Old 02-27-2013, 05:46 PM   #3451
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,812
Originally Posted by dwayne View Post
You use a thinner section when using steel, looks can be deceiving. Aluminum's strength to weight ratio is better than steel, but it strength to thickness ratio is shockingly poor compared to steel. You would also change the feel of the rear suspension, steel has more flex...I imagine there would be both good and bad things that come from a more rigid swingarm.
Again the KTM 950/990 would be a decent comparison for weight and use to a Dakar.
I suspect you wouldn't break most swingarms from modern bikes, but I can only imagine the headaches of trying to modify one (remember the bmw chain is on the "wrong" side). Take a look at which parts get modded (or not) on a tourtech rally bike as a baseline the for value of a high performance mod. I believe they use the stock swing arm.
pretty sure some of the husqvarna 2 strokes also have the chain on the wrong side. just an idea.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 02-27-2013, 06:05 PM   #3452
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
What is the story with the dust cover? If I'm using YZ250F and using the YZ bearings to & bottom right? So do I use the BMW dust cover or YZ?
Posted mobile on Tapatalk
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 02-27-2013, 06:15 PM   #3453
WayneC1
Oddometer: 2,513
If you are referring to the steering head bearings, look to the Koyo bearings with inbuilt seal, one is
Koyo Part No 320/28JRRS (Replacement for stock BMW bearing)
F800 and other model owners have moved to them for longer SHB life, I would still use the metal dust cover as well
WayneC1 is offline   Reply With Quote
Old 02-27-2013, 06:40 PM   #3454
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
The bearings on the steering stem. Thanks for the link. Planning to get a replacement set of bearings for the YZ.
What I'm really asking are what dust covers are used?
Old 02-27-2013, 06:47 PM   #3455
tomatoe333
tomatoe333's Avatar
Oddometer: 2,296
I used a KTM dust cover on the top side. Same part number used on pretty much every KTM since 2000. Works nicely.
Bottom just gets the seal included in the bearing kit.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 02-28-2013, 09:34 AM   #3456
isgila
isgila's Avatar
Oddometer: 109
Raising links
Good day, this topic have been discuss before few pages back, yes i read the whole thread..
I believe Herrhelmet and Rcmad made 12 sets of links to raise the rear to match the yz front. And yes I do agree that this is not the best way to go but sending the forks to HoH or getting a customise hyperpro not for someone who lives outside of USA. I was reading the orange crush forum and got to know that emigracing.com does customise links for ktms. If anybody would be so kind to share the CAD drawings with me, i will check out the cost to run a couple of sets..
Thank you.
isgila is offline   Reply With Quote
Old 03-04-2013, 06:51 AM   #3457
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Does anyone have measurements for the ignition key lock mount? I remember seeing a drawing around here but can't find it now.
Thanks,
Old 03-04-2013, 07:04 AM   #3458
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,943
Thanks,
Scroll about 2/3 of the way down in this document.
GSBS is offline   Reply With Quote
Old 03-05-2013, 04:53 AM   #3459
swamp
swamp's Avatar
Oddometer: 1,812
Question center stand work with 18" rear wheel?
quick question.
will the center stand work with the 18" rear wheel?
::edit::
never mind
Enduro Earth
YOUTUBE
swamp screwed with this post 03-05-2013 at 04:56 AM Reason: found proof
Old 03-05-2013, 01:07 PM   #3460
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Anyone have measurements for the Dakar center stand and side stand? I may need to extend-a-weld a GS stand to make it dakar'd
Old 03-05-2013, 05:33 PM   #3461
swamp
swamp's Avatar
Oddometer: 1,812
Question how tight?
anyone know how tight this nut is supposed to be?
i read on thumper talk that the steering stem nut is supposed to be 105ft lbs. not sure if that is correct.
Enduro Earth
YOUTUBE
Old 03-05-2013, 05:35 PM   #3462
WERA456
WERA456's Avatar
Location: North Ga. (The site of the first major gold rush)
Oddometer: 209
I just did the front fork swap. I have a few details I need to figure out still.
I am running the yz wheel and caliper. So my abs does not work any more. Can I still get the rear abs to work? If not what all can I rip out having to do with the abs?
How did you route your brake line. Can someone post some pics. I currently am still using the stock headlight and fairings.
WERA456 is offline   Reply With Quote
Old 03-05-2013, 10:23 PM   #3463
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,994
I'd understand ABS just at the front, but just at the rear I don't see the point
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 03-05-2013, 10:49 PM   #3464
WayneC1
Oddometer: 2,513
ABS does a wheel speed comparison between front and rear wheel so running it on one wheel only would be interesting to say the least, sure would find any firmware bugs fast, can we be there to take pic's ?
GSBS has confirmed the ABS removal process I put in the back of the notes I made as the thread progressed so look at that as a starting point
http://www.f650gs.crossroadz.com.au/...orkNotesYZ.pdf I would update the notes if anyone posted more info
Re the nut referred to by swamp, it is the SHB tension adjustment nut, bit like the nut behind the wheel, would not react well to 100 odd foot pounds of force
Old 03-06-2013, 04:39 AM   #3465
swamp
swamp's Avatar
Oddometer: 1,812
i hand tightened the nut pictured above, then i torqued the top nut that is under the handle bars.
does this sound ok sufficient ?
Enduro Earth
YOUTUBE
Times are GMT -7.   It's 12:46 AM.
