Old 04-01-2013, 03:03 AM   #7801
paulW
Oddometer: 143
Originally Posted by RichBMW View Post
Ooh, I like the look of that
Makes me think of an Apache attack helicopter - very apt for the GS, in yer face, go anywhere bike
. . . not that I would do anything other than VERY light offroad on my own
paulW is offline   Reply With Quote
Old 04-01-2013, 03:20 AM   #7802
GSMarc
GSMarc's Avatar
Oddometer: 1,007
Weight mesured : 247.2 kg ready to go. (545 lbs)
Back to the R1150GS weight
http://www.moto-station.com/moto-sta...ive.php?id=737
Perhaps, some weight could be saved in welding quality (see HP2 models)
GSMarc from BELGIUM
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 04-01-2013, 03:34 AM   #7803
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,115
More videos...
(maybe posted before?)
(you don't get to see much actually )
(ok this guy has a weird sense of what a video is)
NLS
My Blog
When the going gets tough, the tough get going...
NLS is online now   Reply With Quote
Old 04-01-2013, 03:46 AM   #7804
IB1
IB1's Avatar
Oddometer: 1,002
Originally Posted by NLS View Post
More videos...
What do you expect from the dutch?
IB1 is offline   Reply With Quote
Old 04-01-2013, 03:48 AM   #7805
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,059
Originally Posted by twinrider View Post
A friend has a similar guard on his GSA's headlight. He's complained that it blocks a considerable amount of light, enough to cast that same pattern on the road at night.
I have the TT guard on my Tiger 800. Although it does project a shadow on to the ground, I dont think it blocks enough light to be a problem. Admittedly, the Tiger does use twin headlights though.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 04-01-2013, 04:16 AM   #7806
tau
Oddometer: 15
Though it looks like being welded, it is not!
That "sub frame" represents the panniers fastenings which can easily be replaced / added.
That's depending on the package ordered - with or without them. I had the same felling - meaning that's welded - but Saturday I've spent (only) three hours around it in my dealer's showroom and I've been told the above mentioned.
tau is offline   Reply With Quote
Old 04-01-2013, 04:32 AM   #7807
Japanviking
Oddometer: 92
But it doesn't change the fact that the welds look like they have been done by a 6year old
I guess the Touratech engine guards are a good match judging from the pics on their website....
BMW S1000RR -12
BMW R1200GS -13
Japanviking screwed with this post 04-01-2013 at 04:40 AM
Japanviking is offline   Reply With Quote
Old 04-01-2013, 04:36 AM   #7808
tau
Oddometer: 15
Comparing with the previous model(s), the non ESA present one has non adjustable front shock absorber.
Is there any (special) reason for that? What do you guys, think about it?
Is the new installed Sachs shock absorber more efficient / better then previous Showa / WP?
I can see that still nobody has answered my questions; therefore I'm asking you another one: would you buy it / order it without ESA?
Please explain your reply. Just to be frank with you guys, I'm willing to order it without ESA, as:
- I consider the manual adjustment being more suitable / accurate.
- lower replacement cost
My main problem / concern the case I order it without ESA, is the front suspension which ... can not be adjusted ...!
Old 04-01-2013, 04:39 AM   #7809
tau
Oddometer: 15
Based on my previous - and good - experience with Wunderlich engine guard, I would go on them.
Old 04-01-2013, 04:41 AM   #7810
MaxReving
MaxReving's Avatar
Oddometer: 254
That's depending on the package ordered - with or without them. I had the same felling - meaning that's welded - but Saturday I've spent (only) three hours around it in my dealer's showroom and I've been told the above mentioned. That is not what he is referring to. He is referring to the quality of the weldings.
Hurra for handmade stuff
Ohh my God those weldings don't look nice. They might hold the subframe together but they sure look like someone had a very bad day at the welding factory. Maybe BMW Motorrad has subcontracted the welding but they still have to have some kind of quality control of all the subframes no matter if they made them themselves or if it was made by subcontractors. This for sure does not look like German engineering.
Max :-)
MaxReving is offline   Reply With Quote
Old 04-01-2013, 05:10 AM   #7811
IB1
IB1's Avatar
Oddometer: 1,002
Found the first made in Taiwan sticker ... On some of the wiring leading to the headlight.
Old 04-01-2013, 05:31 AM   #7812
Nick 187
Oddometer: 204
Low Suspension?
Currently I'm riding a 2010 R12 GS with a low factory low suspension. The older bikes with low suspension were not available with ESA. As I understand it there is a factory low suspension option however does anyone know if the riding modes and ESA is available on the 2013 low suspension model?
Nick
Nick 187 is offline   Reply With Quote
Old 04-01-2013, 05:36 AM   #7813
MaxReving
MaxReving's Avatar
Oddometer: 254
Touratech vs. Holan weldings
Touratech
Touratech
Touratech
And then this one from Holan. Maybe they are not better at welding at Holan but they sure are better at doing an extra effort to make the final result look a lot better than the stuff from Touratech.
Well, you be the judge!
Touratech = German Engineering at its best! Not so much.
Touratech may just have won an award for being best brand from the German magazine "Motorrad" but maybe the big chief Herbert should spend less time posing with awards and more time kicking some ass in the welding department at Touratech.
Max :-)
Old 04-01-2013, 05:37 AM   #7814
NLS
NLS's Avatar
Oddometer: 3,115
Took you long enough.
At least is from Taiwan specifically (which is still considered quality manufacturing) not China in general.
NLS
My Blog
Old 04-01-2013, 05:38 AM   #7815
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,295
I like the Cee Bailey headlight guards. They won't win as many admiring looks outside Starbucks but they give good protection without blocking any light and they pop off in a second for cleaning.
twinrider is offline   Reply With Quote
Times are GMT -7.   It's 10:11 AM.
