Old 04-01-2013, 06:35 PM   #16
ontic
Oddometer: 1,070
Originally Posted by GapRunr View Post
As for the tach, it's a new digital tach designed for two cylinder dual fire ignitions. I would suspect it is pretty accurate.
Link and details? I'm still shopping for a tach for my G/S.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 04-01-2013, 07:44 PM   #17
GapRunr
GapRunr's Avatar
Oddometer: 504
Here's a pic installed in a temporary location.
Since I own a shop posting details and price is frowned upon. Check your PM's.
GapRunr
07 R1200GSA - 81 R80g/s - 95 KLR 250 - 06 TW200 SuperDuper Tenere - Gas Gas TXT280 Edition
88 Hawk GT-> for sale!
GapRunr screwed with this post 04-04-2013 at 08:14 AM
GapRunr is offline   Reply With Quote
Old 04-02-2013, 04:36 AM   #18
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
Originally Posted by Bluethumb View Post
What can I do to lower r.p.m.'s of a ST? At hiway speeds of 70 m.p.h., the engine is spinning about 1,000 more r.p.m.'s then my R100. I know of two ways to change the ratio of the final drive on a G/S - ST. One is with the higher 5th gear and the other is the optional final drive. The higher 5th gear is expensive from what I've read, the cost of the gear plus the time and expense of a rebuild. I thinK I've read it drops r.p.m.'s by 400-500. The optional final drive is NLA I believe, but if it is still available I'm guessing it's unbelievably expensive and I'm not sure how much it drops r.p.m.'s.
Is there another option? Is it possible to use a different FD and re-lace the rear hub to a ST rim?
Any other way to replace the final drive with another to drop engine speeds?
There is a solution that hasn't been mentioned yet: the adaptation of a 88-95 RxxGS rear wheel to a monolever 4-lug FD. That gives you three FD ratios from factory:37:11 (R80RT Mono), 32:10 (R100RT Mono) or 33:11 (R100RS Mono) . Details are here: http://www.stephenbottcher.net/BMW/rearconv.htm
Hope that helps, Stephen
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
StephenB is offline   Reply With Quote
Old 04-03-2013, 11:04 AM   #19
bajaburro
Ancient Adventurer
bajaburro's Avatar
Oddometer: 1,556
tall 5th
it's the best option for your bike.just lowers the rpm in 5th enough to make freeway riding a bit nicer.
ancient adventurer
bajaburro is offline   Reply With Quote
Times are GMT -7.   It's 02:05 AM.
