Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 03-03-2013, 10:43 PM   #316
Going_Commando
Going_Commando's Avatar
Oddometer: 511
Originally Posted by adam_c_eckhardt View Post
What argument? I only have loud discussions.
We're going with a generator at some point- just don't know when, and it will be propane. Doesn't code say that if you have an automatic transfer switch that the generator has to be able to power EVERYTHING in the house? Just curious.
We pre-wired for the hot tub today. Not that we can afford one but at least we can plug one in. Also got the well wired up and was happy to see water for the first time. We're getting close to being done with the rough-in wiring. A few nights this week and we should have it.
After the plumber does his thing I'm going to pre-plumb for central vacuum.
The AV guy continued wiring today (he likes working weekends when the rest of the crew isn't around.)
Shoot me the square footage, what you'll have for AC, and how deep your well is (roughly) and I will shoot you the info for how big a generator you need to do a whole house transfer switch, and give you a couple other options too.
Going_Commando is offline   Reply With Quote
Old 03-04-2013, 04:15 AM   #317
weave
Oddometer: 651
you can wire the transfer switch to an emergency panel, those items you wish to use when the power is out. Meets code and allows you to use smaller generator.
weAve
weave is offline   Reply With Quote
Old 03-04-2013, 05:25 AM   #318
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,347
Subscribed.
That floor pour video was great.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 03-04-2013, 07:39 PM   #319
adam_c_eckhardt OP
done with Chemistry!
adam_c_eckhardt's Avatar
Oddometer: 5,177
Roughly 2200 square feet finished. 2800 total.
Well pump is about 450 feet down.
30 amp wall oven
gas cooktop
AC is off a double pole 20 amp
Don't forget the hot tub.
adam_c_eckhardt is offline   Reply With Quote
Old 03-05-2013, 12:25 PM   #320
Going_Commando
Oddometer: 511
30 amp wall oven
gas cooktop
Soo, after doing a bunch of calcs, and figuring pricing versus fuel consumption/hr, buy a 20KW (forget the hot tub on the generator). I didn't realize you had an electric oven before, and load shedding just the AC doesn't really save you enough $$ to mention with the oven in the picture. I figured it was gas, and that thing is a power hog. The load calc for your house comes out to 19,820VA, which equates to 19.8kW, or 83A. If you had gone with a gas oven, and slapped the AC on a load shed module, you could get away with a 10 or 12kW generator, hence why I mentioned 10kW earlier. The Kohler 20kW should only set you back about another $500 over a Generac 20kW, and with that in mind I would go Kohler 6 days a week and twice on Sunday. An Onan 20kW (Cat's ass, bee's knees, Cadillac, etc) is going to cost about $1000 more than the Kohler, but even that, in my opinion, is worth it in every way. When I get my own place in the sticks, it is going to have an Onan for backup power. I have worked on several Onans that are 20, 30, 40, 50 years old, and are still purring along like kittens (really big, noisy kittens ).
Engine work on a Generac is a test in patience and fortitude, so if your Generac needs to be worked on outside of warranty, it is going to be pricey as hell. The Kohler is still easier to take apart than a Generac, but neither can touch the Onan. It looks like Onan hopped on the V-Twin bandwagon, which is really too bad. Their older residential standby generators were boxer twins, and were an absolute breeze to work on. Here are some spec sheets for you to peruse:
Onan:http://www.cumminsonan.com/www/html/...ets/a-1555.pdf
Kohler:http://kohlerpower.com/onlinecatalog/pdf/g4209.pdf
Generac: http://www.generac.com/Brochures/0193260SBY.pdf
If you want, I can PM you some prices, but I am not going to put them up in the public domain for obvious reasons.
Old 03-05-2013, 02:21 PM   #321
adam_c_eckhardt OP
Oddometer: 5,177
20KW eh? At least you and I can share a laugh over that!
Thanks for the info Jeff. I REALLY appreciate it. And I'd be curious as to how the numbers would pan out- if you shoot me some numbers (NO RUSH) that'd be great.
Let me know what kind of beer you like and I'll have some waiting for you next time you visit.
Old 03-05-2013, 05:42 PM   #322
ian408
Oh?
ian408's Avatar
Oddometer: 14,325
Just go with the gas fired hot tub
ian408 is offline   Reply With Quote
Old 03-05-2013, 05:48 PM   #323
adam_c_eckhardt OP
Oddometer: 5,177
Ordered $1000 worth of circuit breakers today (damn arc fault breakers!). Only hot tub I'll be seeing anytime soon is a free one!
Old 03-05-2013, 06:25 PM   #324
ian408
Oh?
ian408's Avatar
Oddometer: 14,325
I learned about those at my last job. Imagine trying to explain how come a breaker costs $1000 All I can add is hopefully, the electrician knows how to install them properly.
Old 03-05-2013, 06:35 PM   #325
adam_c_eckhardt OP
Oddometer: 5,177
Well they're about $37 a piece but I need 19 of them. Throw in a handful of standard single pole 20 amp, a few double poles, etc, and it'll be pushing a grand.
Yeah I'm pretty sure the electrician knows how to install them. Someday maybe the panel manufacturers will make a panel that has grounding bars and neutral bars on BOTH sides.
Old 03-05-2013, 07:41 PM   #326
Going_Commando
Oddometer: 511
Did you not see the grounding bars for sale at home depot and all the extra drilled and tapped holes in the back of the panel enclosure?
Old 03-05-2013, 09:14 PM   #327
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,055
The thing that pisses me off about the AFCI breakers is the failure rate. The ones that we've put in remodels 4-5 years ago are starting to trip for no reason more and more often. I'm not a fan of AFCI and tamper proof receptacle requirements.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 03-06-2013, 01:27 AM   #328
Going_Commando
Oddometer: 511
Check to make sure the grounding conductor isn't touching the neutral screws on receptacles. I had an AFCI circuit that kept tripping, and that ended up being the problem. When installing 150 receptacles in a dwelling, this can happen.
Old 03-06-2013, 04:31 AM   #329
adam_c_eckhardt OP
Oddometer: 5,177
Shadddup.
I'm going to design the perfect panel and laugh all the way to the bank.
Old 03-07-2013, 09:35 AM   #330
Going_Commando
Oddometer: 511
Shadddup.
Siemens can and neutral layout, and square-d QO breakers. You're welcome
Thread Tools
Times are GMT -7.   It's 08:11 PM.
