03-01-2013, 10:31 AM
#1 |
All Hands on Deck!
Oddometer: 20,692
Rebuilding my VW Type One 1600cc motor
I'm going to rebuild my VW Air cooled Type 1 engine. Currently it has single port heads and is running with a 30-PICT carburetor. The vin on the motor starts with AH so it's dual relief 1972 case and should be a good to use if it all checks out at the machine shop. RIMCO is in my area and they know the VW motor better than about anyone and they are the machine shop I plan on using for parts inspection and I'm leaning towards them assembling the long block when I get the parts sourced and together.
Around $2500 is my budget... Used parts, New parts, keep the heads, use DP heads, single carb, dual carbs, turn key motor.....?? I'm entertaining thoughts and opinions. Not looking for HIGH horsepower, but strong, reliable and semi-good gas mileage. Old motor revved to 4k and I want a more usable power band.. at least rev to 5k with power would be fine. Swing Axel, stock drum brakes and it's a BAJA BUG... low end torque and gas mileage work great when off road... Pleasure vehicle not a race vehicle. Parts, thoughts, crass humor... what ya got? ![]() ![]()
What is this Green Energy we are looking for? "Self Replicating Carbon Sequestering Bio-Nano Technology"................TREES are the Answer! |
03-01-2013, 10:38 AM
#2 |
Remastered Classic
Oddometer: 4,584
I'm pretty sure something about a "TDI" will surface soon enough...
There. Their. They're not the same. (By reading this, you have briefly given me control of your thoughts) When life gives you melons, you might be dyslexic. |
03-01-2013, 10:50 AM
#3 |
Oddometer: 792
Definitely go with DP heads. Theres lots of info out there on which ones are good and which are not. Hell there was a two part artical a couple years ago in Hot VW's that was a good read. Have you talked your plans/needs over with RIMCO? they may have some pretty good ideas.
If it wasn't for my graceful wife, my dumbass would be banned already Doug Mc Gee 01 1150 GS 84 R100RS 74 XL350 |
03-01-2013, 10:54 AM
#4 |
Air cooled runnin' mon
Oddometer: 6,112
This is probably a little tail happy though.
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
03-01-2013, 11:06 AM
#5 |
Oddometer: 799
![]() Im in, i love an old aircooled!
Project Labor of Love: 1972 CT90 Rebuild Current Stable: DRZ400 | VFR800 | DRZ250 | CT90 | CB125 Need an airfilter for your DRZ250!? I have too many, PM ME
03-01-2013, 11:19 AM
#6 |
All Hands on Deck!
Oddometer: 20,692
The red one is nice... A Factory convertible like mine...Not a CHOP.
I have spoke with RIMCO and they want me to tell them what I want.. So many choices most of which are dictated by budget...as with most things in life. Most likely use the stock crank and rods, which means 1776, 1835 or 1915.. Will keep the compression low so I can run 87 octane. Had a friend who's an off-roader and fabricator said keep the single ports, 30-PICT and go to 1915cc's with the piston and cylinders...run a 110 long duration cam. Torque monster and real good gas mileage... Not sure, most everyone else says DP's and that means new carburation..
03-01-2013, 11:35 AM
#7 |
Oddometer: 3,961
This one is a 1776 and has plenty of power, I am doing a 1300cc bug right now.
I understand the rail is quite a bit lighter, but after the snow melts it is going to get driven to work from time to time....quite often I think.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist[/FONT] |
03-01-2013, 11:48 AM
#8 |
Oddometer: 142
The sanba,is a good site for VW info.
03-01-2013, 12:11 PM
#9 | |
Oddometer: 6,112
That VW was in Laguna Beach a few years ago, so not too far from you. If on a budget, just a light going over would probably give you the most bang for the buck. I don't know anything about bugs though. Closest I ever came to owning one was when I bought a Corvair. Try Bugformance.http://bugformance.reachlocal.com/?s...r_id=182866790
03-01-2013, 12:13 PM
#10 |
Riding Nomad™
Oddometer: 12,717
Upgrade to 2.3L Type4, turbo, and never look back..
Learn to ride. Ride to learn. FS: 1993 Suzuki DR350S (wide ratio 6 speed - street legal kickstart) |
03-01-2013, 01:46 PM
#11 | |
Oddometer: 792
03-04-2013, 09:23 AM
#12 |
All Hands on Deck!
Oddometer: 20,692
Pulled the heads and cylinders off...
03-04-2013, 12:49 PM
#13 |
Push'n parts
Oddometer: 3,175
at first i thought you were wierd for leaving it bolted up to the trans, then i realised you are using it for a motor stand
Get to work, millions on welfare are depending on you |
03-04-2013, 07:03 PM
#14 |
Oddometer: 4,594
Always amazed they don't use head gaskets.
'01 Kawasaki W650 '05 Yamaha XT225 |
03-05-2013, 02:51 AM
#15 |
Bam Bam
Oddometer: 76
I would look at building a 85.5x76 stroker motor. No need to fly-cut case and heads but you will need to clearance the case. Single port heads will limit your rpm but on a stroker its all about grunt and gas milage. I will be doing this to my manx clone when the time comes.
| Thread Tools | |
