Old 02-23-2013, 11:41 PM   #46
drtdino OP
drtdino's Avatar
Oddometer: 24
I used 3/8 16 all thread, which is the same thread on the nuts that come with the trailer. And I used 1/2 tubing cut to fit as the spacer. I welded them to the frame slipped on the fender and now each fender is bolted down with four bolts, all spread out.
drtdino screwed with this post 02-23-2013 at 11:52 PM
drtdino is offline   Reply With Quote
Old 02-23-2013, 11:46 PM   #47
drtdino OP
drtdino's Avatar
Oddometer: 24
I also got some 3/8 16 x 1" carriage bolts and installed them from the bottom up, on the original two holes that holds the fender on. The reason I did that was because with my new tires being slightly taller, under load the threads that stick down may have contacted the tire and sliced into it. That would be bad...
I trimmed the extra thread sticking up after the pictures were taken.
Old 02-25-2013, 12:15 AM   #48
drtdino OP
drtdino's Avatar
Oddometer: 24
Fabricated and installed the removable plates for the wheel chock today. I bought some 5/16x16 stainless cap screws and washers then welded in carbon nuts on the underside.
There are different positions from front to rear that can be changed within a matter of a minute. This will allow adjustable tongue weight for different bikes.
Old 02-25-2013, 12:27 AM   #49
Jack90210
mindful
Jack90210's Avatar
Oddometer: 15,271
Originally Posted by drtdino View Post
Those wires really need to have some kind of wear liner over the top of them. A rubber grommet for the holes wouldn't hurt, either.
Oh, and I like to check the hubs and tire treads by feel every time I stop. No need for a tool to do this job, you learn pretty quickly what they are supposed to feel like.
I must say that my son has exposed a reservoir of love and of worry within me that I never knew existed. --nskitts, 9/2/12
Jack90210 is offline   Reply With Quote
Old 02-25-2013, 10:33 AM   #50
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,236
I really like that idea!
+1 on the wire covers and grommets. I would at least use a double layer of shrink tube on the wires. You can get grommets from any hardware or auto parts store.
Jim
Old 03-01-2013, 08:44 PM   #51
drtdino OP
drtdino's Avatar
Oddometer: 24
Well I am calling this finished... I am eventually going to install a spare tire holder but for now it will go in the bed of the truck or trunk of the car.
drtdino screwed with this post 03-02-2013 at 01:47 PM
Old 03-02-2013, 05:49 AM   #52
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,010
As the former owner of one of these trailers I can tell you I always hated the way the tail lights stuck out on either side. They are very vulnerable to damage. Since you have a welder you might want to make up some kind of enclosure for them while you are at it.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 04-07-2013, 11:51 AM   #53
drtdino OP
drtdino's Avatar
Oddometer: 24
Got to use the trailer yesterday to pick up my "new to me" xr400.
I also went about 400 miles a few weeks ago,to help my father in-law go pick up his brand new grizzly 450.
Old 04-07-2013, 03:03 PM   #54
bwalsh
bwalsh's Avatar
Oddometer: 11,484
Your trailer is looking good! I've been contemplating buying one of these 4x8 trailers to customize.
Not to hijack your trailer build thread but I stumbled upon this HF trailer build the other day.
The guy did a fantastic job!
2004 XR650L
NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 04-18-2013, 12:05 PM   #55
Gillus
High Desert Rat
Oddometer: 759
And the reason there are no four wheeler tracks on those snow plow berms or the fresh snow is??
Beware those with no sense of humor as they will cause you misery.
Disclaimer: I am only responsible for what I said, not what you understood or how you interpreted my words!!
'11 GSA supertanker/mothership, '11 Suzuki Burgman 400, '06 KTM 640A
Gillus is offline   Reply With Quote
Old 04-18-2013, 12:09 PM   #56
JimVonBaden
"Cool" Aid!
Oddometer: 52,236
You might have a tough time pulling that behind your 650!
Jim
Old 04-18-2013, 12:10 PM   #57
JimVonBaden
"Cool" Aid!
Oddometer: 52,236
Probably the "Private Property" sign behind it!
Jim
Old 04-19-2013, 08:28 PM   #58
bwalsh
bwalsh's Avatar
Oddometer: 11,484
Jim
You got that right although I was thinking more along the lines of using my truck.
2004 XR650L
Old 04-21-2013, 07:55 AM   #59
lookaught
Loner Extraordinaire
Oddometer: 197
Nice job.
I owned a similar trailer in the past. My only suggestions are to replace the garbage castors that bolt to the trailer with better quality ones and weld them on... it makes all the difference because the shitty ones that come standard fall apart when the balls fall out. I always considered welding the rest of the frame but never got around to it and just sold it and bought an enclosed trailer instead.
Also, being chinese steel... these rust. Make sure you stay on top of the rust with some wire and spray paint.
Do the wires get pinched when you fold it flat? I remember my trailer rubbed together there along the two halves.
Aprilia SXV 550 supermoto
F800GS 30th - sold and replaced by... a 2010 F800GS!
CRF450R
Solo Ride Pennsylvania to Anchorage, Alaska and back 2011
Two Ape supermotos take on the Dragon
lookaught is offline   Reply With Quote
Old 04-21-2013, 04:10 PM   #60
JimVonBaden
"Cool" Aid!
Oddometer: 52,236
Originally Posted by lookaught View Post
Nice job.
Chinese steel isn't the problem, it is the cheap powder coating. All steel will rust if exposed.
Jim
Times are GMT -7.   It's 04:07 PM.
