Old 04-11-2012, 04:13 AM   #31
JohnG.
JohnG.'s Avatar
Oddometer: 1,946
Originally Posted by klm4755 View Post
Now that's one worn sprocket
Keithm
My previous one did 54k klm pushing for 70k this time with a little TLC
JohnG.
JohnG. is offline   Reply With Quote
Old 03-29-2013, 12:46 AM   #32
wcprominence
Oddometer: 12
2 thumbs up
I'm just getting ready to do this job. This is a great and perfectly detailed write up. I haven't changed the chain on my KLR yet, so let's hope it goes well :-) thanks again.
wcprominence is offline   Reply With Quote
Old 11-26-2013, 05:02 PM   #33
kallehof
kalle
kallehof's Avatar
Oddometer: 106
Worn Sprocket
Thanks klm4755. Nice details.
These look more like suggestions than teeth
I think I could have turned this sprocket around and ran it for another 1000 miles.
Kalle Hoffman
San Francisco, CA
kallehof is offline   Reply With Quote
Old 05-14-2014, 01:14 PM   #34
Pablodakar
Oddometer: 117
Hi. I recover this old thread because I just discover that DID RIVETTING TOOL is not more compatible with new chains
I was using a Did 520V in my DR350, rivetted without problem and perfect... just received a 520VX2 (X ring instead o ring), tried to riveting and... BAD. I discovered DID tool doesnt fit this new chain.
First, new chain is a bit closer.
When you insert chain to rivet, and push the plate, in other side is two hole with a groove, and that groove was perfect for 520v, but its large for 520VX, then you push to other side the pin a bit= x-ring crushed.
Im trying to adapt Did rivetter tool to new chain (covering the holes), next days I will try to rivet again with new ordered parts...
I was thinking that DID tool was a good investiment for future, but if every years I must replace tool.... maybe would be better a standard chain tool.
Regards
Suzuki DR350SEX
Suzuki KingQuad 450
Pablodakar is offline   Reply With Quote
Times are GMT -7.   It's 01:29 PM.
