Old 03-04-2013, 07:43 PM   #1
YJake OP
Roaming
Oddometer: 327
DOT 3 in a DOT 4 reservoir...
It was an accident, filled the reservoir and went "D'oh"
Will I be alright if I just use DOT 3/4 and flush the system with a bottle of fluid?
I also got some of the Brake fluid on my rear tire... What can I use to get it off and how dangerous is it?
Thanks all,
-Jake
Touring The Gulf
YJake screwed with this post 03-04-2013 at 07:49 PM
YJake is offline   Reply With Quote
Old 03-04-2013, 07:50 PM   #2
ragtoplvr
Oddometer: 6,048
They are both about the same, and can be interchanged. Dot 4 has a higher boiling point. But they mix fine. Relax.
I usually use dot 4 where they specify dot 3 as it is more expensive and hopefully have better anti-corrosion additives.
Rod
ragtoplvr is online now   Reply With Quote
Old 03-04-2013, 08:52 PM   #3
manic mechanic
manic mechanic's Avatar
Oddometer: 158
What he said. Given the choice, I use DOT4 when rebuilding brake systems, unless the system calls for DOT5, or even mineral oil in some hydraulic clutches.
'76 R90/6, '07 K1200GT
Rounder #6
MOA Ambassador
RA WI Regional Rep
manic mechanic is offline   Reply With Quote
Old 03-05-2013, 05:22 AM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,171
Wash off DOT 3 or 4 with water. It is water soluble, mixes with water, which is also one of it's problems because it absorbs water from the atmosphere and this causes pitting in cylinders. Change brake fluid at least once a year by flushing with fresh fluid from a new container.
---Albert Einstein
Old 03-05-2013, 09:14 AM   #5
mbfj40
Oddometer: 167
Biggest difference between Dot 3-4 and 5 is the temperature rating before the fluid will boil. A lot of the Dot 5 fluids are silicone based and can get a "spongy" feel near it's highest temperature ratings, as well as not absorbing water like the Dot 3's and 4's can, which lowers the fluids boiling point even more. A simple flush of your system with Dot 4 will get you back to OEM specs for the higher temp rating that your OEM called for. In the mean time, at less than race speeds, extreme duty and maximum braking, you most likely aren't anywhere near boiling even the Dot 3 for grocery runs or a casual a ride out for breakfast or lunch.
safe ridin
mike
mbfj40 is offline   Reply With Quote
Old 03-05-2013, 09:54 AM   #6
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,560
Just to clarify, do NOT mix DOT3/4 with DOT 5. You will end up with a guey mess in your brakes that does not work. Dot 5 is silicone based, DOT 3/4/5.1 are glycol based.
Jim
PS DOT3/4 is fine for all but the most agressive street riders.
Old 03-05-2013, 12:04 PM   #7
fast4d
Oddometer: 2,278
no need to freak. we'll let it slide this time.
next time buy DOT4
if you can't sleep in peace just flush it out with DOT4.
Alan
2011 KTM RC8R
2012 BMW S1000RR
2000 Kawasaki ZRX1100
2013 KTM SMT 990
fast4d is online now   Reply With Quote
Old 03-05-2013, 02:13 PM   #8
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,527
Start over.
scooteraug02 screwed with this post 03-05-2013 at 02:21 PM
scooteraug02 is offline   Reply With Quote
Times are GMT -7.   It's 06:47 PM.
