Old 04-03-2013, 01:23 AM   #7966
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Originally Posted by cug View Post
What I found more interesting is that the braking distance from 100km/h (62mph) was longer on the new model. Only in Enduro mode it got kind of close. New one is said to be more stable while braking, but needs longer distance.
and despite the larger contact patch of the bigger tires....looks like 9% longer stopping distance on asphalt with sand surface and 2.3% worse on asphalt.
EJ_92606 screwed with this post 04-03-2013 at 01:29 AM
EJ_92606 is offline   Reply With Quote
Old 04-03-2013, 01:45 AM   #7967
NLS
My bike needs washing...
NLS's Avatar
Oddometer: 3,145
Originally Posted by wildy View Post
Nobody on a forum ever changes their minds and loses an argument.
A wise statement.
Originally Posted by RedLeg View Post
throttle is touchy in dynamic mode.
As it should be. I am sure they'll fine-tune it with future software updates though.
BTW love the avatar...
Originally Posted by Japanviking View Post
I am also very interested in getting other springs. If the new ESA system is rebuild able and can be sprung for my weight it would be really good it think.
Wouldn't this mess with what the software expects?
NLS
My Blog
When the going gets tough, the tough get going...
NLS is offline   Reply With Quote
Old 04-03-2013, 03:08 AM   #7968
fennel
fennel's Avatar
Oddometer: 25
Originally Posted by EJ_92606 View Post
Good point...are we talking about the plastic GPS bracket being moved up or what appears to be a black metal bar that supports the GPS bracket being moved up? I assumed he was talking about the metal bar but now that you mention it, it's not clear.
The metal bar has two bolts at the inner sides of the beak.
Sent from my GT-P7500 using Tapatalk HD
fennel is offline   Reply With Quote
Old 04-03-2013, 03:32 AM   #7969
NLS
NLS's Avatar
Oddometer: 3,145
Originally Posted by Moronic View Post
Motorrad has posted online an article comparing the waterboxer with the 2012 GS, reporting on a side-by-side ride and various performance and static measurements.
Very interesting, thank you.
(btw below you will realize that I don't work for BMW - as some people seem to hate I defend the new model all the time)
Things I find interesting:
- Worse braking performance. Not in a critical level (as you said, where the '12 stops, the '13 makes a low speed bump), but this is a definite NEGATIVE to me. Hope they can improve with software, as (shown by enduro mode) the physical part is definitely able to perform at least same as previous version.
- Reports seem to agree that HP is spot-on and plus (whereas most vendors inc. BMW cheat). Good for people that care in such numbers.
- Speedometer seems to cheat a bit more. Not good. The difference @100Km is the difference I get at top speed.
- Real v-max not impressive. They could do much better. I will say again: 6th should be longer or consumer bike vendors should start thinking about 7th gear (overdrive with slow "pick up" for bikes like GS, "real" for bikes like S1000RR).
- Strange that dynamic mode (hope they indeed tested dynamic mode) can just chop 0.1sec over the last version. I would expect closer to 0.2-0.3.
- Seeing side-by-side photos, new bike indeed shows more fresh.
- The test verifies what everybody seems to fail to understand. New version is about same price. Extras are more. You want them I know, you don't HAVE to get them though.
So to sum up. Motorrad seems to find new GS as a "revolution" over previous.
Mechanically this is definitely true.
In practice I would say "evolution" is as far as you can go.
Given the differences and similarities, we definitely have a GS here. The new bike looks cool (way more cool than last), will perform better in real-life (rolling accelleration, ability to turn and follow terrain) both on and off tarmac.
We definitely already see what can be further improved for first face-lift in 2-3 years.
NLS
My Blog
Old 04-03-2013, 04:04 AM   #7970
mkletecka
Oddometer: 286
How does the new WC corner/handle compared to AC
My only question is this. Does the new WC handle any better through the canyons than the previous AC (I'm talking about fully leaned over, scraping parts/no chicken stripes compared to the previous AC). If none have done this with their new WC's, no need to reply to my question.
BTW, I think the new WC looks great, has a lot of new goodies etc. and for those who got one, congratulations!!!!!!!!!!!!
mkletecka is offline   Reply With Quote
Old 04-03-2013, 04:51 AM   #7971
Japanviking
Oddometer: 92
Yes it handles better when ridden aggressively. Turns in quicker and I thought it felt very stable leaned over.
