Old 02-23-2013, 08:10 PM   #5251
Poweranger
Oddometer: 760
[QUOTE=DerrickWade;20790179]I have since replaced the flexi hose, with 4" conduit.
Originally Posted by Tech23 View Post
Thanks, Details on the insulation are:
I cut the pieces to fit inside each panel of the garage door. I then went around the edge of each panel with aluminum tape.
Name: Reflectix Insulation
Bought it at Menards
Thickness: Not sure, 1/4 inch maybe. Its just shiney bubble wrap.
Stays put? Yes, I have it taped to the framework with aluminum tape.
Check out post #12 of my single car garage revamp on garage journal.
http://garagejournal.com/forum/showthread.php?t=155324
Sweet garage! I used that same insulation from Menards under my garage floor for a vapor barrier. Laid it out, taped the seams with aluminum tape, and poured the concrete on top of it.
Poweranger is offline   Reply With Quote
Old 02-25-2013, 03:52 PM   #5252
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,642
Did the same with my garage doors but just used the WHITE foam. I glued it to the doors with Liquid Nails. Makes the garage so much brighter and really keeps the garage insulated.
Man Castle link:
http://advrider.com/forums/showpost....&postcount=530
2006 - Triumph Tiger
1995 XR650L
atokad screwed with this post 02-26-2013 at 09:18 AM
atokad is offline   Reply With Quote
Old 02-26-2013, 08:39 AM   #5253
DerrickWade
Oddometer: 10
[QUOTE=Poweranger;20796093]
Thanks, Its pretty neat stuff. Easy to work with as well and has a million and one uses.
[QUOTE=atokad;20809388]
Did the same with my garage doors but just used the why foam. I glued it to the doors with Liquid Nails. Makes the garage so much brighter and really keeps the garage insulated.
Man Castle link:
Love the Gladiator cabinets and slatboards!
DerrickWade is offline   Reply With Quote
Old 02-26-2013, 09:32 PM   #5254
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,642
Some day I hope to have a cool floor. Thought it would be epoxy, but not sure yet with all the great "tile" options. The Gladiator cabinets are great. Found the wall cabinet on CL, cheap, but they hardly come up at all anymore. Lowes used to carry the brand (maybe they still do ) and they will deal on the prices some if you are buying several pieces and ask for a deal.
1995 XR650L
Old 02-26-2013, 10:25 PM   #5255
Poweranger
Oddometer: 760
I thought about doing the fancy floor in the shop side of my barn. Was really liking the epoxy. But after getting spilled oil, grease, beer, ect on the concrete I changed my mind. Sticking with concrete. Keep a good sealer on it and the spills clean up easy.
Old 02-27-2013, 06:36 AM   #5256
ducnut
Oddometer: 3,316
You can use acid etch (2 times) and a pressure washer (steam cleaner is best) to get up the oils. I'd recommend an oil-based concrete stain, instead of epoxy. Epoxy only adheres to the surface (think: topcoat), but, the stain soaks into and bonds to the concrete (even over oil stains). Unfortunately, Sherwin Williams has discontinued what we used to use, as they continue to drop oil-based products. I need to look at some other brands, for a replacement.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-27-2013, 08:21 AM   #5257
Poweranger
Oddometer: 760
Actually I should of worded that different. What I meant was I do not want to do anything with the floor so I won't worry about spilling stuff on it or dropping something heavy causing damage. I really like the look of those garages but I still want mine to feel like a shop. I wonder what weld spatter would do to those tile floors or epoxy?
I like your idea of just staining the concrete. It would look nice but still have that I can get it dirty shop feel to it. Since it is still just concrete.
I keep a can of carb cleaner around to clean up small grease or oil spills.
Old 02-27-2013, 09:41 AM   #5258
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,412
http://www.southernstainandseal.com/...y=17&keywords=
Atomic Top Coat. I used this product on my floor and it has been great. You can also add a stain color to it if you like. Browse their site for many other types of sealer.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is online now   Reply With Quote
Old 02-27-2013, 10:54 AM   #5259
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,286
1 gallon for $225!
You just gave a dozen KLR owners heart attacks!
HapHazard is offline   Reply With Quote
Old 02-27-2013, 11:26 AM   #5260
Poweranger
Oddometer: 760
Originally Posted by HapHazard View Post
1 gallon for $225!
Ouch! I'll stick with my bare concrete. And I thought the industrial sealer was expensive at 90 bucks for 5 gallons!
Old 02-27-2013, 11:32 AM   #5261
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,450
I just used a basic water based concrete paint in my garage, knowing from the start that it was going to get some abuse. Some of it has been lifted by hot tyres, & there are chips, bits of overspray & weld burn on it now, but it's still much nicer than bare concrete & cheap enough not to worry about damaging.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 02-27-2013, 11:35 AM   #5262
richarddacat
abnormal character
Oddometer: 3,412
You get what you pay for. In my case this was a new floor and I only wanted to seal it once.
Mid-TN Tag Riders
Old 02-27-2013, 12:15 PM   #5263
ducnut
Oddometer: 3,316
+1
Good product isn't cheap and certainly isn't a box-store offering.
'96 Ducati 900SS
Old 02-27-2013, 12:31 PM   #5264
Poweranger
Oddometer: 760
+1
I am not sure what the stuff is I used. They delivered it right on the concrete truck when we poured the floor. Judging by the smell when I applied it the sealer is oil based. I think I have a empty bucket of it I will see.
Old 02-27-2013, 04:30 PM   #5265
atokad
wan⋅der⋅lust
atokad's Avatar
Oddometer: 2,642
They do a ton of concrete staining around here in Colorado. That might be a good solution. I see lots of it in various applications around the state. Guess it gives that rustic, granite kind of appearance to go along with all of the other rocks we have here. BIG ASS ROCKS. In fact, we pretty much have rocks every where you look. Like this: I call this "Nature's Stadium Seating".
1995 XR650L
atokad screwed with this post 02-27-2013 at 04:35 PM
Times are GMT -7.   It's 05:54 PM.
