Old 03-17-2013, 06:29 PM   #11
Brewtus OP
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,014
Originally Posted by lineaway View Post
Brewtus, time to get OJ up to speed. Less than a month away before our trials. Got the Cota 200 running again! Took it apart and found nothing obvious wrong. Replaced one main (looked like it got hot). Back together and runs better than ever.
Had to make a base gasket.(Compression seems better from the homemade gasket). Went from 3 clutch springs back to the stock six. (So much for the easy clutch pull) Added a ball bearing to the detent spring. Maybe it will stay in second this year.
Next week new tires. Also have new sprockets and chain coming. Found a one tooth smaller cs sprocket. That should solve my low end problem with the small engine!!!
Yeah, less than a month. I plan on camping at SanYo next weekend setting sections. OJ may make it, it may not. It has not even been started since the beginning of last November.
Good work on the Cota. Did you decide not to compete on your Bultaco(s)?
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus is offline   Reply With Quote
Times are GMT -7.   It's 11:07 AM.
