Old 03-23-2013, 05:35 PM   #1
mynameiswoody OP
mynameiswoody's Avatar
Oddometer: 20
quick disconnects
Do any of you notice air seeping into the lines after you connect/disconnect a few times? I can't help but think that this happens.
mynameiswoody is offline   Reply With Quote
Old 03-24-2013, 01:02 AM   #2
XL-erate
Oddometer: 154
If you check out JEGS or Summit they have many Residual Pressure Valves for brake systems designed to prevent backflow in lines. Of course they can only flow in one direction, from master to wheel cylinder, so that may allow some air entrainment anywhere past the point of disconnect, that's unavoidable. But they will prevent the line & master from getting air in them so it minimizes how much bleeding you might have to do.
Bleeding's an easy job if you make up a cheapo one-man bleeder of a piece of rubber fuel line to fit over the wheel cylinder bleed nipple, running down into a little relish jar or similar, with tip of bleed hose submerged under about an inch of fluid in jar. With all connected just crack the nipple and pump pedal a few times, keeping a close eye on fluid level in master. Close nipple & check pedal pressure. If all good I crack it again for one more stroke of pedal then seal it up. Neat & clean plus you can get a visual on condition of fluid coming out. Because of thickness of fuel line it can get a little tippy so a larger sort of jar is better to help keep it upright, say 16 oz.. is best.
XL-erate is offline   Reply With Quote
Old 03-24-2013, 10:42 PM   #3
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,863
I agree that it's easy to be suspicious of those QD's, but I get air into the rear brake line of my Guzzi pretty easy and it's a completely closed system. I've decided that there is at least one air gnu living under my garage floor and it comes out at irregular intervals when I'm not around to mess with my brakes.
WUMPA
Sidecardogs.com
DRONE is online now   Reply With Quote
Old 03-25-2013, 08:27 AM   #4
jaydmc
Oddometer: 1,054
Turn the female end up right. Take a screw driver and depress the check ball long enough for a drop of fluid to form. Then put the ends together. This will help keep any air front getting into the system.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Times are GMT -7.   It's 10:32 PM.
