Old 01-22-2013, 03:15 PM   #1
Afry OP
Why hike?
Afry's Avatar
Oddometer: 611
Aeroquip fuel line project
After installing the rear fuel tank on an SE I don't feel comfortable with the rubber fuel line being exposed and am thinking of replacing all the lines and fittings with Aeroquip lines and quick disconnect fittings. Hopefully making it easier to remove the tank as well.
Before I go down this road has anyone else done this or have any tips?
KTM 950 SE
Yamaha TDR250
CRF450 flat tracker
Get on with riding or get on with dying - one or the other
Afry screwed with this post 04-02-2013 at 10:11 AM
Afry is offline   Reply With Quote
Old 01-22-2013, 04:11 PM   #2
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,407
Completely unnecessary... but if you must, avoid the SS hose at all costs. Opt for their Kevlar product.
I think settling for a quality Gates FI hose will serve you well.
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 01-22-2013, 04:29 PM   #3
DuctTape
Oddometer: 351
Due to ethanol blends and other crap being put in the fuel I've been putting these on all my toys. http://www.gates.com/brochure.cfm?br...cation_id=5348
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 01-23-2013, 04:55 AM   #4
DeepInIt
DeepInIt's Avatar
Oddometer: 1,368
I Think Replacing The Hoses Is Overkill But Hey, While Your At It. The Quick Disconnect Is Useful Depending On How Your Tank Is Attached but more so for removing the front tank than your aux. (caps screwing up on phone, too lazy to fix).
“Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
KTM 950SE, KTM450exc, WR262, XR100
SA Trip: http://profundoenel.wordpress.com
My Spot Page: http://share.findmespot.com/shared/f...VRxGZhKdq5PNll
DeepInIt is offline   Reply With Quote
Old 01-23-2013, 11:23 PM   #5
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 784
Goodrich hose same quality cheaper...
They sell a plastic coated version that keep the stainless wire in place and you don't get poked by itty bitty razor sharp barbs.
Fragola Fittings are also a good deal, same if not better quality than the Aeroquipe, and about 1/3 the cost.
Dirt track catalogs are your friend
Good luck.
Dave
pdxmotorhead is offline   Reply With Quote
Old 01-24-2013, 09:59 AM   #6
beergut
Thumper
beergut's Avatar
Oddometer: 413
I have about 7' of stainless Aeroquip line that I have had for several years, just never did anything with it. I am about to do my fuel pump, so I thought...what the hell, why not use this stuff up. (I have had it for several years just laying around)
After doing a little research, the rubber hose is sort of becoming a thing of the past. As others have pointed out, the types of fuel available are changing, as is the engineering of vehicles. Even though that Gates link is a sales flyer, I am 100% confident that what it states is true in that rubber fuel line breaks down.
I think when I do my fuel pump, I will install the Gates hose. Overkill, maybe. Needed, no. Want, yes. Piece of mind for only a few bucks (my oriley has it for $4.60/ft), yes.
FWIW, I have used quick disconnect hose fittings on rubber line. It works the same way. I will not do the fittings on the fuel pump. -I will just use a stainless clamp
My KLR
beergut is offline   Reply With Quote
Old 01-24-2013, 10:25 AM   #7
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,407
A pair of these quick-disconnect fuel taps will certainly help. I've been using them for years now, available soon to everyone...
~ Ken
PowerCell screwed with this post 01-24-2013 at 11:04 AM
Old 01-26-2013, 03:45 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
This replaces the petcock as well?
looks interesting and very handy. Instead of turning off the fuel petcock you can remove the quick connector, so the flow is cut!
gefr screwed with this post 01-26-2013 at 11:15 AM
gefr is online now   Reply With Quote
Old 01-26-2013, 09:32 AM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,665
I have something similar on my 990, but uses stock components.
Leave the taps in position and turned on, fit one of these in the centre of the balance pipe, near the battery, protected by the bashplate
http://www.ebay.co.uk/itm/Quick-rele...item2ec019388f
both connectors seal as soon as they are uncoupled, so no leaking fuel and no fiddling about with pliers trying to get the hose clips off the stock taps.
Peanuts is offline   Reply With Quote
Old 03-16-2013, 05:43 AM   #10
mookymoo
Mookish Mook
Oddometer: 4,396
Out of curiosity why not SS?
mookymoo is offline   Reply With Quote
Old 03-16-2013, 06:55 AM   #11
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 1,024
I`m guessing these are plastic.
Good Idea, but in time these can break.
rossguzzi is offline   Reply With Quote
Old 03-16-2013, 05:38 PM   #12
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,407
They act like a buzz saw and wear through everything they touch. Also they are unneeded weight. Use the Kevlar...
~ Ken
Old 03-16-2013, 06:11 PM   #13
mookymoo
Mookish Mook
Oddometer: 4,396
Aha. Cheers
Times are GMT -7.   It's 10:44 PM.
