Old 03-01-2013, 02:16 PM   #931
ohgood
ohgood's Avatar
Oddometer: 3,129
Originally Posted by CatSailor View Post
Usually in the spring or summer my friends start bringing their engines to my garage that have been sitting since last summer. Usually a 6" section of stripped multi conductor lamp cord does the trick. Depending on the size of the clogged jet, 1-3 strands twisted and GENTLY worked through the jets gets the problem fixed.
Blind bearing removal w/o a puller: pack the recess behind the bearing, place a shaft in the center of the bearing and hit it with a hammer. The bearing will pop out.
A foiled gum wrapper wrapped shiny side out around an old buss type fuse will get you home - fix the reason of the blown fuse 1st!
hydraulics are awesome stuff. thanks for posting this, i had forgotten.
(years ago i watch in amazement as a 15 ton propeller was stretched and pressed onto to a shaft, all at once)
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 03-01-2013, 02:28 PM   #932
ohgood
ohgood's Avatar
Oddometer: 3,129
Originally Posted by cat View Post
Until you get up and kick it.
you've seen me in the garage ? wthell ? lol
ya, i quit with pie pans, now it's either:
a) 5 gallon bucket (tire changes, all tools AND parts inside)
b) ziplocks (oily parts, lots of them
c) duct tape, peal a strip off and put each part in the next space. re-assembly = reverse it
d) magnetic ashtray
Old 03-01-2013, 07:47 PM   #933
MsLizVt
pfft ...
MsLizVt's Avatar
Oddometer: 1,619
Wow! Now i'm curious ...
Originally Posted by ohgood View Post
hydraulics are awesome stuff ...
ohgood, hi!
Hope you don't mind me asking, but how did they actually do that, stretching and pressing the propeller on?
You've piqued my curiosity.
Thanks,
Liz
MsLizVt is offline   Reply With Quote
Old 03-02-2013, 06:09 PM   #934
mrbreeze
mrbreeze's Avatar
Oddometer: 9,075
I haven't read the entire thread, so forgive me if any of this is 205
I have a thermarest pad I lay on the garage floor whenever I need to lay down next to the bike to change the oil, check the tires, whatever. Way better than lying on concrete.
My bike is supposed to be upright when the oil is checked, but doesn't have a centerstand. I got a small mirror with a telescoping handle, so I can check the oil while sitting on the bike. I got it from Sears.
Before I work on the bike, I always sweep the garage floor. That makes it a lot easier to find that washer I always drop.
2013 Suzuki DL650 Adventure
Travels with Maw Maw
mrbreeze is offline   Reply With Quote
Old 03-03-2013, 12:22 AM   #935
KyoXR
Clouds, Snow, Rain
KyoXR's Avatar
Oddometer: 786
+1, your the first other person I have heard that does this, also, sweeping the dirt away keeps anything that hits the floor from picking up dirt, parts/tools/your body/that rag your supposed to be cleaning stuff with ect...
2007 XR650L
Looking to acquire a stock XRL choke plunger.Also don't get Wenzeled
KyoXR is online now   Reply With Quote
Old 03-03-2013, 12:51 AM   #936
Tom S
Can I ride it?
Tom S's Avatar
Oddometer: 4,584
Originally Posted by KyoXR View Post
+1, your the first other person I have heard that does this ...
I think most people do. Hardly a ‘trick’.
Tom S is offline   Reply With Quote
Old 03-03-2013, 07:31 AM   #937
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
My trick is old carpet runners under the bike. Sops the oil spills and dampens the falling washers/bolts....they don't go so far.
No need to sweep, the ShopVac is always close by. I should go shopvac the bike maybe I'll find that SS fastener I dropped a couple days ago around the radiators.
Have tools, will travel!
Old 03-04-2013, 10:05 AM   #938
muguvian
lugrubious
muguvian's Avatar
Oddometer: 105
Invert a sock or piece of pantyhose over the end of the vacuum to catch the fastener.
muguvian is offline   Reply With Quote
Old 03-04-2013, 10:24 AM   #939
ohgood
ohgood's Avatar
Oddometer: 3,129
Originally Posted by MsLizVt View Post
ohgood, hi!
Thanks,
Liz
ill dig up some cool stuff when I get home :)
Old 03-04-2013, 11:14 AM   #940
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Nauseum tent screening material....last much longer and better at filtering the juice from the parts washer.
Set of micro brushes/reaching tools, best thing you can buy for them shopvacs, then you can use it on the computer.
