Old 03-01-2013, 11:51 AM   #16216
sintax
Oddometer: 495
I was wondering if any of you guys have had issues with your throttle cables getting pinched on your Scotts steering stabilizer? I use the oil filler mount style. I may have to play around with routing, but the cables are kinda short for too much rerouting.
I also run a TM40 carb, and use the cables that come with that carb setup, i think they are already +2 or something.
sintax is offline   Reply With Quote
Old 03-01-2013, 12:23 PM   #16217
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,292
I had trouble with mine when I bought it last year, the throttle cables came up thru a rubber divider thingy that attaches to the Scotts mount and contacts the tank - there's an opening in between for the cables. But I had a lot of trouble with the throttle being "snatchy" from idle to the first 10% of throttle movement, made it hard to roll on the power from idle. I moved the cables to the left (out of the opening) and covered them with clear vinyl tubing to protect them from the Scott's. That helped a lot, then I bought a G2 throttle tube and it is much smoother. There is still a pull, but I can't help but think part of that is vacuum on the venturi / slide.
I have an aftermarket tank, although I don't know the brand. I'll do a pic this weekend.
PineyMountainRacing is offline   Reply With Quote
Old 03-01-2013, 12:31 PM   #16218
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 475
I can't help you as i dont use stabilizer , but i am sure someone else will .
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 03-01-2013, 12:42 PM   #16219
sintax
Oddometer: 495
thanks,
I'll poke around with it this weekend and see what i can come up with.
Old 03-01-2013, 01:27 PM   #16220
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,362
i think scotts sell them ... plastic thing that holds cables away from the arm and closer to the tank to stop the binding .... if you find 1 can you let me know i want 1 also
Sean-0 is online now   Reply With Quote
Old 03-01-2013, 02:41 PM   #16221
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,270
Scotts and Cleanspeed engineering sell cable routing goodies
http://cleanspeedeng.com/cable_guide.htm
Sent from my MB855 using Tapatalk 2
2013 KTM 990 Baja
2011 Husaberg FE 570
Knobbiethrower screwed with this post 03-01-2013 at 04:29 PM
Knobbiethrower is offline   Reply With Quote
Old 03-01-2013, 07:13 PM   #16222
bill pierce
I don't wana pickle
bill pierce's Avatar
Oddometer: 741
I need to buy a shop manual and was wondering if the factory Honda manual is better than the Clymer.
Anyone with both?
bikes
BMW R1100s,destroyed by deer strike.
Yamaha FZR 1000 (sold)
Honda Cr 500 sold
bill pierce is offline   Reply With Quote
Old 03-01-2013, 07:40 PM   #16223
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,294
Anyone with both?
Can't say I've seen the Clymer for the BRP, but all of my previous uses of Clymer pale in comparison to factory manuals. And Honda manuals have been some of the best I've ever seen from any factory.
Get a factory manual, you won't be sorry. Or find a download for the .pdf.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 03-01-2013, 08:26 PM   #16224
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 811
Yeah, I just recently downloaded the pdf. If you can't find it, send me a pm with your email, and I'll get it to you.
So I got the replacement thermostat from NAPA and went to pull the old one out to see if it was stuck open. Turns out the previous owner must have read the same thing I did about not having to run it with the thermostat, because there wasn't anything there.
Hopefully that's all that's wrong with it, I'll find out tomorrow when I warm it up to change the oil and then really take it out and see how it's doing.
nigelcorn is online now   Reply With Quote
Old 03-01-2013, 09:06 PM   #16225
galland1
galland1's Avatar
Oddometer: 112
Did you drill a bleed hole in the stat?
Sent from my Galaxy Nexus using Tapatalk 2
galland1 is offline   Reply With Quote
Old 03-01-2013, 09:07 PM   #16226
Mur
Wheee!
Mur's Avatar
Oddometer: 21
Anyone with both?
I use both. The Honda manual goes in depth into things the Clymer doesn't.
Mur is offline   Reply With Quote
Old 03-01-2013, 09:09 PM   #16227
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 811
What? I haven't heard of that before. No, I didn't drill anything.
Sent from my Nexus 7 using Tapatalk HD
Hmm, maybe I should have read a bit more carefully. Now I get to drain the coolant again to drill the hole.
Old 03-01-2013, 09:23 PM   #16228
galland1
galland1's Avatar
Oddometer: 112
A pic of my failed OE stat.
Old 03-01-2013, 09:44 PM   #16229
galland1
galland1's Avatar
Oddometer: 112
Going to try out a 280mm and some carbon pads.
Old 03-01-2013, 10:03 PM   #16230
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,618
muffler
Anyone buy an aftermarket muffler recently? Mine came with an old Big gun one that does not have a sparky and loves to blow out packing and is way too loud.
I think I would go OEM but can't seem to find one.
Jayrod1318 is offline   Reply With Quote
Times are GMT -7.   It's 12:21 PM.
