Old 02-06-2013, 06:19 AM   #1
jesse v OP
Motorcyclist
jesse v's Avatar
Oddometer: 205
distribution block (Canyon Chasers)
Hi all,
I've been reading up on this tutorial on CanyonChasers.net to learn how to install a distribution block for electric accessories. (It's worth noting I really don't know much about electronics, but I can solder, attach crimp connectors, change pickups on my guitars, etc.)
I was about to begin my installation, but then realized that my accessories (Tourmaster heated jacket, Stebel Nautilus horn, and [soon] heat grips) have 0-ring connectors designed for battery terminals that are too large for my radio shak distribution block. (The rings don't fit between the black walls.)
The Canyon Chasers tutorial doesn't address this issue. Should I look for a larger distribution block? Or should I cut the ends off my accessories and attach smaller prong connectors?
THanks!
Jesse
everybody lies
My band: June Embers
jesse v is offline   Reply With Quote
Old 02-06-2013, 06:47 AM   #2
JimVonBaden
"Cool" Aid!
Oddometer: 53,263
Cut the ends and add new ring connectors of the appropriate size.
Jim
Old 02-06-2013, 06:54 AM   #3
jesse v OP
Motorcyclist
jesse v's Avatar
Oddometer: 205
Thanks Jim. I figured this was the case, but I'm a little intimidated by electronic gizmo-wizardry-black-magic.
everybody lies
Old 02-07-2013, 02:58 PM   #4
jesse v OP
Motorcyclist
jesse v's Avatar
Oddometer: 205
Welp... I hooked everything up today and there's no power coming from the dis. block. The relay makes a "click" sound when I turn the key on, so I assume that my soldering job into the running light is good. Tomorrow I'll check all the other connections.
everybody lies
jesse v screwed with this post 02-22-2013 at 01:03 PM
Old 02-08-2013, 11:06 AM   #5
Rocket Scientist
Oddometer: 24
I picked up a 6 fuse distribution block along with an 8 terminal block (for grounds) from Auto Zone. Im cleaning up the wiring (wirenuts & alot of 3 way splices) & putting it behind the headlight on my DR. Ive got a battery pack back-up that Im verifing this weekend. My best guess is that the 12v lead from the stator (old headlight power) needs to go to the switched side of the relay (on) allowing the battery supplied constant 12v to go to my block. That way nothing is backfeeding into the stator feed when the bike is off (not running). Trying to verify all this over the coming weekend.
Rocket Scientist is offline   Reply With Quote
Old 02-22-2013, 01:03 PM   #6
jesse v OP
Motorcyclist
jesse v's Avatar
Oddometer: 205
A fellow forumite on the svportal.com pointed out my mistake... I had my jumper positioned incorrectly so that the block was not divided into positive and negative sides, so I blew the fuse every time I turned the key on. got it fixed now; works like a charm! Grip heaters, heated jacket liner, and my stebel horn are all connected to it. My PCIII was installed by the previous owner by being tapped into some other power source and grounded to the battery, so I'm just going to leave that as is.
everybody lies
Old 03-02-2013, 02:45 PM   #7
seniorasi
Oddometer: 816
Any chance you can upload some photos?
seniorasi is offline   Reply With Quote
Old 03-02-2013, 05:21 PM   #8
aussie_king_mick
Oddometer: 167
Thumb
I recommend that you have a look at these three website links:
http://www.cyclenutz.com/Fuzeblock-Fuse-Block-FZ-1_p_92.html
http://www.twistedthrottle.com/powerhub-fuse-block-master-ground-block-and-wiring-harness-for-motorcycles-by-twisted-throttle
http://www.cyclenutz.com/Fuse-Block-and-Relay-Installation_df_49.html
aussie_king_mick is offline   Reply With Quote
Old 03-09-2013, 04:22 PM   #9
jesse v OP
Motorcyclist
jesse v's Avatar
Oddometer: 205
yes sir:
The relay tucks nicely behind the battery:
Symtec Grip Heaters, also a la Canyon Chasers. Tip: Wrap the left side of your handlebar with silicon tape ("Rescue Tape") for best heat transfer, especially if you're using aluminum bars like me:
everybody lies
Old 03-09-2013, 04:24 PM   #10
jesse v OP
Motorcyclist
jesse v's Avatar
Oddometer: 205
This is the WRONG way that I initially tried to do it:
It's seems so obvious now, but this was my first venture into electrical work. I needed to cut the jumper in half, and put the 2 halves "diagonal" from one another.
everybody lies
Times are GMT -7.   It's 02:49 PM.
