Thread Tools Rating: Thread Rating: 60 votes, 5.00 average. Display Modes
Old 03-03-2013, 08:02 PM   #346
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,093
Ok here's my solution for a bracket to hold the brake line in place.
Started with some 1" strips of stainless steel.
And mounted up. It holds the brake line nice and secure and allows enough slack in the hose for the suspension at full drop and a full left turn.
And mounted to the caliper. (Ignore the extra washers on the bolt holding the bracket onto the caliper, I didn't have the correct length bolt on hand to mock it up :-).
This picture is at full right turn with the suspension at full bottom travel. I had to mount the brake hose where I did to get clearance for the spring. I used a piece of rubber hose and a clamp to secure the hose. The clamp is spread apart and one side of the clamp mounted on each side of the bolt hole, if the clamp is mounted on the back side only there isn't enough clearance for the spring.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 03-04-2013, 08:46 AM   #347
bobfab
bobfab's Avatar
Oddometer: 1,475
you my friend are quite the artisan! Looks awesome!!
Whats the target completion date for the project?
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 03-04-2013, 11:12 AM   #348
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,585
Originally Posted by koncha View Post
This thread is an inspiration for the abolition of half-assedness.
Well there goes many of my projects.
How much higher will this end up being compared to stock?
Is the previous owner local? I wonder what he/ she would think of this machine once it is finished.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 03-05-2013, 07:49 PM   #349
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
Thanks, I'm shooting for May but we'll see. Lots of small items to go still.
Hodakaguy
Old 03-05-2013, 07:50 PM   #350
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
It will be about 3" higher than stock with the lift and taller tires. Yeah the original owner is local, I'll be driving it over there for her to look at once completed :-)
Hodakaguy
Old 03-05-2013, 08:49 PM   #351
ian408
Oh?
ian408's Avatar
Oddometer: 14,517
Impressed with your progress so far. Looks great!
ian408 is offline   Reply With Quote
Old 03-06-2013, 02:06 PM   #352
rider1150gsadv
Fl Keys Fishing Guide
rider1150gsadv's Avatar
Oddometer: 5,914
Simply awesome and the ONLY way to do a rebuild!
rider1150gsadv is offline   Reply With Quote
Old 03-08-2013, 04:47 PM   #353
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
Time to get the seat installed again.
Pulling out the old 3/8" cork material. A small leak in the rear heater had deteriorated them. Good time to replace it while its apart.
Laying down some Dynamat sound deadening material in the low spots before re-installing the new boards.
Got a good deal on some 3/8" finished oak plywood, here I'm replicating the old cork material.
That's better.
My friend Mike helping out, here he's removed the old propane tank. I'll be replacing it with the new unit that holds 10% more.
Had to do a little trim work to get the new tank to fit, it was off by 1/8". I think I'm going to undercoat the ends on the tank as well as the bottom gaurd/bracket to keep them from getting chipped up from rocks and rusting.
More progress tomorrow.
Hodakaguy
Hodakaguy screwed with this post 03-10-2013 at 07:48 AM
Old 03-09-2013, 04:41 AM   #354
kobudo28
kobudo28's Avatar
Oddometer: 5,888
NICE!!!!!!!!!!!
kobudo28 is offline   Reply With Quote
Old 03-09-2013, 10:46 AM   #355
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,393
Good work. I'd let you work on any of my projects.
jesusgatos is offline   Reply With Quote
Old 03-09-2013, 07:22 PM   #356
Robb Mc
what?
Robb Mc's Avatar
Oddometer: 1,598
Ooh. Where'd you find that propane tank? I'm looking for something similar.
Robb Mc is offline   Reply With Quote
Old 03-09-2013, 07:29 PM   #357
Robb Mc
what?
Robb Mc's Avatar
Oddometer: 1,598
Never mind.. I remembered gowesty and took a look there...
Old 03-09-2013, 07:48 PM   #358
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,781
Hodakaguy
Be careful with dissimilar materials on a fuel cell. Knowing you it will be well grounded but could tell you stories about unintended capacitive effects.g
Mr. Fisherman is offline   Reply With Quote
Old 03-09-2013, 08:19 PM   #359
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
Wish we lived closer, would be fun to help out in designing parts, projects etc!
Hodakaguy
Old 03-09-2013, 08:21 PM   #360
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,093
The tank is steel so it shouldn't have any dissimilar metal issues :-)
Hodakaguy
Thread Tools
Times are GMT -7.   It's 09:31 AM.
