Old 03-10-2013, 12:07 PM   #2251
vnp514
Oddometer: 630
Originally Posted by RideFreak View Post
If you read some of the posts from the GoPro forums they aren't having good luck using the GoPro in record mode while running off the USB cable. It's fine for playback running off USB. I'm going to sacrifice (take apart) a battery so I can connect wires to it internally, leave the metal back off the cam and run the wires out the back of the openings in the non-waterproof case cover, whan I can get around to it. Too many projects, not enough time.
Here's a recent ride shot mostly with the H3 @ 1080/60, still working on the settings to get rid of the jello effect from stabilization.
I don't know anything about how to produce video(I have a hard enough time with a P&S camera-) but this one was great! What do you mean by "Jello Effect"?
Pete
vnp514 is offline   Reply With Quote
Old 03-11-2013, 06:29 PM   #2252
The_Commander
The Man.
The_Commander's Avatar
Oddometer: 6,156
Indypup FTW
The_Commander is offline   Reply With Quote
Old 03-11-2013, 10:22 PM   #2253
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,977
Pete
Thanks,
If you look close, ocassionally the picture looks like the screen is waving somewhat. That's due to the stabilization software I'm using when editing. There's allot of stabilization adjustment settings, I need to find the best ones to reduce the effect.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is online now   Reply With Quote
Old 03-14-2013, 01:29 PM   #2254
team ftb
Befuddled Adventurer
Oddometer: 1,666
Awesome Vid Ridefreak!! Love the singeltrack stuff and makes my busted arm yearn even more for it.
I was thinking of charging the Go Pro via USB and saw your comments. Why prey tell does it seem to function well on Playback but not record do ya know? Have your heard if this is an issue with all Go Pro's or just the Hero model (I just have a HD Go Pro)?
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Old 03-15-2013, 05:04 PM   #2255
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,977
The prev gen heros (Hero HD) charge fine off usb and give a solid 2hrs per battery. It's the new ones that are having the USB issues with charging from a computer and trying to film when running off USB.
Chris
Old 03-15-2013, 09:29 PM   #2256
team ftb
Oddometer: 1,666
A big tip of the hat for your answer, thank you.
Cheers,
Team FTB
Old 03-17-2013, 07:29 AM   #2257
scooterGdawg
Oddometer: 531
What about charging off the bike? Any issues?
http://myscootlife.blogspot.com
scooterGdawg is offline   Reply With Quote
Old 03-17-2013, 08:39 AM   #2258
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,324
n00b question. I've got a new Hero2. This one charge OK by USB? And I've been planning to go with a case mod and leave it plugged in to USB while riding from an onboard port. Any issues?
Thanks.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is online now   Reply With Quote
Old 03-17-2013, 08:43 AM   #2259
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,977
Talking
If you mean from the bike via USB that's a good question. There are issues charging issues, not recommended from a computer's USB port which is ~.5A, 1A seems to be the preferred outpt to fully charge the batteries, many folks are using an Apple IPOD wall charger (120V to USB @ 1A).
If I was going to charge off the bike's electrical system (or any vehicle) I'd run a wasabi charger that has the 12VDC/120VAC inputs, it's dedicated and frees up the cam while charging, available at Amazon.
Chris
Old 03-17-2013, 09:13 AM   #2260
scooterGdawg
Oddometer: 531
WELL....my cables came yesterday...to charge while operating. ..so I can report back... hereo 3
Old 03-17-2013, 09:59 AM   #2261
scooterGdawg
Oddometer: 531
i just tested two hero 3's recording while charging from the bike...... no issues....
what exactly am i looking for issue wise?
Old 03-17-2013, 01:47 PM   #2262
team ftb
Oddometer: 1,666
When charging the Go Pro off my dirt bikes battery what cables/setups have people found work well and are compact and convenient to ride on the enduro dirt bikes?
Cheers,
Team FTB
Old 03-17-2013, 07:24 PM   #2263
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,977
From what I've read and supposedly GP confirmed it (no first hand knowledge) when the cams are powered from USB when filming they shut of for no apparent reason. Duh! mine shuts off for no apparent reason running on the battery
I discovered that one of the 4 batteries I bought when the cam was purchased is bad, it charged all night and never went over 1 bar on the display. 3 of the 4 batteries have already been replaced by GP for causing intermittent shutoffs and short record times. I'm starting to wonder if the issues are all related to the battery.
Chris
Old 03-17-2013, 07:36 PM   #2264
scooterGdawg
Oddometer: 531
I only recorded for a few mins.... I will do a longer test to verify
My big problem is the damn remote will drop a cam..so next time I hit the power button, two come on, and one goes off...
Old 03-22-2013, 04:18 AM   #2265
tomfarr
Oddometer: 21
Originally Posted by Motoriley View Post
I use the adhesive mounts on my helmet and they stick amazing. For the bike nothing beats a RAM mount and a Manfrotto Nano clamp. You can clamp the camera to a crash bar, a handlebar or pretty much anywhere. You move the camera in seconds and it does not fall off. I've had mine on multiple bikes in many crashes and it is fine. It will give in an impact which is also nice.
I just bought one of these Manfrotto Nanos on Amazon for $39.95...free ship.
I did a little snooping around just now and found it for $29.88 - $33.87 w/ship.
http://www.bhphotovideo.com/bnh/cont...=REG&A=details
I guess the $6 is nothing to get worked up about.
I love this thread. I just bought my Hero Silver on Tuesday, and I immediately Googled "GoPro for dummies" - it brought me here.
I'll be using this on my CBR250R and I plan to see some dirt roads in May down in Oklahoma. No single track though. :)
"life's a bitch, and then you reincarnate" ~ me
tomfarr is offline   Reply With Quote
Times are GMT -7.   It's 09:55 AM.
