Old 02-22-2013, 11:37 AM   #2221
Dranrab Luap
E-Tarded
Dranrab Luap's Avatar
Oddometer: 25,714
Originally Posted by madeouttaglass View Post
An inmate PMed me asking about the Showchrome heated grips I put on my bike a year or two ago. Here's a couple pics:
I always estimated my FJR grips were closer to 12 inches wide. I might have to start reconsidering some things.
Marcel Marceau " "
Dranrab Luap is offline   Reply With Quote
Old 03-01-2013, 12:31 PM   #2222
srelegante
srelegante
Oddometer: 61
2003 FJR teardown
Just picked up a lightly used, 2003 FJR, and going to tear into it this weekend. She has 20k miles.
Aside from my list-what else should be attended to while she is apart?
Already planned:
1) Fork rebuild-springs/seals/oil
2) All fluids changed
I understand one of the wires comes loose sometimes?
SE
srelegante is offline   Reply With Quote
Old 03-01-2013, 12:50 PM   #2223
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: Bristol Hills in the Fingerlakes region of NY
Oddometer: 2,190
Already planned:
SE
Does it rattle at idle? Cam chain tensioners are common. I just put one in my '06. It started to rattle at about 20K. Yamaha has had two upgrades on this part.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
madeouttaglass is offline   Reply With Quote
Old 03-01-2013, 12:51 PM   #2224
harfooz
FJR1300 / FLHX
harfooz's Avatar
Oddometer: 263
Already planned:
SE
Lube the splines
http://www.fjrtech.net/getdbitem.cfm?item=36
Check the air filter
http://www.fjrtech.net/getdbitem.cfm?item=2
Swap out the plugs for some iridiums
http://www.fjrtech.net/getdbitem.cfm?item=20
There may be some other specific items that need attention, but those immediately come to mind.
Hope this helps!
'fooz
'05 Yamaha FJR1300
'09 Harley-Davidson FLHX Street Glide
harfooz is offline   Reply With Quote
Old 03-01-2013, 05:32 PM   #2225
srelegante
srelegante
Oddometer: 61
Thanks fellas!
Just got started wrenching on it tonite.
Someone was living in the airbox, dog food and all.
She will be sweet when I get her dialed in.
The splines was not something I had thought of, will let you know what I find.
Q: There is an aluminum (?) foil attached to the bottom of the tank-is that the heat shield retrofit I have heard of?
SE
Old 03-01-2013, 09:16 PM   #2226
markjenn
Oddometer: 9,698
As I recall, there is a foil-lined heat shield on the bottom of the tank on all models. If it looks "factory" (substantial and well-molded to the bottom of the tank), it's probably stock; otherwise it might be something extra someone has added.
There was no "heat shield retrofit" from Yamaha.... just the major revisions done in 2006 to improve heat control and airflow management (that don't retrofit to the Gen 1 bikes). There are a lot of homebrew solutions out there though, especially for the Gen 1 bikes. Most were centered on re-directing the airflow through left side of the fairing and reducing the blast furnace effect on one's left calf.
BTW, if you're lubing the splines where the wheel attaches to the final drive, it won't hurt anything, but its also completely unnecessary. It is a good idea to lube the splines on both ends of the drive shaft now and then, but if you get in there every 2nd or 3rd tire change, you're doing fine. I think a lot of BMW paranoia infects FJR owners about spline lubing - in reality, there have been almost no issues with the FJR's splines.
- Mark
markjenn screwed with this post 03-01-2013 at 09:21 PM
Old 03-02-2013, 05:48 AM   #2227
harfooz
FJR1300 / FLHX
harfooz's Avatar
Oddometer: 263
SE
I've seen some photos (can't find them at the moment though) of FJR owners who ziptie hardware cloth or screen door material over the air box opening to keep the mice out. If you don't have cats where you live, and do have mice, that mesh cover should prevent them from setting up shop in your airbox.
While you have the tank up, cut some firewall material to shape and put it under the tank to help keep the heat down. I have some material that I picked up from another FJR owner, but have never bothered to put it under the tank on my '05. I ride with full gear, and ride in the winter, so the heat doesn't bother me. When it's below freezing outside, I would welcome some additional heat! In the summer, keep the tank from getting too low, and the heat may not be an issue for you either. When it's above 100F, and the tank is near empty...that's when I've noticed the heat! So while you have the tank up, it's a good time to put a heat blanket under there.
