Old 03-19-2013, 10:39 AM   #1
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,645
LED Light Upgrade program
We consistently hear from riders who have there doubts about LED Aux lights. Some just are not sure of their capabilities, Some have seen the LED lights that are extremely bright to look at yet put out very little forward lighting,
Many have been bitten by the allure of what appears to be inexpensive or less expensive LED lights. Only to have failures when they needed the products the most. This is very prevalent in Chinese made LED lights. There is a lot more that goes into an LED than throwing a Cree emitter in a case. Thermal degradation, thin wires and weak mounts are just a few issues. I have never seen a quality LED light made in china.
If you have a failure,and you will, all the sudden that inexpensive light cost you much more. In the long run, wouldn't it be better to buy quality in the first place?
There are good reliable LED lights from Cyclops and other companies.
You do not need to spend an arm and a leg for quality products. Look at the total cost of wire harnesses, ease of install and most of all reliability. It doesn't take much to see that value is more than the bottom line.
We are offering a $75 credit for your broken, failed or just inadequate LED lights toward the purchase of a set of the lifetime warrantied Long Range LED's with dimming harness.
seen in this thread . Quality and value meet here.
http://advrider.com/forums/showthread.php?t=839163
This is a limited time offer and not good with any other discount
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder screwed with this post 03-27-2013 at 11:07 AM
Off Road Ryder is offline   Reply With Quote
Old 03-24-2013, 08:04 AM   #2
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,543
Awesome promotion!
Yellow Pig is online now   Reply With Quote
Old 03-25-2013, 03:44 AM   #3
GordonFreeman
Gamer
GordonFreeman's Avatar
Oddometer: 1,591
Nice deal. I have two model 30s from advmonster that have stopped working. $75 each will go a long way towards buying your. How do I do this?
GordonFreeman is offline   Reply With Quote
Old 03-25-2013, 08:09 AM   #4
Off Road Ryder OP
Oddometer: 2,645
Thanks GF.
You would PM me and then send the lights in.
$ 75 is the total allowance.
1-800-624-0278
Old 03-25-2013, 08:19 AM   #5
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,430
I've also got a broken adv monster light, would that work?
twinrider is offline   Reply With Quote
Old 03-25-2013, 09:07 AM   #6
Off Road Ryder OP
Oddometer: 2,645
We have seen a pattern here. I wonder why that is. Yes we will accept any bike mounted lights.
1-800-624-0278
Old 03-25-2013, 09:08 AM   #7
Off Road Ryder OP
Oddometer: 2,645
Originally Posted by Yellow Pig View Post
Awesome promotion!
Thank You,
I dont know how long we can do it for.
1-800-624-0278
Old 03-25-2013, 10:27 AM   #8
bastimentos
Oddometer: 105
Haha easy there fella.
Great promotion idea, hope it goes well.
bastimentos is offline   Reply With Quote
Old 03-26-2013, 12:48 PM   #9
ewagman
Oddometer: 30
I'd be interested in upgrading my Super Sherpa's LED single lamp to one of your 10 degree singles or maybe a dual, if that would work with your $75 LED trade in upgrade credit. It's only got a 15 amp alternator, and I have some Gerbing heated gear plugged in at times.
ewagman screwed with this post 03-26-2013 at 01:02 PM
ewagman is offline   Reply With Quote
Old 03-26-2013, 03:56 PM   #10
Off Road Ryder OP
Oddometer: 2,645
Thanks for the consideration.
The offer is good for a set of lights with the dimmer, I cant do it on single lights and stay in business.
A set of the long range or NXG prime lights will pull less wattage than the single light you have, so that should not be an issue.
What might be an issue with the Long Range for you is the mounting, The Long Range lights are quite a bit larger than the light you currently have (3x3)
I could see a set mounted to each side and maybe slightly lower than your current setup.
Otherwise I know of a good light bracket for the KLR
1-800-624-0278
Old 04-05-2013, 05:13 PM   #11
Japanviking
Oddometer: 94
PM sent,
Need some new lights for the 1200 gs LC
BMW S1000RR -12
BMW R1200GS -13
Japanviking is offline   Reply With Quote
Old 04-07-2013, 07:45 AM   #12
gsstampeder
gsstampeder's Avatar
Oddometer: 1,076
Pm sent
5 weeks in Baja
gsstampeder is offline   Reply With Quote
Old 04-08-2013, 09:14 PM   #13
GordonFreeman
Gamer
Oddometer: 1,591
PM sent.
Old 04-10-2013, 08:31 AM   #14
Off Road Ryder OP
Oddometer: 2,645
Thank You
Thanks everyone.
We have quite a pile of trade in lights stacking up here
Please note that the offer includes the dimming harness and is not available with the standard harness.
We do have a ADV discount code for those that do not want the dimmer.
Code is ADV
1 800 624 0278
1-800-624-0278
Old 04-22-2013, 07:31 AM   #15
kimokk
kimokk's Avatar
Oddometer: 103
Any discount for turning in HID set up?
'09 BMW R1200GSA Adventure! (gone)
IBA #49426
kimokk is offline   Reply With Quote
Times are GMT -7.   It's 04:55 PM.
