03-21-2013, 03:21 PM
#16 |
Oddometer: 457
If you want very instant and very cheap, get yourself your favorite brand silicone/gooey crap that will stick, get a tarp, and then "glue" it down. Might have to redo it every once in awhile, but it would be cheap and quick to repair.
If I were in your shoes, I would source out a welder and some steel and repair it correctly though. I tend to not "repair" stuff cheaply as I hate redoing things. |
03-21-2013, 04:06 PM
#17 |
Oddometer: 593
Some sheet tin or aluminum and some windshield adheisive should fix it.I would clean the area around the hole with a wire wheel on a drill .Slap the patch down with the windshield glue.If you wanted to you could put roofing tar on the whole patch after the glue dried.That windshield glue is mean stuff-I think it is urathene based.
03-21-2013, 04:30 PM
#18 |
WFO for 41 years
Oddometer: 3,995
RTV will last two years easily. Cut the end off the (multiple) tube, (not the nozzle, the TUBE!) and push it out with a hammer handle. Trowel to suit. Throw a scrap of metal (road sign) over it to shield UV. Done in 10 minutes.
I've seen it done inside million dollar machinery, lasts nearly forever.
Too much is just barely enough..... 2007 Tiger 1050 2005 Royal Star Tour DeLuxe 1973 Yamaha TX750 1974 Norton 850 Commando Roadster |
03-21-2013, 04:57 PM
#19 | |
Ninjetter
Oddometer: 33
You cannot stop that rust from progressing, no matter how much you cover top and bottom; it is a microscopic thing. The same rust will make any welding very difficult, and each weld joint will rust faster itself. You can combine this solution with desirable roof insulation. Roof paper+bull tar or some UV-resistant plastic film would reduce the costs. |
03-22-2013, 06:40 AM
#20 | |
A proud pragmatist.
Oddometer: 2,860
I should dig out my test piece, half done with the phosphoric, the other half with Corroseal or possibly "Conquest by Chemsearch", don't remember been a while and the piece has been under the weather all winter.Just that them Tannic/Gallic Acid based ones dry faster (20 minutes) and give a much better finish. The term is Polymer, that's what the converter turns the rust into. Phosphoric does the same but looks more like a clear varnish when the Tannic/gallic ones are nice and black. Yep....seen a lot of corrosion "at sea" in the last 30+ years. Lots of Sikaflex and Corroseal/Conquest used.
Have tools, will travel!
03-22-2013, 07:10 AM
#21 |
U'mmmm yeaah!!
Oddometer: 1,598
Remove the side off and old washer or dryer (it's galvanized) and gluing it down, with the forementioned adhesive.
I like the windshield skylight idea too....
Maggot Don't sweat the petty things; Pet the sweaty things !!! |
03-22-2013, 07:49 AM
#22 |
Old & beat up
Oddometer: 11,079
Scrape, soda blast the rust? Then apply bedliner?
Ride, Crash, Visit the ER, Get a splint, Recuperate, Assess your mistakes, Repair Motorcycle, Gather courage to ride again, Ride, Rinse & Repeat My SPOT - No tracks = not riding | Mapsource Tutorial | Rides |
03-22-2013, 08:23 AM
#23 |
Oddometer: 433
Cold roofing patch, here in the USA big box stores sell it in 5 gal containers, get the silver stuff should last at least 5 years. Apply with trowel sticks to anything
03-22-2013, 08:55 PM
#24 |
Oddometer: 215
How about some peal and stick rubberized roof flashing. I get some at the local box store that is 10" wide. if the sustrate is clean and you don't streatch it when you apply it, it sticks very well and its supper easy to use.
03-22-2013, 09:22 PM
#25 |
Bend it Bend it
Oddometer: 5,437
Yes the roofing idea with glass is great but just to remind folks, it'll have another container on top so no light and no space for the wooden structure but it will get plenty of water graining down from the container above when it rains and little sun to evaporate the standing water afterwards
Thanks for all the responses. I have already though of an old enamellled washing machine or cooker as being a good source of steel plate. I'm having to use the metal plate to reinforce the already very weak steel roof which has rusted badly over about 3'x1' and is thus weak. I'm leaning towards a very thin (watery NOT gel) acid type rust converter which will soak into all the cracks and crevices and stop further rust. Keep the ideas coming. |
03-22-2013, 09:42 PM
#26 |
Oddometer: 922
Sorry to talk about welding, but the thing is made of steel. A hot welded steel patch will be the best and cheapest and easiest cure. Anything else just seems silly.
Are you actually in Sydney? I go to metal recyclers in Melbourne and I get steel for free- fancier metals I pay per weight but even if you have to buy some steel from a scrap yard it will be the fraction of the cost of one tube of Sika. A cheap little modern inverter stick welder like numerous people you must know could lend you will deal fine with a long extension cord. Get an oversize sheet- lay it down and draw around it in a marker- wire wheel an inch or two clean all around where you have marked, lay the patch back down and weld the patch on. Including sourcing steel it would half a day max. Done. If it is about doing it as cheap and dodgy and lazy as possible... many ways I suppose. Got any old paint tins lying around? Weathershield or a similar vinyl type acrylic would work well. Block up the pin holes with anything that will stop the paint running through. On a hot day get a $2 roller and paint multiple layers of paint over the whole suspect area making sure to go up beyond the area the water will pool. Put half at least half a dozen layers of thick rubbery weathershield paint and it doesn't matter what happens underneath it, the membrane on top will hold for years, even with water pooled on top. But again, it seems silly not to weld it. |
03-22-2013, 11:56 PM
#27 | |
Rhymes w/piecejunkie
Location: The only county in Illinois with no train tracks
Oddometer: 4,766
I personally wouldn't weld it as it is non structural and the only thing you will do is burn off any corrosion protection already applied to the steel. Also, if you are putting another container on top of it you might not even bother with doing anything.
Grow a WW1 Victory Garden this year! |
03-23-2013, 01:07 AM
#28 |
Oddometer: 361
Patch and sikaflex, if you use a rust converter and patch it bigger than the weakened spot once the other container is on top it will be a decade before you even have to think about it.Sikaflex is the Chuck Norris of sealants, if you ever want to take something apart DONT use Sika.
03-23-2013, 01:27 AM
#29 |
The Bone Destroyer
Oddometer: 189
I would just clean it up, wet it out with epoxy, lay on some 12 oz cloth, wet it out again and your done, if required another coat 12 to 24 hours later, Thats what I have done on my container here on the wet coast and its worked for many years.
I try to make my container look like crap so no one thinks there is anything of value in it.
R1200 GSA XR650R dualsport/Rally Trainer “We should come home from adventures, and perils, and discoveries every day with new experience and character” |
03-24-2013, 05:48 AM
#30 | |
Bend it Bend it
Oddometer: 5,437
From my first post: "From inside I noticed a single rusty blister 2" OD with evidence of a small leak below. On the outside of this area, there is an area about 2' x 1' with severe rust. By this I mean multiple thin layers of steel rusting come off when nudged by a screwdriver. I created two small holes (1" sq) easily so then stopped. The container steel is about 0.125" thick - maybe more. I only need to keep the container for another couple of years or so welding is uneconomic. " |
