Old 03-24-2013, 02:26 AM   #1
brotherdan OP
Oddometer: 3
620 LC4 adventure 1997 Fuel Line
Can anyone describe how those fuel tap (3 unit) are connected. Further how its controlled. Im using 28 liters fuel tank.
1st Left Petcock 2nd Right Petcock
(ON/OFF/RES) (Thumb ON/OFF) only
TANK 28 litres
Feul Pump
3rd just Below rider Petcock
(ON/OFF/RES)
CABURATORS (DellOrtho)
cheers..
brotherdan is offline   Reply With Quote
Old 03-24-2013, 05:43 AM   #2
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 962
TANK 28 litres
Feul Pump
(ON/OFF/RES)
cheers..
Missplaced thread, should be on THUMPERS.
Yet, the RH fuel petcock connects to the LH by a hose passing in front of the engine.
The 2nd exit on the LH petcock connects to the fuel pump.
690R
Old 03-25-2013, 09:43 PM   #3
brotherdan OP
Oddometer: 3
how about the 3rd petcock ON/Off/RES at RH just below the rider??....this is the highest reserve fuel contained in the 28 liter tank.
Old 03-25-2013, 11:21 PM   #4
Droptarotter
Oddometer: 1,301
OK.......let's make a few things clear first.........on all vehicles, left and right are as you sit on/in the vehicle.
So, for a 640 Adventure......the upper L/H and R/H thumb screw lines are joined with the fuel line running behind the engine.
The L/H On/Off/Reserve goes to the fuel pump.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 03-27-2013, 11:07 PM   #5
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 842
Cheers
Correct, but not for all years...
1998-2001 there was only two petcocks, L/H on-off-res and R/H on-off.
Line from R/H on-off connect to t-connector between pump and L/H on-off-res.
Seikkailu_R is offline   Reply With Quote
Old 03-27-2013, 11:14 PM   #6
Seikkailu_R
Oddometer: 842
Transfer/balancing line from possible rear tanks?
Times are GMT -7.   It's 03:43 AM.
