Old 03-19-2013, 02:02 PM   #3406
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,120
That may not be easy to come by where he is.
About a year ago or so I was going to send 1 lb of tig wire to a guy in NZ.
The wire didn't cost me anything as it came from my former employer however the postage was well north of $50.00. I didn't send it.
E-309L is the preferred dis-similiar fill wire but E-308L will work.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is offline   Reply With Quote
Old 03-19-2013, 02:07 PM   #3407
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 945
I would think with all the boat building on the North island, stainless filler should be abundant.
But then again I could be wrong. It seems to happen daily.
"If what you are doing isn't working, don't try harder, try different."
"Today I'm younger than I'm ever going to be, and I intend to act like it"
EvoLife is offline   Reply With Quote
Old 03-19-2013, 04:01 PM   #3408
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,500
Thanks Guys!
I work in the pulp & paper industry & they stick stainless onto carbon steel quite a bit so there's a good chance the rods for it will be available here, if not, or if they only come in big packs I'll see if I can bum a couple of lengths from one of the local workshops.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 03-19-2013, 06:37 PM   #3409
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,128
Originally Posted by David R View Post
Perhaps you could just buy a few pounds of 6013, 6011 or 7014. All are AC rod and for all position.
Baking the 7018 will dry it out but its still a DC rod.
If you have dirty metal, clean it.
David
Thanks.
I read somewhere that 7018 could be an AC or DC rod, but mine just says "7018", so it's probably made for DC like you say. I'll get a little starter kit of some of the 6 series rods.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 03-20-2013, 03:33 AM   #3410
David R
I been called a Nut Job..
David R's Avatar
Oddometer: 2,538
7018 will run on AC, but its aggravating. It sticks to the plate when starting especially with a buzz box. Not the best way to learn to stick weld. Good idea to use something easier until you get the hang of it. Then try the 7018.
Have fun and show us pictures of your welds.
David
2012 R1200R ! 2000 R1100RT (parts for sale!), 1976 R75/6, 2014 Vulcan 900 Trike
There is a seat for everyone.
David R is offline   Reply With Quote
Old 03-20-2013, 05:51 AM   #3411
xcflyn
xcflyn's Avatar
Oddometer: 1,157
Originally Posted by EvoLife View Post
ER309L is the general go-to for carbon to stainless IIRC
+1
xcflyn is offline   Reply With Quote
Old 03-22-2013, 09:36 AM   #3412
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,977
Originally Posted by slackmeyer View Post
Thanks.
I've got a couple boxes of 7018AC you can have. They're just collecting dust since I have a mig at home now.
Old 03-22-2013, 05:20 PM   #3413
slackmeyer
slackmeyer's Avatar
Oddometer: 3,128
That would be most excellent for my screwing around with metal. I wish PG+E would get around to giving me 240v. . . .
Zak
ktm
old bmw
others
Old 03-23-2013, 11:56 AM   #3414
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,977
I'll put them in the trunk, stop by the dump Mon-Fri, 1300-2130 hours.
Old 03-24-2013, 02:37 PM   #3415
clintnz
clintnz's Avatar
Oddometer: 3,500
So I called in at a local engineering business that does a big variety of stuff & asked for a few lengths of 309L, the bloke said 'Nah mate, what you need is some MG600' So for a couple bucks I walked out with some of that. It seemed to lay in nicely considering my n00b skill level.
The butt welds on the rest of the tube with normal ss rods were nowhere near as pretty. I think I need to set up a purge on the inside to improve those.
Cheers
Clint
Old 03-24-2013, 02:56 PM   #3416
kirkster70
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Cheers
Clint
I think you are doing a fine job! Keep up the good work, Clint!
kirkster70 is offline   Reply With Quote
Old 03-25-2013, 06:41 AM   #3417
xcflyn
xcflyn's Avatar
Oddometer: 1,157
I agree with Kirk ! looks pretty darn good.
Old 03-31-2013, 02:48 PM   #3418
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,097
Newb question here:
A friend was moving, and gave me an older Lincoln buzzbox (A-225S, I think the model is), and a big (open) box of 7018 electrode, probably open in a humid climate for the last 15-20 years. I think it works, though I'm still waiting for the local utility to give me a new service drop so I have 220v at my house.
Anyway, I've never stick welded before, though I've done a bit of some other types (mig and tig, and a fair amount of gas welding). This seems like a decent enough welder to play around on and make some functional stuff. If it doesn't work for me, I'll try to trade it for a mid size wire feed welder. My hope is that I can dry the welding rod just before I use it with a light bulb/ cardboard or wood box arrangement.
Any comments, either about the rod, the welder, or whether an old simple stick machine is a good all-purpose tool these days?
Hi Zak, some 7018AC rod has a little bit of potassium in it to help the arc when using an AC buzz box. It would be easier for you to maintain your arc with it.
The old rod probably has alot of mositure in the coating so if you see porosity in your welds it is from the hydrogen mixing into your liquid metal from the H2O.
You wont pass an x ray test but it would be ok to practice with.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 04-07-2013, 08:11 PM   #3419
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,641
My water cooler rig is seized up on my tig welder. It's been sitting for lots of years unused. I've only used the thing to stick weld a couple times.
I'm not planning on doing any heavy work, so I don't think I need the water cooler. Apparently there is still water in the line because I could strike an arc.
I'm I in danger of screwing something up without the cooler/pump going?
Do I need to swap the torch and lines out with a dry one?
Also, FYI argon co2 mix does not work for Tig. Couldn't figure out why I was burning up tungsten
Jayrod1318 is offline   Reply With Quote
Old 04-07-2013, 08:29 PM   #3420
ER70S-2
ER70S-2's Avatar
Oddometer: 6,742
You should be able to strike an arc; current doesn't care whether there's water or not.
Yes, the leads are depending on water to keep from melting the liner. bbzzzzzttttt
Also, FYI argon co2 mix does not work for Tig. Couldn't figure out why I was burning up tungsten.
Wasn't so funny at the time was it.
fwiw: My answers are for the TIG torch, not arc welding.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Times are GMT -7.   It's 11:32 AM.