BMW S1000RR -12
BMW R1200GS -13
Japanviking is offline   Reply With Quote
Old 04-03-2013, 05:01 AM   #7972
NLS
NLS's Avatar
Oddometer: 3,145
Yes but have you tested and compared the two models THROUGH THE CANYONS? Because else you shouldn't reply.
NLS
My Blog
Old 04-03-2013, 05:24 AM   #7973
MaxReving
MaxReving's Avatar
Oddometer: 257
Yes
MaxReving is offline   Reply With Quote
Old 04-03-2013, 06:02 AM   #7974
oz97tj
oz97tj's Avatar
Oddometer: 819
Im glad im not the only one who laughed at the arrogance in that statement.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 04-03-2013, 06:03 AM   #7975
MaxReving
MaxReving's Avatar
Oddometer: 257
- Worse braking performance. Not in a critical level (as you said, where the '12 stops, the '13 makes a low speed bump), but this is a definite NEGATIVE to me. Hope they can improve with software, as (shown by enduro mode) the physical part is definitely able to perform at least same as previous version. Bikes were on different tires Metzeler Tourance Next and Metzeler Tourance EXP
- Speedometer seems to cheat a bit more. Not good. The difference @100Km is the difference I get at top speed. Calibration is often different from bike to bike
- Strange that dynamic mode (hope they indeed tested dynamic mode) can just chop 0.1sec over the last version. I would expect closer to 0.2-0.3. Well, 0.3 sec would almost be 8-9% faster and that may be a bit optimistic when you compare the torque figures
Ahhh, this type of side-by-side test is always a bit tricky. I have a few questions for the people at the magazine "Motorrad":
Regarding performance. Did both bikes run on the same fuel? The new 1200GS LC can handle octane 95 but the camhead have been known to be better of with octane 98. They also write that in the review. Both bikes have to be tested with octane 98.
Breaks. The new 1200GS LC was fitted with the new Metzeler Tourance Next and the camhead with the Metzeler Tourance EXP. Tons of tests shows that different tires have different breaking distances. How would the figures look if both bikes were on the same tire (but different size of cause) ?
How are the breaking tests done and how have you measured the acceleration figures? Number of times the breaking and acceleration test was done. Are the figures the best out of a number of tests or is it average figures? Was it the same rider on both bikes? Details are missing.
Engine performance illustrated by the torque and power curves have been made on a dyno, so those figures should be comparable. However, I will like to know what the milage were on both bikes when they were tested.
However, if you add up all the figures in this test then you will see that the new 1200GS LC is 3.2674% better than the camhead, including the seat which alone is 5.3863% better
Max :-)
Old 04-03-2013, 06:21 AM   #7976
MaxReving
MaxReving's Avatar
Oddometer: 257
MCN vid
Max :-)
Old 04-03-2013, 06:26 AM   #7977
NLS
NLS's Avatar
Oddometer: 3,145
Originally Posted by MaxReving View Post
Good points all.
Especially about tires, they COULD (and should) use Next on both bikes.
(Next is already available in "old" GS sizes - I've seen it in tire shops)
Only objection about the fuel.
'13 GS manual specifically mentions 95 octane fuel. There is no mention of being better with 98.
In contrast, '12 GS requires 98 octane and 95 octane limits its capabilities. This is because of the different engine characteristics in latest oilhead model (DOHC etc.).
(also to mention, OLDER 12GS models - like mine, again specified 95 octane fuel except that of course they could handle lower and higher octanes because of the knock sensor)
So they should compare (as they should I think) both with the "factory suggested" fuel.
NLS
My Blog
Old 04-03-2013, 07:14 AM   #7978
avalher
Life is Good.
avalher's Avatar
Oddometer: 101
Arrogant, to say the least!
Live everyday like there's no tomorrow...
avalher is offline   Reply With Quote
Old 04-03-2013, 07:17 AM   #7979
avalher
Life is Good.
avalher's Avatar
Oddometer: 101
Laugh
Max :-)
You, sir ARE WRONG!! The seat is actually 5.3864% better!
Old 04-03-2013, 08:08 AM   #7980
Montauk
Oddometer: 280
I am impressed on 5 digit accuracy.
Montauk is offline   Reply With Quote
Times are GMT -7.   It's 10:09 AM.
