,612
02-27-2013, 03:50 PM
#16032 | |
Oddometer: 31
I work with and design aircraft components. If a rivet or bolt gets slop it has zero fatigue life. i.e. If you stick a 6mm bolt in an 8mm hole it can carry zero load. Simples. I apologise for being too fussy. I have a syndrome called self preservation. I've noticed Hardly-Worthit drivers don't have this basic human instinct. |
02-27-2013, 04:00 PM
#16033 | |
Oddometer: 2,482
Your bolt example is dead-on. However, I can't tell you how many iron, Brembo race rotors I've heard rattle, to include new, out-of-the-box examples. Brake Tech iron rotors do the same. They float freely, without spring washers. IDK, I'm not an engineer. But, I'd think the engineers, who specialize in these components, have a pretty good idea what they're doing. In fact, before floating rotors became mainstream, they didn't have spring washers. When nearly every sportbike started coming with them, people started complaining about the rattling.
02-28-2013, 12:33 AM
#16034 |
Tigers R great.
The 100GS was like it when I bought it. It only had 11250 miles on the clock.
02-28-2013, 12:39 AM
#16035 | |
Tigers R great.
Now if you replace bolt with bobbin...............
