Old 03-17-2013, 02:24 PM   #61
dpetersak OP
Oddometer: 44
The Warthog is 98% complete. I need to make a longer kickstand, wire the heated grips, add saddlebags and side covers, and I'm waiting for a new front brake line. Other than that, all I need is spring break-up so we can get to the road and she's ready for the Alaskan Highway and beyond.
Ground clearance from the skid plate is 9 inches, a bit more than what I was aiming for but well within the ballpark.
Photo & Video Sharing by SmugMug
dpetersak screwed with this post 03-17-2013 at 06:18 PM
dpetersak is offline   Reply With Quote
Old 03-17-2013, 09:25 PM   #62
WhicheverAnyWayCan
Deaf Biker
WhicheverAnyWayCan's Avatar
Oddometer: 915
It looks good!
[COLOR="red"]IBA 49083[/COLOR]
[b]-[/b] [URL="http://advrider.com/forums/showthread.php?t=842005"][B][COLOR="DarkOrange"]Converting 1998 Harley Sportster XLHugger 883 into Dual Sportster[/COLOR][/B][/URL]
WhicheverAnyWayCan is offline   Reply With Quote
Old 03-17-2013, 10:26 PM   #63
Trane Francks
Trane Francks's Avatar
Oddometer: 646
Originally Posted by WhicheverAnyWayCan View Post
It looks good!
It sure as hell does!
Trane Francks is offline   Reply With Quote
Old 03-18-2013, 06:56 AM   #64
Dirigo
Curious
Dirigo's Avatar
Oddometer: 489
Very Nice!
Dirigo is offline   Reply With Quote
Old 03-18-2013, 01:48 PM   #65
Pugsley/Hobbfather
Oddometer: 415
Like the D/S attitude.
A Sportster with clearance!
There is hope yet.
Don't let HD copy you though.
Be unique, just like everybody else!
Funny, I'm trying to streetify my KLR a bit. Still need a commuter more than a dirty adventurer...
But yours is a nice inspiration!
Pugsley/Hobbfather is offline   Reply With Quote
Old 03-19-2013, 09:20 PM   #66
dpetersak OP
Oddometer: 44
kickstand
Since I don't want to carry a 4" block with me when I ride, I needed a longer kickstand. I saw one possibility on ebay off an Aprillia dirtbike, but I decided to first try to extend the stock one. I used heavy-wall pipe that would fit over the stock kickstand and then put a slight bend in it. I cut off everything I didn't need from the stock one but left about 3 " to fit inside the extension. The only downside to the whole set-up is that it hangs slightly low and reduces my ground clearance by about half an inch.
dpetersak screwed with this post 03-20-2013 at 08:34 PM
Old 03-20-2013, 08:08 AM   #67
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
All stock HD Kick stands kind of hang down and drag easily. It will not drag with your ground clearance but it could snag on something. It will probably be OK though.
How about a pic of it in the up position so we can see the issue, maybe someone will have a simple fix.
[FONT=Arial Narrow][COLOR=orange]it is easier to ask for forgiveness than permission[/COLOR][/FONT]
kellymac530 is offline   Reply With Quote
Old 03-20-2013, 08:31 PM   #68
dpetersak OP
Oddometer: 44
Here's the kickstand in the up position. I could get it to tuck up further if I do a side bend, but I worry about the lateral stresses this would place on the sidewall of that pipe once the weight of the bike is on it. Should I decide to change it, I think I may just have to weld a bracket for some kind of dirt bike kickstand that will retract more up alongside the swingarm.
dpetersak screwed with this post 03-20-2013 at 08:41 PM
Old 03-21-2013, 08:16 AM   #69
kellymac530
motorcycle addict
Oddometer: 1,052
Yeah that is a tough one how it rolls down right there.
I agree a bend upward which would be a bend backwards when the kick stand is down might be a way around it, but could weaken the stand with all of the weight on it.
If you are using 0.120" wall DOM tubing of 3/4" diameter I think an S bend would be strong enough.
What if you just made it straight instead of the arch in it and then angled the foot pad to hit the floor flat? That might lessen the drop down when up???
Old 03-22-2013, 07:59 AM   #70
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
I ended up with a dirt bike sand with. Welded bracket. Used a xr650 stand and the bolt on bracket
[url=http://advrider.com/forums/showthread.php?t=706541] dual sportster to artic circle[/url]
[URL="http://www.advrider.com/forums/showthread.php?t=332519"]KLR tour[/URL]
[URL="http://www.advrider.com/forums/showthread.php?t=661573"][SIZE=3][B][I][COLOR="Red"]Sportster Build[/COLOR][/I][/B][/SIZE][/URL]
[URL="http://advrider.com/forums/showthread.php?t=875712"][SIZE=3][B][I][COLOR="Red"]Sportster Build II[/COLOR][/I][/B][/SIZE][/URL]
johnwesley is offline   Reply With Quote
Old 03-22-2013, 10:51 AM   #71
dpetersak OP
Oddometer: 44
Kelly, the stock kickstand already angles toward the ground when it is in the stowed position, so more length results in less clearance. I tried a length of straight tubing, but at that angle it added another 6" until it reached the ground, so it sticks way out there.
Old 03-22-2013, 10:54 AM   #72
dpetersak OP
Oddometer: 44
John, if I remember correctly, the pivot point for your stand was right about where the frame starts to curve up behind the primary case. Does the kickstand then rest alongside the swingarm? Any problems reaching it with your foot?
Old 03-22-2013, 10:56 AM   #73
dpetersak OP
Oddometer: 44
There is hope yet.
Thanks, I appreciate the feedback! Now if I could just get out of my driveway and the ice covered roads would hurry up and melt.
Old 03-23-2013, 07:36 AM   #74
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,634
http://johnwesley.smugmug.com/Motorc...HFGv5&lb=1&s=L
http://johnwesley.smugmug.com/Motorc...qxWmh&lb=1&s=M
I can reach it without issues. Tucks in nice as well
Old 10-26-2013, 04:09 PM   #75
bitpusher
Oddometer: 6
all the pics are gone. :(
here is a little sportster (based ;)) sumpin sumpin i've been working on.
bitpusher is offline   Reply With Quote
Times are GMT -7.   It's 04:51 AM.
