Old 02-27-2013, 07:57 AM   #14131
wundis
Oddometer: 78
Oh, thanks, it seems my perception of long German words isn't as good as I imagined it would be.
Originally Posted by mait View Post
Here you are:
http://www.dr-big-shop.de/BIG_MotorReparatur_821.html
I ordered one a couple of months ago
wundis is offline   Reply With Quote
Old 02-27-2013, 03:26 PM   #14132
aapo
aapo
aapo's Avatar
Oddometer: 155
Huh, Just editing some 40 G of videos for wedding present for my firend. (yes no piston yet, so have some extra time) hope i'll finis in time...
But if you have time and want to see some lapland views go to youtube and just type "Uraa" in sreach. (no my staf there yet)
Sorry, not so many DRs there anymore these days... but still some fun videos. Especially if not very dry summer
http://www.youtube.com/watch?v=6Hy--REj8AA
http://www.youtube.com/watch?v=l3VekS0TEEc
-aapo
-aapo
DR 750S 1989
http://picasaweb.google.com/aapo.saari
aapo is offline   Reply With Quote
Old 02-28-2013, 12:32 AM   #14133
mait
mait's Avatar
Oddometer: 320
Very beautiful playground there, Aapo. Should come to visit the place some time.
PM sent, too.
mait is online now   Reply With Quote
Old 02-28-2013, 04:52 AM   #14134
robmoto
robmoto's Avatar
Oddometer: 3,848
Great vids Aapo and good rideing
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 02-28-2013, 10:07 AM   #14135
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by robmoto View Post
Just a little tip for you , only use suzuki valve stem seals, the after market ones go hard in no time.
Which brand(s) of aftermarket stem seals have you tried?
Regards,
Derek
motolab is online now   Reply With Quote
Old 02-28-2013, 10:07 AM   #14136
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by aapo View Post
I've used only suzuki valve stem seals and orginal mikuni parts in carbs, learned that hard way...
Regards,
Derek
Old 02-28-2013, 10:16 AM   #14137
motolab
motolab's Avatar
Oddometer: 2,584
I hope these guys are still in business: http://www.ignitech.cz/english/aindex.htm
They are. In fact, I sell enough ignitech igniter boxes that I designed and stock these brackets: http://www.moto-lab.com/gallery/view?itemid=384, http://www.moto-lab.com/gallery/view?itemid=387 & http://www.moto-lab.com/gallery/view?itemid=385.
Regards,
Derek
Old 02-28-2013, 11:50 AM   #14138
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,975
So is the DR750 coil both the POWER and the TRIGGER for the ignition system.
I don't understand how you eliminate one coil without losing the trigger also.
Derek, I have GOT to make time to come see your shop. It's funny, you kinda sit there in the background while I think that everything I need has to come from europe and then you just wave and say "I can do that"
Ladder106 is offline   Reply With Quote
Old 02-28-2013, 12:13 PM   #14139
motolab
motolab's Avatar
Oddometer: 2,584
The trigger is separate from the coil that normally powers the CDI.
Regards,
Derek
Old 02-28-2013, 12:20 PM   #14140
Ladder106
Ladder106's Avatar
Oddometer: 4,975
OH....OK so the CDI power coil will look the same as all the other coils on the stator.
The ignition trigger is obviously different. I thought the ign. trigger did both functions.
Old 02-28-2013, 01:10 PM   #14141
aapo
aapo
aapo's Avatar
Oddometer: 155
HI,
In 750s the power coil is in stator and the trigger is the black plastic one with smal "cylinder" in the magneto cover. DR 750 stator is available only from suzuki (some 500), but DR 800 you can cheaper.
But with ignitec you can go with the
http://www.electrexworld.co.uk/cgi-b...html%23aG7#aG7
"I heard" one guy in finland was about istal this stator on turbo dr 750. (there was a picture in thi thread some 2 years ago).
anyway, you can keep the trigger, and use the place of ignition power coil to have some more power for hated grips, lights etc.
But I haven't done it, so it's jus theory.
Br: aapo
-aapo
DR 750S 1989
Old 02-28-2013, 01:15 PM   #14142
motolab
motolab's Avatar
Oddometer: 2,584
...and use the place of ignition power coil to have some more power for hated grips, lights etc.
What did grips ever do to you?
Regards,
Derek
Old 02-28-2013, 01:20 PM   #14143
motolab
motolab's Avatar
Oddometer: 2,584
If you're switching to a battery powered ignition, you can then also go to TCI ignition instead of CDI (you'd have to install coils with higher primary resistance to go along with the TCI).
Regards,
Derek
Old 02-28-2013, 01:26 PM   #14144
aapo
aapo
aapo's Avatar
Oddometer: 155
Regards,
Derek
I'm sure they jumped in to the mysterious fuel system of CV mikunis and caused lean mixture and cylinder damage. Now i need some electricity to keep them in control and not to dominate my dr.
Br: aapo
-aapo
DR 750S 1989
Old 02-28-2013, 06:59 PM   #14145
Ladder106
Ladder106's Avatar
Oddometer: 4,975
Airbox Adapter
Being well sick of the silly air filter system in both the SR41/42 and SR43. I went in search of something to allow me to fit a large cylindrical foam filter inside the box.
I actually came up with something I think will work.
Photos are from the SR43 airbox but I think the 41/42 is similar enough at the front so there will not be a problem.
I'm certain I'll be able to find some sort of filter to fit into the box and clamp to the adapter. The small end of the adapter can be had in 1 1/2 in. (as in photos) 2 in. and 3 in. openings. The 3 in. end fits very nicely into the inside of the airbox. It will have to be sealed with RTV and maybe a small round headed screw and nut top and bottom for insurance.
I'll adjust the inside size to fit whatever filter I can source but will ovbiously try for the largest opening inside the box that I can find.
Opinions???
Ladder106 screwed with this post 02-28-2013 at 07:13 PM
Times are GMT -7.   It's 12:39 PM.
