Go Back   ADVrider > Riding > Regional Forums > Northeast - Greater Flugistan and home of the carpet baggers.
Old 01-29-2013, 08:07 PM   #46
BificusRex
BificusRex's Avatar
Oddometer: 252
Originally Posted by V8 View Post
keep that NWC tor going blitchfield
Haha.. yeah I've been slacking on my goal for the TOR, tomorrow night looks like fun 43 degrees, heavy rain and wind.
So whats the plan of action for that DRZ? Blow off work, get the plate and ride the shit out of it while the temps are up??
BificusRex is offline   Reply With Quote
Old 02-14-2013, 08:57 PM   #47
bmwpowere36m3 OP
bmwpowere36m3's Avatar
Oddometer: 90
I won't be riding the bike till it gets warmer... I know vag For now I'm doing some maintenance on the bike.
First, stripped all the plastics, subframe and swingarm and did some major cleaning... a ton of mud and dirt in every crevice. Noticed the left side mount (on main frame) for the subframe was cracked and barely hanging on. So I removed it, cleaned up the welds and re-welded it in place.
Second, went to re-grease the swingarm and linkage and found this mess:
Looks like it wasn't taken care of properly by the PO. Essentially all the bearings were rusted and disintegrated to dust. The bearing bores in both the linkage and swingarm were worn/gouged due to bearing failure. So I got a replacement used swingarm and linkage with low miles and in great condition. Took the replacement parts, stripped/cleaned and lubricated them. Also cleaned and lubricated the spherical bearing in the rear shock and re-charged the nitrogen.
Third, the original chain guide/slider/rollers were beat so I ordered a replacement set off eBay, (Hotfootmoto). Quality and fitment are okay (we'll see how long they last). NOTE: the lower chain roller bearings didn't have any grease, so I packed them.
Finally, cleaned the FCR-MX carb (not finished) and received some nice 7 mm ID fuel line (made in Italy, seller valtermotousa) off eBay.
Still have a few things to do...
bmwpowere36m3 is offline   Reply With Quote
Old 02-15-2013, 04:12 AM   #48
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,972
[sarcasm] Huh...all the Japanese bike fanboys here on ADVRider insist that Japanese bikes are maintenance free [/sarcasm]
Congrats on your new (to you) bike. Enjoy
bobnoxious67 is offline   Reply With Quote
Old 02-15-2013, 07:00 AM   #49
bmwpowere36m3 OP
Oddometer: 90
Originally Posted by bobnoxious67 View Post
[sarcasm] huh...all the japanese bike fanboys here on advrider insist that japanese bikes are maintenance free [/sarcasm]
congrats on your new (to you) bike. Enjoy
Old 02-15-2013, 02:45 PM   #50
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,945
Originally Posted by bmwpowere36m3 View Post
Also cleaned and lubricated the spherical bearing in the rear shock......
Does that come apart.....or some kind of factory press in job?
Hurricane Bob is offline   Reply With Quote
Old 02-15-2013, 05:24 PM   #51
bmwpowere36m3 OP
Oddometer: 90
Yea its pressed in, but you could removed the seals, snap ring and press it out. I just sprayed it with brake cleaner (it was pretty clean) and then sprayed some Wurth HHS-2000 into it.
Old 03-14-2013, 09:06 PM   #52
bmwpowere36m3 OP
Oddometer: 90
Been catching up on some needed maintenance... also recently purchased a house. So finding a work/life/house/bike balance has been difficult to say the least
Day after I got it:
Started taking it apart:
Nice surprise:
Fixed:
On the bike:
Cleaned & Serviced:
Re-laced:
Started putting it back together:
  • Bought it in January
  • Cleaned it fairly thoroughly of dirt/salt/mud
  • Replaced and serviced swingarm & linkage
  • Installed new chain rollers/slider/guide
  • Welded one of the subframe mounts
  • Cleaned & serviced the carb
  • Re-laced the rear wheel & balanced the tire
  • Installed a new air filter
  • Checked valve clearances
  • Loctite'd the front sprocket
Still have a few things to do... and that'll be all for the pre-season maintenance!
Old 03-15-2013, 05:17 AM   #53
Happy Seal
Happy Seal's Avatar
Oddometer: 2,538
Check Thumpertalk.com and go into mods sticky. I would do Eddies' o-ring mod on the carb, all loctite fixes, And those FCR's are famous for pulling water up from puddles into your carb during water crossings causing a stall in the middle of the puddle. There are one way vent kits or mods to rerun the vent hoses on the carb. I work out of Milford and live in Middlsex county. Welcome aboard!
Don't forget ultra heavy duty tubes for this rocky NE terrain.
with his videos I've been able to crash into trees even faster than before. ( Darius re Shane Watts)
Happy Seal is offline   Reply With Quote
Old 03-15-2013, 05:39 AM   #54
bmwpowere36m3 OP
Oddometer: 90
I'm a member on TT and have read through those stickies. I took apart and cleaned the FCR and when I reassembled it realized the AP would only squirt for about 0.5 seconds and only a couple feet out. I ended up having to re-clean the AP nozzle, install an AP spring ($5 cycle gear special) and grind down the AP diagram. Now its at 1 sec and just misses the slide.
I'm keeping the vent hose routing just the way it was before, all the hoses go down near the linkage. I will at one point reroute a set of them up either under the tank or seat. Right now I'm just trying to get the bike working 100% again and then I'll dick around with it once I start really using it.
I am planning on doing the rest of the loctite fixes though (starter clutch/stator/counter-balancer/primary gear).
Good to see a fellow rider in the area.
bmwpowere36m3 screwed with this post 03-15-2013 at 05:44 AM
Old 03-15-2013, 10:36 AM   #55
Happy Seal
Happy Seal's Avatar
Oddometer: 2,538
Be careful if your riding local, they put cops over there by the river in the state land quite a bit, one of our guys got a ticket last year!
Old 05-10-2013, 06:56 PM   #56
bmwpowere36m3 OP
Oddometer: 90
Took myself & the DRZ "off-road" for the first time... Thomaston Dam, it was good fun and a heluva work out getting the "pig" around that rocky single-track.
Times are GMT -7.   It's 10:33 PM.
