Old 03-04-2013, 12:04 PM   #136
wingwing OP
Oddometer: 119
Branded Fue vs "generic" fuel vs easy to find
I know I've read it all comes from the "same tank"..
.. but I still prefer to purchase "Brand Name" over "no name".
In this order, I usually I look for:
Chevron ,Shell,Texaco,Exxon and BP.
... but they seem to be getting harder and harder to find.
Used to be Chevron and Texaco both added techron to their mix..
..not sure if they still do that.
Anyone else prefer the branded fuel over the no-name fuel?
Dennis
because they're getting harder to find around here,
I created an additional search page for it in the "additional weather" section
called Brand Fuel within 12 miles.
It shows your current location and nearest 20 gas stations within about 12 miles based on my preferred list.. then fills in with Kangaroo if nothing else is around.
.. looks like this:
wingwing is offline   Reply With Quote
Old 03-08-2013, 07:15 AM   #137
wingwing OP
Oddometer: 119
It is Friday AM and main street is already "clogged"..
.. nice.. I don't care what the calendar says..
..NOW it must officially be "spring"
if you have easy map.. just go to Hourly or 7-Day and I've added "traffic" when you zoom in..
see you there!
Dennis
Old 03-31-2013, 09:08 AM   #138
wingwing OP
Oddometer: 119
minor update..
What's in this version:
Mar 21st,2013 v5.23
Change log info:
http://fogbog.com/help/ChangeLog.htm
THERE HAVE NOT BEEN ANY CHANGE IN PERMISSIONS.
Please, if you have a question or concern, contact me first.
I answer all emails.
Minor update details:
>> geo-referencing for fuel, events and google alerts
>> Long tap HOURLY or 7-DAY now shows cloud cover & traffic
>> Faster NexRad updates (location now updates every 5 seconds.)
>> Tablet tested ok for the Nexus 4.2.2
Does not work in Canada because there are no public NexRad sites to access.
happy trails.. safe riding..
Dennis
www.fogbog.com
Old 04-13-2013, 09:17 AM   #139
wingwing OP
Oddometer: 119
minor update..
added map of ethanol free gas stations
check WEATHER - ADDITIONAL WEATHER -- Geo-Ref Section
Dennis
www.fogbog.com
wingwing screwed with this post 04-13-2013 at 10:14 AM
Old 04-13-2013, 08:42 PM   #140
drdubb
OFWG
drdubb's Avatar
Oddometer: 404
power consumption
Do you have any hints on reducing power consumption in the Droid.
I have a USB charger hooked up, but I find that if the cord works loose or if I let the charge drop, it is very difficult to get the droid back up to full charge.
'06 DR650 - Suzuki
'95 750 Nighthawk - Honda - for sale
'83 650 Nighthawk - Honda - for sale
'71 SL 350 - Honda
drdubb is offline   Reply With Quote
Old 04-14-2013, 01:17 AM   #141
wingwing OP
Oddometer: 119
You can't really reduce the power consumption..
.. you need to increase the charging rate.
The problem is the USB charger.
That is only 400 ma.. That is barely a trickle charger and not enough to use the GPS while charging.
.. it is not designed to both use and charge the phone at the same time.
Go to "Best Buy" and get their "Rocketfish" charger..
.. about $26 but it is rated at 2500 ma.
More info here about 1/3 the way down:
http://www.fogbog.com/gl1800/Android...hing/index.htm
Dennis
wingwing screwed with this post 04-14-2013 at 10:43 AM
Old 05-02-2013, 12:08 PM   #142
wingwing OP
Oddometer: 119
Just in time for Spring
I added another page to the Geo-Referenced section.
No new download needed, it's just there.
It almost could replace many of the other wea functions.
From the home page, go to WEATHER then ADDITIONAL WEATHER then in the GeoRef@@ section:
"Current: Clouds, and high/low Temps
..then.. either zoom out for Satellite overlay OR tap the icon for WIND, Humidity and 4 Day forecast."
When you first open it, it will center on and show your current location (the AndyRoid biker) but you can drag it anyplace you wish..
(even up into Canada and Alaska).
At the default zoom level, the SAT view is hidden but if you zoom out the SAT view will get overlayed on the map.
