Old 01-16-2013, 03:24 AM   #451
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Another
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 01-20-2013, 06:23 PM   #452
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Just found another pic of it, a bit arty
Airhead Tragic
Old 02-11-2013, 02:31 PM   #453
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Time for some more work on Yajuu
I need to do something serious about the front brakes on this bike
Current front end is XR/XL 250 Disc brake set up. 38mm forks Honda XR-250R (84-85)
Question is, what will fit on here Disc wise and calliper wise?
I can fabricate an adapter bracket for a calliper if needed.
Or what else runs 38mm forks, that would be suitable for a swap over?
Looking at the thread below, not much on offer in 38's
http://www.advrider.com/forums/showp...&postcount=198
Airhead Tragic
Old 02-11-2013, 08:28 PM   #454
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Disc is gonna be a bit trial and error. 4 bolt rotor, I think newer Kawasaki KXf bikes are 4 bolt. not sure if it is the same pattern and bolt centerline though.
Caliper wise, about ANYTHING newer will work better but you will need to make an offset for the bigger rotor. The master cylinder may also be an issue though, getting the right MC bore and caliper piston size ratio is critical.
Rotor diameter is probably the biggest issue, that thing is a tea cup saucer, you need a dinner plate.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 02-11-2013, 08:36 PM   #455
doug s.
Oddometer: 1,354
this one indicates it will fit '84-'04, but the link to the bracket is iffy, re: fitment - likely the same rotor w/different caliper for later years?
270 mm rotor:
http://www.ebay.com/itm/271017502421
bracket:
http://www.ebay.com/itm/271019077275
320mm rotor bracket (rotor will fit, but not the bracket?):
http://www.ebay.com/itm/320974991593
doug s.
doug s. is offline   Reply With Quote
Old 02-15-2013, 07:41 PM   #456
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Pre 2008 KLR650?
NordieBoy is offline   Reply With Quote
Old 03-10-2013, 08:54 PM   #457
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Well I just went out, after having the heli-coil inserted to secure Number 4 spark plug, just gave it a kick in the guts
Airhead Tragic
Old 03-10-2013, 10:43 PM   #458
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
That, is the coolest sounding starter in the history of the world.
Made by Nippon-Denso-Hyena?
Old 03-11-2013, 08:12 PM   #459
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Just fitted up an XR600 front calliper, brake ine and master cylinder. They bolted straight on. I now have front brakes that work
Airhead Tragic
Old 04-02-2013, 01:19 AM   #460
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Some Helmet Cam footage from my GoPro from the 2013 Scrapheap Adventure Ride
Airhead Tragic
Old 04-02-2013, 02:38 AM   #461
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
A few from the weekend at the Scrapheap Adventure Ride
Last Photo - Taken by James Manson CD Media
Airhead Tragic
Old 04-06-2013, 07:58 PM   #462
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,735
She seems really puzzled by that bike. Great stuff Pezz
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 04-07-2013, 03:32 PM   #463
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
That was a K100 built by Buckscreek for Scrapheap. Last year it was a sidecar, which had a little mishap on the way home, necessitating a few dyas in Hospital for the rider and passenger and a full rebuild for 2013.
Previously
2011
2012
Big favourite with the kids, my Molly at the back and my Grace beside her with the glasses and cap.
Airhead Tragic
Old 05-23-2013, 11:07 PM   #464
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
I was just sent this pic of me on my XR460/4 at Srcapheap 2013
Airhead Tragic
Old 05-28-2013, 11:38 PM   #465
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,835
Well after being asked how much this bike weighed, I went out and bought a set of $8.00 bathroom scales from K-Mart.
Front axle is 82kg and rear is 94kg making total mass of 176kg (388lbs)
I reckon I could lose a few kilograms with lighter rear guard, tail light and rack.
Airhead Tragic
Times are GMT -7.   It's 01:35 AM.
