Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 03-31-2013, 11:43 AM   #46
225 OP
225's Avatar
Oddometer: 149
Thanks!!
Tube of silicone says it may take up to 7 days to dry. Which is no biggie because I am going on a motorcycle trip for a week next week anyway.
Better pics of almost finished trailer:
Profile and holes cut. I still need to cut the notch for the hatch, which I will do later today.
2013 KTM 500 EXC SuperMoto | 2001 Honda CBR929RR | 1988 Yamaha YSR 50
225 is offline   Reply With Quote
Old 03-31-2013, 08:27 PM   #47
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,829
Hmmmmmm.....just the one door??
We had one on both sides of ours and would never consider anything but 2 doors! (it eliminates the need for the person on the window side to hafta climb over the other person to use the 'facilities' at 3am! )
Originally Posted by 225 View Post
but we too LOVE the Benroy style! (best use of available space!)
"Good Times & Good Friends Make Life Better"
www.artworks-unlimited.com
Patrick46 is offline   Reply With Quote
Old 04-01-2013, 06:55 AM   #48
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,356
Tongue jack
Enjoying your build, some neat ideas.
I like your idea on the tongue and have a possible improvement for you. I did something similar on a log splitter but made the jack part of the fixed (trailer side) rather than the tongue side. It allows me to remove the entire tongue for theft and I'm less apt to gouge my knees when working around it. In your case it would also deter theft and allow you to adjust the tongue without the burden of the tongue weight. It appears you have put a lot of planning into your build so I suspect you may have considered this already.
Best picture I could find, the tongue slides into a receiver like yours near the yellow wires.
HowlingMad is offline   Reply With Quote
Old 04-01-2013, 08:45 AM   #49
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Cool build! One thing I plan to do some day as well.
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is online now   Reply With Quote
Old 04-01-2013, 09:49 AM   #50
dan-c
Back
dan-c's Avatar
Oddometer: 13,695
Cool build.
Of course I have $0.02 to offer also
Instead of that gargantuan cooling unit, you can get a De Longhi portable heat pump - A/C for around $500.
AC/Heat Pump
dan-c is offline   Reply With Quote
Old 04-01-2013, 11:59 AM   #51
225 OP
225's Avatar
Oddometer: 149
I have a pop up camper for the misses and the youngun'. This camper is just for me and my motorcycle trips to the mountains, and wherever else. I wanted something small and light that can run off my small Honda generator. And that I can use anywhere, like on side of the road in the middle of nowhere.
Yes, I am putting a stabilizer jack on the front. I just haven't yet. I have to patch up the 4 holes in the square tubing and build some rails in between the taillights and fenders. When I do that, I'll weld the jack on.
Originally Posted by dan-c View Post
Cool build.
AC/Heat Pump
Wish I could. Wouldn't be enough room on the inside for that.
The silicone dried up faster than I thought it would. So today, I cut the notch for the hatch on the walls. Then laid down epoxy, then bed liner on the bottom.
I also I put the bed liner on the bottom of the floor. So I am going to let everything cure for the night. And in the morning, I'll place everything on the trailer, and start on the cabinets.
Old 04-01-2013, 12:22 PM   #52
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,829
are you planning on pulling this with your motorcycle, or throwing the bike in a truck bed and draggin' this behind that??
not a dumb question, as I HAVE seen bikes towing teardrops.
Old 04-02-2013, 07:13 AM   #53
225 OP
225's Avatar
Oddometer: 149
Really not a dumb question. I am pulling it with my van.
Old 04-04-2013, 05:20 PM   #54
KeithinSC
KeithinSC's Avatar
Oddometer: 1,547
Bikes and teardrops are a myth....
KeithinSC is offline   Reply With Quote
Old 04-04-2013, 05:25 PM   #55
225 OP
225's Avatar
Oddometer: 149
Sorry for the lack of updates over the last couple of days. But the camper shell is done. Wiring is done. And I am working on the cabinets, and hatch tomorrow. Should have the A/C in too. I am waiting on tan bed liner and more epoxy to come it before she will be done. Other than that, the galley is all I have left.
I'll be 99% done other than waiting on bed liner to come in to coat the outside, and she'll be finished.
Carpet on the wall on the window side. Painting the ceiling.
Door side:
More tomorrow!!
Old 04-05-2013, 08:32 AM   #56
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,829
Old 05-17-2013, 06:28 AM   #57
225 OP
225's Avatar
Oddometer: 149
Sorry for the lack of updates. But The cabinets are painted and installed. First coat of bed liner is on. All that's left is install the speaker box which will go under the hatch, and the inverter. And the counter top.
I also have to epoxy, and bed liner the hatch, and that's that.
Cabinets:
First coat of bed liner:
Bed liner up close:
The bottom part that's black will be cut in correctly tomorrow.
Almost there..
Old 05-21-2013, 03:47 PM   #58
225 OP
225's Avatar
Oddometer: 149
Stuff needs done:
Remount fenders.
Carpet ceiling.
Build interior cabinets.
A little touch up painting.
And very little trim work left on the galley:
Old 05-23-2013, 10:16 PM   #59
Patrick46
visionary
Patrick46's Avatar
Oddometer: 2,829
I don't remember if you posted your location or not, but for folks on the California/Oregon border areas...
I was riding home a week ago from Sacramento, and coming through the Lake Shasta area. I saw well over 50 teardrops, running solo or in groups, heading South down I-5 on their way home from the "Dam Gathering".( http://www.teardrops.net/damgathering.html )
I later heard from a friend that attended, that there were 170 teardrops at the event this year!!! (very likely that this was the largest teardrop event in history!!)
what a great place to get ideas and inspiration for a teadrop build.
Summer's just about here....get that baby finished!!!
Old 05-24-2013, 02:08 PM   #60
TooFast
TooFast's Avatar
Oddometer: 1,255
Are you going to weigh this teardrop when you're all done?
TooFast is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 03:21 AM.
