Old 03-02-2013, 11:08 PM   #31
StoneAgeMan
Wanderer
StoneAgeMan's Avatar
Oddometer: 721
Originally Posted by Countdown View Post
... counting the number that do not fail has no information. ...
For simple folk like me, if 2 out of 2,000 things have a failure is pretty different than 2 out of 200,000 having the same failure. By a couple orders of magnitude.
I find that knowing "number not failed", along with "number failed", of a product to be quite useful.
StoneAge Man
StoneAgeMan is offline   Reply With Quote
Old 03-02-2013, 11:48 PM   #32
Countdown
Oddometer: 5,345
Absolutly true, if you somehow knew the number that didn't fail then you know the number that did fail (# produced less # didn't fail = # failed).
However just knowing that 10 out of say 10,000 produced did not fail just means that all you do know is that less than 9,980 did fail. Not much information there.
Jerry Counts
Countdown is offline   Reply With Quote
Old 03-03-2013, 05:19 AM   #33
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,541
What defines the failure here anyway? If a gps "fails" because it was torn out of its mount by a tree branch then driven over by a wheel, then I'd say that's not really a failure of the gps since it wasn't designed to survive that.
Or is it the design of the RAM mount for the 60 which is flawed?
I'd say that there are fewer failures of the 76 reported simply because it was less popular. That's probably why they ran out of 60s long before the 76, after both were discontinued.
I really liked my 60 until Garmin started making units with better map capabilities. I had 2 X 60C, and a 60CSx and my wife had the 76S as well as a 76CSx.
Emmbeedee screwed with this post 03-03-2013 at 05:31 AM
Old 03-03-2013, 06:32 AM   #34
freeflow
get in or go in
freeflow's Avatar
Oddometer: 15,617
Originally Posted by Emmbeedee View Post
A well placed piece of electrical tape will keep the card lock mechanism from moving.
I jammed an earplug there, under the batteries. Keeps the batteries from vibrating and power loss too
freeflow is offline   Reply With Quote
Old 03-03-2013, 06:43 AM   #35
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,541
Good idea. Foam earplugs are versatile.
Times are GMT -7.   It's 04:20 AM.