Google for "cromeit heat fix" to see some of the other heat fixes that are available to control the heat coming off the engine. People have varying sensitivity to a bike's heat. For me, it's a non-issue. I wear gear and that's an effective barrier against the engine heat in the summer and the cold in the winter. I also have an air-cooled v-twin. Let me tell ya: in the 100F+ heat, and after we sit at a few stoplights in traffic, I'm reminded about how nice the FJR is!
There is one more change I did to mine that I wish I had done a long time ago: Install the V-Strom handguards! I finally did that when I had a discount card at one of the mailorder places, and I really like that mod a lot, and would highly recommend that to all FJR owners.
Be sure to Loc-tite (blue 242) the screws for the locks on the saddlebags. I forgot about that in my earlier post. They are security torx style screws and they fall out. Mine got really loose, and I got lucky noticing before they fell all the way out. This is covered in the Bin-o-facts at the FJR forum. I replaced mine with standard (non-security torx) screws and loc-tited them in place.
Hope this helps,
'fooz
'05 Yamaha FJR1300
Old 03-03-2013, 05:54 AM   #2228
B.E. Coyote
(Super-Genius)
B.E. Coyote's Avatar
Oddometer: 4,637
Anybody ever make pannier racks for aftermarket panniers on a Gen2 ? I'd love to put e-41s on my bike.
Apparently there is hard to find givi pannier racks for Gen1 but not Gen2.
B.E. Coyote is offline   Reply With Quote
Old 03-04-2013, 04:38 PM   #2229
andoulli
CAJUN
andoulli's Avatar
Oddometer: 1,649
New AE
I picked this up in Naples on Friday, and rode it home 900 miles to Baton Rouge on Saturday and Sunday. It's a 2007 AE. Loving it big time, two left hand surgeries had me looking for relief and the AE is just the ticket.
andoulli is offline   Reply With Quote
Old 03-04-2013, 04:54 PM   #2230
Rider
Moderator Emeritus
Rider's Avatar
Oddometer: 2,102
Very nice!
I can see why those surgeries would welcome a break from squeezing a clutch lever. I got caught in a horrible traffic jam back in June in West Virginia and wished I had the AE model.
2012 FJR1300 - In Search Of Fast Sweepers
My Voice
Rider is offline   Reply With Quote
Old 03-04-2013, 07:18 PM   #2231
WVrefugee
WVrefugee's Avatar
Oddometer: 9
Ae
Sweet ride for sure! Best money I ever spent was on my 2010 AE!!
Enjoy!
WVrefugee is offline   Reply With Quote
Old 03-08-2013, 05:49 PM   #2232
srelegante
srelegante
Oddometer: 61
Update
Getting the 2003 sorted-picked it up last week.
Changed the oil, air filter, front tire and upgraded fork springs.
Q: It appears the cam chain tensioner is failing-I am hearing intermittent flop. If I cannot locate one tomorrow, is it safe for a ride to Fla? Sounds fine at anything other than idle.
Q: I just got off a 2002 Triumph Trophy which fit me ergonomically perfect. I am getting some lower back pain and between the shoulder pain on the FJR. The prior owner put some short risers on it-I suspect that is part of the problem. I also suspect the sweep of the bars is a bit more than I like. What is a bloke to do?
Thanks guys!
SE
Old 03-08-2013, 05:56 PM   #2233
B.E. Coyote
(Super-Genius)
Oddometer: 4,637
Motorcycle Larry top plate fixed me right up.
Old 03-08-2013, 08:15 PM   #2234
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,673
Thanks guys!
SE
may want to check out this product
http://www.mv-motorrad.de/lshop,show...440-03,1,,.htm
and this thread for reviews and install
http://www.fjrforum.com/forum//index...rad-bar-riser/
11 Husqvarna TE630
11 Husqvarna SM630
08 Husqvarna TE510- sold
10 Yamaha FJR 1300
Fast1 is offline   Reply With Quote
Old 03-09-2013, 07:38 PM   #2235
eatcorn1625
eatcorn1625's Avatar
Oddometer: 15
Laugh New to the FJR...
I bought an 08 with 33k in May.
http://3.bp.blogspot.com/-ohwcfGBrx4.../s1600/003.JPG
It now has over 43k, I love it!
JP
“It is good to have an end to journey toward; but it is the journey that matters, in the end.”
-Ernest Hemingway
eatcorn1625 is offline   Reply With Quote
Times are GMT -7.   It's 01:31 PM.
