Old 03-31-2013, 02:57 PM   #1
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,754
Exhaust pipe expander ?'s
I am working on another custom exhaust and I have the following measurements.
The header terminates in a male tube 1.66-1.69" OD depending on where you measure it. I found 1.75" SS exhaust tubing 16g would be 1.75-(0.065*2) or 1.62" ID
1.75" 18g (0.049" wall) would be 1.652" theoretically.
http://www.mandrel-bends.com/catalog...-tube-390.html
I know I am going to need to massage this tubing slightly to make that joint a nice slip fit.
I've read some reviews of exhaust pipe expanders on Amazon etc and did not get a good feeling but I am only trying to get a little bit of diameter out of this tubing.
http://www.amazon.com/Lisle-32500-Ex.../dp/B0002STSNU
Suggestions including buying new tools or having a shop do it?
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-31-2013, 04:11 PM   #2
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
I've built a couple exhaust collectors for LC8's and needed to get some SS pipe expanded. I went to a local guy that does custom exhausts and headers to have the pieces expanded. As soon as he saw the SS he said it will split. Sure enough,,,,every piece he tried to expand split. Some split as soon as he put pressure on them and others split after about 1/16"
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-31-2013, 04:57 PM   #3
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,754
I have to think it's possible in some way. The guys mandrel bending this stuff are deforming the metal much more than I would be getting fifty thousandths or so. But I guess I would be getting close to the 1/16" you were.
I have some larger diameter SS from this same supplier and I might try out a piece with a local muffler place before buying a bunch of new stuff.
Everything from this joint back to the can will be welded so I really only need it fit this one section. Hell even if it split I could pretend it was supposed to be that way in order to split it for clamping. I could also slit the tube and form it over a blank I make on the lathe and TIG weld it but I think that's a lot of effort for something that should be easier.
What wall thickness was the material you had when it split?
Nessmuk
Old 03-31-2013, 11:42 PM   #4
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,591
This is my pipe expander - you need to heat the pipe for it to expand. Exhaust shops have hydraulic expanders that work pretty well....but not pretty.
motu is offline   Reply With Quote
Old 04-01-2013, 05:20 AM   #5
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
18ga SS. Maybe with the little bit you need to expand it will be fine. The shop I use has been doing this work for as long as I can remember,,, he can bend anything. He's even bent a couple brass and copper boat exhausts for me over the years.
We did try heating one and it split just as easy. Not sure what you mean by not pretty,,, the hydraulic expanders are the same principle as the manual.
Old 04-01-2013, 06:23 AM   #6
crawdad
Oddometer: 507
Don't know if you could go the other way with a bigger tube but Concours has some 2" stainless .060 wall for sale In the FM and the price seems pretty reasonable to me.
crawdad is offline   Reply With Quote
Old 04-01-2013, 09:40 AM   #7
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 773
both ways
Hi,
Pete ,your local exhaust guy can shrink tubing also on a good exhaust machine.
Regards,Ed
also HF has a small 1.125 to 2" ? expander
pennswoodsed screwed with this post 04-01-2013 at 09:45 AM Reason: harbor fright
pennswoodsed is offline   Reply With Quote
Old 04-01-2013, 09:40 AM   #8
redprimo
Oddometer: 515
Did you anneal the tubing or heat it up and try expanding it while red hot. I'm just curious because I have my first exhaust project comming up and I will be using stainless tubing.
Id love to see some pics from the Op as the project progresses, will you also be fabing up a muffler?
redprimo is offline   Reply With Quote
Old 04-01-2013, 10:53 AM   #9
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
This was one of the multiple failures....
Not saying it can't be done but we tried without any luck. We did try anealing and were met with the same exact result. As soon as the expander exerted pressure the tube split.
In the end I used plain steel header tubing. The rest of the system was plain steel so I really didn't worry about it.
Old 04-01-2013, 01:01 PM   #10
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,075
Is this seamed or seamless tubing? Just curious...
Laconic is offline   Reply With Quote
Old 04-01-2013, 01:17 PM   #11
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,459
Seamed,,,,, you can see the weld line about 1/2" below the split. It never split on the seam.
Old 04-01-2013, 01:21 PM   #12
Laconic
Anodyne
Laconic's Avatar
Oddometer: 18,075
OK, I see it now, looked like a shadow.
Old 04-01-2013, 06:13 PM   #13
RVDan
RVDan's Avatar
Oddometer: 2,689
I use one of those manual pipe expanders to make squished pipes round again, I've never had any luck expanding one enough for a slip fit, it ends up not quite round.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 04-01-2013, 06:18 PM   #14
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,754
I'll be posting pics in my build thread in the some assembly required forum.
I built a header from scratch last time for a CBR600, wow that was an exercise in humility. I did it out of carbon steel as I also have a tubing bender for some of the shallow bends and the guy I bought the tight radius bends from said it would work better than stainless.
For this project, I am using the stock Ninja header, and coming from the much discussed swage back under the motor and up the side of the subframe like all the other exhausts you see. I'll be doing it out of stainless and then using a carbon fiber Scorpion can I bought off ebay yesterday for $50. I like the carbon cans because they are really light and don't get hot like stainless.
The only crap part about building it out of stainless is back purging the tube with argon the whole time you are welding it. But it's a fairly simple task once you have done a couple. This will be my third exhaust and hopefully I don't make any mistakes.
Even if the tube cracked like the pics above, I'd be fine with it as I would just weld it back up
Nessmuk
Old 04-02-2013, 07:58 AM   #15
ragtoplvr
Oddometer: 6,526
You can take one of the cheap expanders and cinch it up tight.
Then you take a small hammer and peen evenly over the outside of the pipe.
If it works for you like it did for me the expander will be loose.
Tighten to round pipe, then remove, check fit and repeat as needed..
ragtoplvr is offline   Reply With Quote
Times are GMT -7.   It's 01:44 AM.
