Old 03-03-2013, 06:33 PM   #1
sherpa7 OP
Oddometer: 20
12 o Clock Labs rear tail-light help
I have a Honda CRF 250 L and am putting on the new rear tail-light. I did a crappy job at crimping but they are holding. I spliced the 5 wires but the light only gets full power if the left turn signal comes into contact with the power wire. With just the power wire hooked up and not touching anything else, I do not get the license plate lights to go on.
The signals are not doing what I want. Likely programmer (me) error. I have triple checked the wiring diagram and they are hooked up correctly. Will a bad crimp job cause these gremlins? Is there a better easier connector I can use?
Any help would be appreciated.
sherpa7 is online now   Reply With Quote
Old 03-03-2013, 09:34 PM   #2
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,291
I've got two of these, one on the DRZ and the other on the XR 650R, both were pretty straightforward. All my paperwork is out in the shop but I remember having tail, ground, L turn and R turn. I solder all of the connections and shrink wrap. I always get all the wires connected before I solder anything. Double check your ground. I'll look at my diagram tomorrow if no one else pipes up.
PineyMountainRacing is online now   Reply With Quote
Old 03-03-2013, 09:59 PM   #3
sherpa7 OP
Oddometer: 20
Thanks Piney,
Might go the solder route as well. Yeah the tail-light black wire is the ground which is giving me the problem.
I am also thinking of using these:
http://www.posi-lock.com/posilock.html
Old 03-04-2013, 03:06 AM   #4
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 992
Weird lighting action often results from bad grounding.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Times are GMT -7.   It's 09:12 AM.