Or, you can tap any of the "current temp/cloud/sun" icons (sun for day and moon for night) over any city and get the WIND, high/low temp forecast, Humidity and 4 Day forecast.
Dennis
.. it should look something like this:
Old 05-03-2013, 11:25 AM   #143
wingwing OP
Oddometer: 119
playing around with the new screen I realized that it's not just for U.S., Canada and Alaska.. it's actually for the entire world..
.. just zoom out..
Dennis
wwwfogbog.com
Old 07-19-2013, 08:00 AM   #144
wingwing OP
Oddometer: 119
I've gotten more than few requests for information so I'll update here..
(with software, I do hate using the word "new" since it's only relevant for a few hours, but in this case Google MAPS really is "new")
As of mid-July 2013
Android Google MAPS has been completely overhauled.
In terms of learning curve, it's almost like starting over again with a brand new app.
Spend an hour or so and it starts to make sense.
Some of it I like, some I don't.
"My Maps" and "Latitude" are gone along with a few other features I used often.
The good news is that Google MAPS is still 100% compatible with EMFB v5.23
So, if you never bothered to learn the old Google MAPS, you still don't have to learn the new one.
Just use EMFB to speak a destination and it will store and sort it and show you both a MAP and NAVIGATION route to it.
You can still use EMFB to speak a quick list of waypoints to create a custom route.
.. for EMFB, there is nothing new to learn or do with the new version of Google MAPS.
(The EMFB real time weather information is all my stuff so there have not been any changes there.)
regards,
Dennis
www.fogbog.com
Old 08-30-2013, 04:01 PM   #145
elron
Still Standing
Oddometer: 290
status?
Hi Dennis,
Just checking where things are at with your app. With the google changes and new android stuff popping up everywhere and almost everyday where does your app stand? what do you see in the near and slightly distant future re your app and android trends. My impressions are that android is going to make standard GPS use passe...is your app on that leading edge as you see it?
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, totally worn out and screaming "WOO-HOO, what a ride!!"
elron is offline   Reply With Quote
Old 09-14-2013, 07:06 PM   #146
drdubb
OFWG
drdubb's Avatar
Oddometer: 404
Can I say that I'm really pissed about the loss of the ability to load my maps onto my droid.
'06 DR650 - Suzuki
'71 SL 350 - Honda
Old 09-15-2013, 10:59 AM   #147
wingwing OP
Oddometer: 119
re status and pissed...
status:
5.23 will remain the latest release for the near future.
.. Google has made some changes to close the interface for my development system.. but I continue to make changes to the java side server scripts which is what you see in the end anyway.
.. I've recently added satellite and traffic overlays to the HOURLY AND 7 DAY FORCAST.
pissed:
if you purchased a new phone with the new maps you are screwed unless you root.. but, if you just upgraded to the new MAPS all you have to do is uninstall it.. the phone will revert to the old MAPS you like..
.. that's what I did.. I'm presently (since Labor Day) on a NE Colorado camping trip and really missed the terrain maps to avoid the floods..
.. Google should be shot for removing them.
Dennis
Old 10-25-2013, 10:31 AM   #148
Outwardbound
Oddometer: 688
Dennis
Do you still recommend the Nexus 7 (32gb) tablet for best compatibility ? The wife has ordered me to put a Christmas list together, and a tablet will be numero uno.
Outwardbound is offline   Reply With Quote
Old 10-25-2013, 01:21 PM   #149
wingwing OP
Oddometer: 119
Originally Posted by Outwardbound View Post
Dennis
.. I only own the Nexus 7 tablet.. so that is the only one I've tested it on and it works fine on that ..
Basically I just ported over the phone version so it looks exactly like it does on the phone except everything is REALLY large and easy to read.
one exception:
The SMS DND (Do Not Disturb) feature does not work because there is no 3G/4G connection and therefore no SMS application to intercept or respond to..
thanks for your support..
.. and if you've not already, PLEASE go to Google Play and give EMFB a good review and 5 star rating..
.. some joker with an ancient antique phone (original HTC) and running on T-Mobile out west and no clue how to use it gave it a bad rap and that is all people see now... some positive reviews sure would help me out.
thanks again,
Dennis
Times are GMT -7.   It's 01:28 AM.
