03-03-2013, 03:23 PM
#1 |
Oddometer: 15
KTM 990 gasoline problem
This is a 2011 Dakar model--went for 30 mile ride today came home put in garage and smelled a little gas could not see any fuel any where. After about 30 minutes in house went back in garage and notice gasoline odor. Went to look at bike and heard a percolating noise. First I thought it was radiator but that looked ok. Then opened gas lid and gas looked like it was boiling which I knew it wasn't opened other tank same issue. This percolation lasted a good hour. When I first opened the thanks it felt like there was vacuum sound upon pulling lid. Bike starts ok and runs ok I'm not very mechanical and wondered if any other person has had this problem or have any ideas . Thanks in advance
03-03-2013, 04:37 PM
#2 |
Oddometer: 423
Could be these maybe? http://www.ktm950.info/how/Orange%20...ance_tube.html
http://cpmodem.smugmug.com/gallery/2575878#109089728 http://www.ktm950.info/how/Orange%20...terectomy.html
Now: '03 KTM 250sx -- '05 KTM Adventure 950 Before: '00 KTM 250sx -- '03 KTM 450sx '03 Yamaha R6 -- '08 KTM SuperDuke R |
03-03-2013, 08:09 PM
#3 |
incognito
Oddometer: 16,374
When you were riding it how high was the temp gauge?
the sun does not have no prisoners |
03-04-2013, 06:56 PM
#4 |
Oddometer: 15
2 bars from the top
03-12-2013, 06:27 PM
#5 |
Oddometer: 15
Had bike at ktm dealer for 3 days and they said they did not see anything. Put it on computer and checked mapping also looked at heat shields and venting on gas claps.Picked it up rode it home freeway 30 miles at 70 to 75 then rode it in neighbor hood for 15 minutes at variable speed 20--35 mph stopped couple times under traffic light --fan came on and it showed 2 bars from the top on engine temp. Parked it in garage fuel was boiling like tea kettle and could feel some pressure when opening gas caps. Any more ideas from anyone thanks
03-12-2013, 07:43 PM
#6 |
incognito
Oddometer: 16,374
You might want to burp your cooling system. If there is air in it the bike will run hot and possibly boil the fuel... 2 bars from the top is unusual for the type of riding you are describing.
http://www.advrider.com/forums/showthread.php?t=598938
03-12-2013, 08:09 PM
#7 |
Grizzly herder
Oddometer: 1,103
I have had fuel boil in my tanks in really hot weather, during slow riding. I have since used reflective heat sheilding on the inner sides of both tanks, as well as installing a second fan. The fuel absorbs a lot of engine heat considering it surounds the engine. The heat shielding really helps and can be found at hot rod shops, in rolls of self adheasive product.
http://www.advrider.com/forums/showthread.php?t=595530 http://www.advrider.com/forums/showthread.php?t=702314 Uhaul, it's part of the KTM experience. 09 KTM 990 Adv Lycan1 screwed with this post 03-13-2013 at 06:33 AM |
03-12-2013, 08:34 PM
#8 |
Oddometer: 56
fuel
Hey, a 990 friend of mine had this happen and he will know what it is, he is in china for work but i will shoot him a text and tell him to look into the forum. i thought he said something about the connection hose between the tanks having something to do with it. hang tight i will do my best.
03-14-2013, 06:43 AM
#9 |
Oddometer: 56
fuel
I talked to my friend in that is in China and he said that his was a dirty fuel filter. may want to check that out
03-14-2013, 08:14 PM
#10 |
Oddometer: 221
03-16-2013, 08:28 PM
#11 |
Oddometer: 15
Thanks guys bike at shop now having fuel filter checked if ok will try heat shield and 2nd fan.
03-27-2013, 03:35 PM
#12 |
Oddometer: 15
Got bike back from dealer today they replaced fuel filter because the sock on it looked like it was filthy. Mechanic said it looked like it was 10 yrs old. Rode bike 35 miles on freeway then rode it slow --stop --and go and figure 8 slowly etc . It never over heated --fuel never boiled and bike rode very smoothly at all paces so it seems it solved my problem and it seems to be same as several other guys have experienced with new bikes.
![]() thanks for all the imput
03-28-2013, 05:18 AM
#13 | |
Present
Oddometer: 490
KTM 990 Adventure White 2009 R specced KTM 640 Adventure 2005 |
