Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 03-06-2013, 04:12 PM   #1711
ducnut
Oddometer: 3,320
Originally Posted by markbvt View Post
It's been well-established that the sound is the stepper motor, which actuates a lever that resets the idle. You can actually watch it in action if you know where to look
You're absolutely correct.
I pulled the tank back, on my 1050, today. Cycled the key, started the bike, and whatnot. The aforementioned SAI solenoid makes some noise, but, the stepper motor is definitely the "faxing" noise. What's weird is that it makes a bunch of racket, but, doesn't move the whole time it's sending. Mystery solved, again. I shall bow down to Mark.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 03-07-2013, 06:50 AM   #1712
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,744
Haha -- don't bow down to me, I learned this from other people in the main Tiger 800 thread. Rob Dirt was one of the early investigators of this issue. I just put other people's findings into practice when I had the issue myself on the Trans-Labrador Highway.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 03-07-2013, 11:48 AM   #1713
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,208
Originally Posted by Chinookmark View Post
Just throwing this out there for the sake of discussion...
Every other bike on the planet just has an idle adjustment screw. No stepper motor. Has anyone considered removing the stepper motor and installing a traditional idle stop?
I know it would lose that cool anti-stall feature, but it would eliminate all the seized stepper motor problems.
Again, I'm not saying the stepper motor is so bad it needs to be removed. Just proposing a "what if" question.
AFAIK, the Tigger is not the only bike with a stepper motor - pretty sure it's standard now on FI bikes isn't it ?
Someone did come out with a manual idle adjuster for the 675 that I think should fit ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 03-07-2013, 12:27 PM   #1714
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
It comes as part of the 675 race kit.
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 03-08-2013, 07:04 AM   #1715
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,606
Doesn't the stepper motor also keep the throttle bodies from slamming shut when the throttle is released from high RPM's, which can cause the motor to stall? (thus causing rear end to lock, slide, crash, etc)
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 03-08-2013, 07:44 AM   #1716
Mercury264
Mercury264's Avatar
Oddometer: 22,208
That is very interesting. A friend of mine with a Triumph Sprint is experiencing an issue where when he lets of the throttle, the revs don't die down immediately and it takes a second or 2 for the revs to drop down. I wonder if the stepper motor is causing his issue - I thought it was more likely sticking cables or something but sounds like it could be the stepper.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-08-2013, 07:46 AM   #1717
Mercury264
Mercury264's Avatar
Oddometer: 22,208
I thought a third-party came out with a kit also ?
Anyway, they are out there.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-08-2013, 08:25 AM   #1718
RED05
Are we there yet?
RED05's Avatar
Oddometer: 151
Could be tight cables on the throttle side, has he zip tied them to tight or changed his bar profile?
530EXC - 800XC
RED05 is offline   Reply With Quote
Old 03-09-2013, 12:29 AM   #1719
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 295
That's the ECU.
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 03-15-2013, 01:31 PM   #1720
RED05
Are we there yet?
RED05's Avatar
Oddometer: 151
ABS shows SIA ???
ABS won't turn off - just shows SIA - has anyone had this happen? And is everyone turning their ABS off when off road? Last year I always turned it off without an issue.
530EXC - 800XC
Old 03-15-2013, 02:56 PM   #1721
bross
Where we riding to?
bross's Avatar
Oddometer: 4,602
Nope, never turn mine off. Even on a pretty tough trail with lots of steep ascents and descents.
Old 03-16-2013, 09:18 AM   #1722
McKay
McKay's Avatar
Oddometer: 931
I find I leave mine on too
Jeff
McKay is offline   Reply With Quote
Old 03-16-2013, 02:38 PM   #1723
Mercury264
Mercury264's Avatar
Oddometer: 22,208
I honestly think that ABS is one of those things that folks like to talk a lot about but in reality, there's very very few would benefit from turning it off....it just makes them look cooler if they say they need to
Personally, I have never once considered using the rear brake to help me get round a corner or whatever. On my Husky ? Sure, on the Tigger ? Not once.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 03-16-2013, 03:18 PM   #1724
andykeck
Oddometer: 106
For what it's worth, SIA is the mileage til next service menu page. I suspect your sequence of button presses is wrong and you end up toggling past the ABS menu.
andykeck is offline   Reply With Quote
Old 03-16-2013, 04:29 PM   #1725
RED05
Are we there yet?
RED05's Avatar
Oddometer: 151
Just had it in to the dealer and they needed to add the software from when they replaced the console last fall.
530EXC - 800XC
Times are GMT -7.   It's 09:03 AM.
