Old 03-08-2013, 02:19 PM   #3196
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Originally Posted by WindSailor View Post
Relocated my lights to use the original OEM aux light mounts (had to fabricate a piece to bolt to the original mount). This works tons better and looks better too.
I like it better now, however, you still need to crank up the engine hp a bit to overcome the wind resistance, personally it's a bit too much for me. I went from no lights to way too many lights (lights everywhere), back to only a set of 60s and that's it for me.
tallguy-09 is offline   Reply With Quote
Old 03-08-2013, 03:46 PM   #3197
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,742
Sanjoh, do you have wide beam lenses or prismatic lenses available for the 61 or 62? Id like to use them for close cornering lights.
Danjal is offline   Reply With Quote
Old 03-08-2013, 04:41 PM   #3198
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Model 30 light on Sale 25% off
Normally $60.00 each now $45.00
Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair) of Lights.
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Length: 70mm , Diameter 55mm
  • black durable coating
  • o-ring sealed housing
  • one meter wire lead
  • includes flat mount (stainless) mounting bracket
  • glass shatter resistant lens
  • Sold individually
The Model 44 or Model 60 will give you a wide beam.
Old 03-08-2013, 04:42 PM   #3199
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Model 60s and the new M64s on my F150. Can you spell daylight
Old 03-08-2013, 06:38 PM   #3200
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,742
All well and good there as I have a 60 already, I just need lower power cornering lights. The stock Dr650 stator wont support too much more draw on it.
Old 03-08-2013, 09:08 PM   #3201
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 769
This reminds me of body piercing. Not that there is anything wrong with that.
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 03-08-2013, 11:28 PM   #3202
Jazz62
Jazz62's Avatar
Oddometer: 1,011
Just for grins you've got to post some night shots with those blazing.
Jazz62 is offline   Reply With Quote
Old 03-09-2013, 05:39 PM   #3203
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
There's been no recent mention of the flashlight that sanjoh sells but it's become my nightly go to light. Love everything about it except that the switch comes apart if you change the battery via the tail cap. I just take the head off instead.
Highly recommended, ESP if you've ever spent real money on a flashlight. This sucker is almost free.
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-11-2013, 04:30 AM   #3204
Bearcat263
Bearcat263's Avatar
Oddometer: 113
haven't read all 200+ pgs but have a question anyway, why do you need a or want a dimmer on your lites don't you want them on full bright isn't that why your putting them on the bike to see what goes bump in the night so you don't. also other than a switch of some kind what else do you need with them? Thanks Mike
A bad day of hunting, fishing, or riding sure beats a good day of work.
2000 ZRX1100
2008 KLR650 sold
2012 KTM990
Bearcat263 is offline   Reply With Quote
Old 03-11-2013, 05:03 AM   #3205
RoundOz
Plenty of seasoning
Oddometer: 1,004
Dim: low beam
Bright: high beam
These lights are really dazzling for other road users if not controlled properly.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 03-11-2013, 09:38 AM   #3206
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
S
Thanks for the praise! Here is the M10 flashlight on a tree @ 250' with the light on high
All that for $33
Old 03-11-2013, 02:23 PM   #3207
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Full bright is blinding to oncoming traffic, so unless you want to be run over, dimming helps make the lights more traffic friendly while providing full power with a flip of your high beam switch.
Old 03-11-2013, 03:43 PM   #3208
Bearcat263
Bearcat263's Avatar
Oddometer: 113
I'm thinking of putting your Blk model 44's with M-30's or using
Model60's with the M-30's any suggestions or would these combo's
work together for up close and way out there thanks Mike
2000 ZRX1100
2008 KLR650 sold
2012 KTM990
Old 03-11-2013, 08:35 PM   #3209
ewagman
Oddometer: 29
I like the recessed look to the 60's, but what about cooling airflow? Is there a limit to how long can you run them at slow speed without overheating? Did you wire in a relay with 16 LEDs drawing current? Any radio interference? Those 64's are big in comparison aren't they! I'd love to see some nite shots on a long straightaway the 60's, the 64's and all on, and with the Ford lights for comparison.
ewagman is offline   Reply With Quote
Old 03-12-2013, 06:59 AM   #3210
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,064
Model 60 and 30 compliment each other very well, although most customers have found a pair of 60s to be awesome. Lots of lighting to the sides and plenty of distance.
Times are GMT -7.   It's 01:07 PM.
