Old 03-02-2013, 08:20 PM   #17671
CatfishRacing
Just a rider.
CatfishRacing's Avatar
Oddometer: 595
Mine were from a guy in the US.
No idea where they were made though.
I had mine off and my bike started and got about 12 miles on the interstate (at about 75mph) before it started to sputter.
What's the point in having an off position?
Catfish
FarkleMasters.com
IBA #12835
AMA Lifer
CatfishRacing is offline   Reply With Quote
Old 03-02-2013, 08:36 PM   #17672
fuelish
Oddometer: 732
Often, a plastic(composite/teflon/nylon) gear is used because it has damping properties. Smoothing the shock load from a single cylinder piston stroke on to the pump it is spinning . They can even offer increased life over an aluminum or steel gear, because often the softer part will imbed particulate and it will act as an abrasive against the harder material.
Also, SquadraCorse, that bike looks great, love the Martini team colors. Makes me want to Johnny Player Special my black SM.
fuelish is offline   Reply With Quote
Old 03-03-2013, 06:27 AM   #17673
Okipouros
Oddometer: 8
Its plastic cause is cheaper
I havent seen an oil pump total failure, some reduced pressure because of wear yes, have you seen one?
Okipouros is offline   Reply With Quote
Old 03-03-2013, 06:41 AM   #17674
LSGiant
LSGiant's Avatar
Oddometer: 1,091
Glad to know you work at Suzuki, are you in Engineering or Purchasing?
"Keep it rural, don't over water"
2010 Concours, 2000 DRZ400E
COG 7524, IBA 46513, GLMC 214
LSGiant is offline   Reply With Quote
Old 03-03-2013, 07:28 AM   #17675
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
What is wrong with you guys? I gave you the Genuine Yamaha part # and price already..... They are $26.99, work for years, don't leak, fit right on and have a built in tank filter. Some aversion to going to your local Yamaha dealer? Why would you try to buy one cheaper than $26.99 online?
buls4evr is offline   Reply With Quote
Old 03-03-2013, 07:44 AM   #17676
CatfishRacing
Just a rider.
Oddometer: 595
The eBay parts I bought weren't any cheaper.
I don't remember why I went eBay over Yamaha.
I think the eBay part could get to me faster but I'm not sure.
I just want everybody to learn from my mistake and stay away from the eBay junk.
Catfish
FarkleMasters.com
IBA #12835
AMA Lifer
Old 03-03-2013, 07:56 AM   #17677
dasvis
dasvis's Avatar
Oddometer: 536
+1, here's a past post I made with a photo of the Yamaha petcock. Cheap & looks factory stock.
http://advrider.com/forums/showpost....ostcount=15629
Dasvis
What? Over? Did you say "over"? Nothing is over until we decide it is! Was it over when the Germans bombed Pearl Harbor? Hell no!
2009 Suzuki DRZ400S
dasvis is offline   Reply With Quote
Old 03-03-2013, 09:53 AM   #17678
150ron
150ron's Avatar
Oddometer: 1,314
I recently installed one of those cheap ebay raptor petcock's on my bike, and it has been fine,
only reason i got it is cause i had this problem with my other more expensive ON/OFF/RESERVE petcock, this one would hit the tank, the raptor one hangs down further, clearing the tank.
Just some dude...
150ron is offline   Reply With Quote
Old 03-03-2013, 10:06 AM   #17679
Xylx
Oddometer: 87
Raptor World (Japanese edition)
Good point. Except I did not go online with the intent of saving money. I mistakenly (naively) assumed that any "Raptor" was a genuine Raptor Yamaha part. I have no problem with the Yamaha dealer except that it would take an hour and a half of my time to drive through the traffic and back. I was saving myself time (which is more precious than money at my age) and aggravation (I get enough of that at work). Hopefully this discussion will help others to follow your advice and make sure they get a genuine Raptor.
Xylx is offline   Reply With Quote
Old 03-03-2013, 11:45 AM   #17680
motolab
motolab's Avatar
Oddometer: 2,584
See the last line item at www.advrider.com/forums/showthread.php?t=528038.
Regards,
Derek
motolab is offline   Reply With Quote
Old 03-03-2013, 01:44 PM   #17681
effensteve
Enjoying the ride
effensteve's Avatar
Oddometer: 717
I used the wr400 petcock on my clark tank. Works great no problems what so ever.
effensteve is online now   Reply With Quote
Old 03-03-2013, 06:11 PM   #17682
Mudclod
Mojo Moto
Mudclod's Avatar
Oddometer: 1,511
Got my "Raptor" petcock from Bike Bandit. Genuine OEM part in OEM box, works great. I always turn petcock off with the wonderful ethanol we get to burn now!
74 TY250 89 GB500 97 XR650L 03 KDX220 06 DRZ400 08 DL1000 09 XR1200
If you don't know where you're going, any road will take you there.
Down Texas Way
Mudclod is offline   Reply With Quote
Old 03-03-2013, 06:25 PM   #17683
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
grinding off the edges on the shifter today and decided if there ever was a bolt that needed safety wiring this was it.
mars is offline   Reply With Quote
Old 03-04-2013, 07:01 AM   #17684
SquadraCorse
SquadraCorse's Avatar
Oddometer: 133
I saw something similar on a black SM at some point. They had the gold boarders around the side panels and fenders, but no JPS anywhere, so who knows if that's what they had based it off of. Looked great though. I think the big JPS logo on the radiator shrouds with the gold trim around the body panels would be clean and classy. If you had some gold anodized hubs or rims it would really set it off.
Thanks for all the compliments everyone, much appreciated.
2013 RallyMoto Overall/Dakar Champ
http://styleperpound.blogspot.com/
BMW R1100S Light | KLX 400
SquadraCorse is offline   Reply With Quote
Old 03-04-2013, 12:47 PM   #17685
bkwags
bkwags's Avatar
Oddometer: 84
Seals and Shocks
Bought a 2001 DRZ last fall and have it stripped down for inspection and some minor repairs.
I replaced the front wheel bearings and one seal. Was wondering if there should be two seals. The kit came with two, but there was only one on the bike when I tore it down. Does the speedo pick up casing act as the second seal? Can I pack it with grease or ????
Also, the rear suspension seems a bit soft. I weigh about 210 in street clothes. The spanner nuts seem to be about 1/2 way down the threads. Since I am not familiar with these shocks and I get timid around compressed nitrogen I was wondering how they work. I see there are different screws and settings, a Schrader valve and other assorted nick nacks. Tried to search the thread, but did not come up with anything of relevance, probably used the wrong key words. What is the proper way to check and adjust the rear suspension?
Any advice on either of these subjects would be appreciated.
BKWags
bkwags is offline   Reply With Quote
Times are GMT -7.   It's 05:50 PM.