Old 03-04-2013, 03:03 PM   #941
MsLizVt
pfft ...
MsLizVt's Avatar
Oddometer: 1,619
Great! Thanks!
Old 03-05-2013, 06:56 AM   #942
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
Watched a professional rebuild front forks from an MX bike. He put all the valving in order on a safety lock pin.
scooteraug02 is offline   Reply With Quote
Old 03-05-2013, 01:29 PM   #943
ohgood
ohgood's Avatar
Oddometer: 3,129
Great! Thanks!
ok, i'll dig up old pictures...
this is a fairly large prop/wheel, depends on the person calling it:
(and my super sexay gs500, ahhh, great bike)
which has a bored taper fit. the fit is checked against the mating taper on the prop shaft (which you can see on the end of the long hanging prop shaft at the beginning of the video, to the LEFT)
http://s33.beta.photobucket.com/user...tml?sort=3&o=4
that may/may not have heavy threads, which DO NOT hold the prop on, but are only used for assembly for what we're discussing:
pre- measure distance from end of prop shaft to prop face, record...
1) check prop taper with blueing dye, against shaft taper, by hoisting the prop even with the shaft, then SLAM it into the shaft (4-5 guys push hard as hell)
2) if 90% or so contact is found, assemble the prop+shaft, then the heavy nut, to prevent the prop falling off from hydraulic pressure...
3) pipe thread were drilled and tapped into the prop, and port-a-power hand jacks are used to put pressure on the nut towards the special seal between nut/prop.
...sorry, no pretty pictures...
4) after 2000 or so psi is achieved, an electric/hydraulic pump is attached to the MIDDLE of the prop, in similar tapped pipe thread holes. shit tonnes (metric, not imperial !) of pressure are applied, i don't recall how much.
5) temperature readings are taken on the prop, and fluid leaks from around the seal and taper, it's inevitable. remember, a shit tonne of pressure here.
as the pressure builds, the fluid heats up, the prop heats up also, and it swells. the area of swelling is somewhere around 3-4 feet long by 3-4 feet wide, stainless or whatever the material is of the prop. after x amount of time (usually determined by 2 engineers and a crusty ship yard worker) a measurement is taken from the end of the shaft to the prop face again. if it's moved up the shaft enough, it's considered 'done' and mechanically 'shrunk' into place.
6) the prop, shaft, and oil is given time to cool.
7) the pressure is relesaed from the prop's hydraulic lines, and the temperature drops again with the pressure.
8) pressure is maintained on the seal and nut for a few hours, and the shaft+prop is rotated by the crane + belts to allow all the oil to drain, if any, from the prop / shaft taper. there should be little to none at this point. it's a metal to metal taper. (remember the blueing check?)
9) indicators (the apprentices, cause mine are nice!) are installed on the fore/aft faces of the prop, and the fore/aft faces of the prop are struck (understandment) with HUGE sledge hammers by big guys. any movement is a failure, and the process is repeated from step one.
10) pressure is released from the seal/nut, the nut is 'torqued' with a 12' cheater pole (no shit) and a crane, until the assembly turns from the stress. this is 'tight'.
11) much beer is drunk, pictures taken, and a new 1/2 a million dollar prop shaft is ready for delivery to some ocean going vessel, AFTER the insurers agree it's 'good'.
sorry i don't have more pictures. that was a while ago, and a very very very busy time.
i have mucho respect for lifetime mechanics and shipbuilders. they are hardasses for a reason.
Old 03-05-2013, 06:32 PM   #944
geolpilot
geolpilot's Avatar
Oddometer: 121
Good old STP oil treatment is VERY slippery stuff. It is excellent for getting recalcitrant hoses onto fittings, shock bushings installed and other rubber to metal problems. My aircraft mechanics also used it for assembly lube on engines. It is slick and thick.
geolpilot is offline   Reply With Quote
Old 03-05-2013, 07:24 PM   #945
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,897
There are some great ideas in this thread.
I was wondering if anyone had some good suggestions for how to store a parts bike in a 2 car garage, with no wheels, whithout disassembly, and without taking up floor space?
I have considered hoisting it up to one of the large rafters in my garage, but the big rafter/ overhead joist support runs right down the center of the main work space, and I would not be able to get it above head height..
Any suggestions or ideas would be appreciated.
BK.RD.RNR is offline   Reply With Quote
Times are GMT -7.   It's 12:46 AM.
