Old 04-06-2013, 04:12 PM   #3286
dsc522758
dsc522758's Avatar
Oddometer: 20
Originally Posted by Ricky Chuck View Post
Morning, it can take a while to get through a thread like this :).
The Xpels are a round (lens-fitting) material that apply directly to the front of the lens. I would say they can be removed if they get damaged or you want a different color. Right now I have yellows on my LEDS, but you can get blue and clear. Mine have some noticeable road-wear and I should be getting some new ones myself, so as to how difficult it is to get them off, someone else can comment, and I would appreciate a good tip on how to start the process myself, lol. Tweezers? :). See link below. I know they USED to have yellow, I hope they still carry it.
http://stores.intuitwebsites.com/hst...Categories.bok
So the Xpels are like a plexiglass slip-on to the glass lens on the light?
dsc522758 is offline   Reply With Quote
Old 04-06-2013, 06:16 PM   #3287
Ricky Chuck
Red Green Rulz!
Ricky Chuck's Avatar
Oddometer: 461
Yes, made of urethane I believe.
Ricky Chuck is offline   Reply With Quote
Old 04-07-2013, 12:27 AM   #3288
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
Originally Posted by sanjoh View Post
Please contact me via email sandjoh@gmail.com.
email sent no answer
Sean-0 is online now   Reply With Quote
Old 04-07-2013, 04:22 AM   #3289
dsc522758
dsc522758's Avatar
Oddometer: 20
OK....I did a youtube search on Xpel and I see it is a film type of product. Sort of like a window tint type of film. I thought it was more like a clear lens cap like you would install over the light housing.
Any answers to the question on the rotary LED switch and how it mounts to the bike?
Old 04-07-2013, 04:45 AM   #3290
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 805
Originally Posted by dsc522758 View Post
2009 Kawasaki KLR650
Where or how exactly does the Rotary LED Dimmer mount? To the bars? On a panel?
Have a look at this page starting at post # 2833.
http://www.advrider.com/forums/showt...y#post19939318
'97 Honda ST1100
Sunday Rider is online now   Reply With Quote
Old 04-07-2013, 12:12 PM   #3291
dsc522758
dsc522758's Avatar
Oddometer: 20
OK...ummmm....looking for something that will give me a bit cleaner install like the Clearwaters use. Something a bit more clean mountable instead of Velcro or 2-sided tape. Love the lights! Already have a pair of Twin Headlight Ernie brackets for the Gen 2 KLR650. Just trying to figure out the rest so I can get this rolling! I'll have to sleep on that ADVmonster rotary switch. Thinking I may be able to panel mount that thing but will I be able to turn it with gloves? I can't wait to order the ADVmonster lights!
2009 Kawasaki KLR 650
dsc522758 screwed with this post 04-07-2013 at 12:25 PM
Old 04-07-2013, 02:19 PM   #3292
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 827
It's a very big knob about one inch across. You can adjust it with one single finger. Gloved or not.
That's what SHE said.
COHVCO #7369
Dusty_Bottoms is offline   Reply With Quote
Old 04-08-2013, 02:45 AM   #3293
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,345
And once you've set a lower setting to be traffic friendly, you don't need to change it. High beams give you full power.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 04-08-2013, 06:40 AM   #3294
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,263
I have read most of this entire thread over the past week. I do all city and or slab riding and would like somethng like the 44's for daytime visibility. I just don't think I would ever need all the light 60's give! I understand running these at 100% at night on city streets would not be very considerate of oncoming vehicles so you recommend one of your LED Dimmers with High Beam Bypass which sounds promising. I don't think I need another key FOB in my collection so I was looking at the Rotary one. I have also checked out the Skene product also. A few questions for you and sorry if they have been answered somewhere else in this great thread.
I understand the Model 44 Flood Light is a glass lens. Does the Xpel Light Protection slip-on to the flood light housing to protect the glass from breakage? Is the Xpel a replacement lens?
The rotary dimmer is surface mount. You can mount it anywhere you have the space. I like mine mounted behind either the brake or clutch (if equipped) master. Like this
The xpel lens protection is a product developed by 3m to protect aircraft windshields. It is not a replacement lens, it is attached with adhesive and becomes permanent about 20 minutes after application. Here is what it is made of.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 04-08-2013, 06:42 AM   #3295
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,263
A guys gotta ride
Email coming with PP invoice.
Old 04-09-2013, 09:24 AM   #3296
garrett
garrett's Avatar
Oddometer: 467
Sanjoh
the plastic knob on the dimmer broke off. Is there anything I can splice in to replace the switch? It still works but the adjuster is flush to the housing and I can only turn it by sticking a key in there.
Garrett
I like bikes...
garrett is offline   Reply With Quote
Old 04-09-2013, 12:30 PM   #3297
dvgonzo
dvgonzo's Avatar
Oddometer: 329
Sean-O.
How did you break the lens? Flying rock, or crash?
I always worry about trashing out my lights cause I tend to ride pretty close sometimes to the buddy in front of me to avoid dust. Plays hell on equipment though.
I found these GREAT covers for the lights I built and they also fit these Monster lights as well to protect them from rock hits and probably crashes to a lesser extent....will have to post a picture.
They are silicon and can be had in clear (which really let the light through pretty well too), or red. When installed they are kind of tight fitting so hold some air pressure as well and that really acts as a nice air cushion to keep them in one piece.
sanjoh, you might want to buy some of these and offer as an option too!
dvgonzo screwed with this post 04-09-2013 at 01:26 PM
dvgonzo is offline   Reply With Quote
Old 04-09-2013, 01:47 PM   #3298
dvgonzo
dvgonzo's Avatar
Oddometer: 329
The clear ones are available from Caplugs and mostly used as masks for when plating or painting things. Real nice stretchy and tough 100% silicone so it stands up to heat real well too. I think they said up to 500 degrees?
Unfortunately to get them from Caplugs you have to buy a huge quantity.
The red ones are available through McMaster Carr and you still have to buy 10 but for only 1.60 apiece they are a great deal.
Here is the part number: 92805K47
I cut the red covers down about an inch as my two outside lights are not as long as the monster ones. Monster cover one is full length as delivered.
Old 04-10-2013, 01:16 AM   #3299
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
A guys gotta ride
well done
dvgonzo.......i crash sometimes ...i like to push the pace a lil bit till my skills runout
there's a few vids floating round this place of my exploits on my xrr
Old 04-10-2013, 06:04 AM   #3300
dvgonzo
dvgonzo's Avatar
Oddometer: 329
That is funny, maybe it is some sort of virus or disease?
I seem to be afflicted with the same thing and it comes on all of a sudden!
Times are GMT -7.   It's 03:31 AM.
