Old 03-20-2013, 05:53 PM   #16
jon_l
jon_l's Avatar
Oddometer: 3,036
read Neduro's tire changing thread beginning to end
http://www.advrider.com/forums/showthread.php?t=50717
'09 Honda CBF1000
jon_l is online now   Reply With Quote
Old 03-21-2013, 09:03 PM   #17
RVDan
RVDan's Avatar
Oddometer: 2,587
Originally Posted by buls4evr View Post
.......and should be thrown away anyway just because it is a deathwing. Save yourself some crashing.
I replaced my Deathwings with kenda 270's. I still crash.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 03-21-2013, 09:06 PM   #18
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 8,895
Originally Posted by MadMax View Post
The date mark on the tire reads: 2512. I'm hoping it is not 4 years old.
Still can't get about a 1/4 of it on the rim. I guess I'll have to take it to the "stealer" tomorrow. I appreciate the response.
That DOT date means it was manufactured in the 25th week of 2012 so they are not very old.
Marc
84 R100RS LE, 2012 Stelvio, 2013 V7R, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650
http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3
Lomax is online now   Reply With Quote
Old 03-22-2013, 09:21 PM   #19
STisma
STisma's Avatar
Oddometer: 145
For the difficult and stubborn front tires (19" here) this seems to work, for me that is.
It also takes plenty of lube, couple of minutes of foot stomping and an iron for the last press-on. Oh yes...plenty of lube. More lube.
And no issues with tube getting twisted, pinched, ....
If it can go wrong, it will go wrong!!!
STisma screwed with this post 06-18-2013 at 09:37 AM
STisma is offline   Reply With Quote
Old 03-23-2013, 04:09 PM   #20
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Why so much trouble changing tires? I took off two and put on two in 1 hr, 15 mins including taking them off the bike 2 days ago. This is not rocket science..... Are you taking the tube out after you break both sides and open up 1 side(the disc side)? Do you have 3 GOOD Spoons (MSR, MotionPro)? Do you have access to dishwashing soap?No need to waste 10 zip ties to do this.The only part that might slow you up at all is a rim lock.Also put just a touch of air in the tube so that it kind of takes a shape before you re-insert it back in the carcass. And a good compressor to pull up that bead.
buls4evr is offline   Reply With Quote
Times are GMT -7.   It's 02:06 PM.
