Old 04-16-2013, 08:51 PM   #8266
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Originally Posted by Assfault View Post
Are any of these ASV clutch lever's accommodating the clutch switch on the 690?
I take it you bike is the 2012+ model?
Mine does. I can start in gear with the lever pulled and find no lack in power...
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 04-16-2013, 11:16 PM   #8267
fluff34567
fluff34567's Avatar
Oddometer: 1,104
Originally Posted by Seth S View Post
I have had a lot of times to twiddle my thumbs and ponder life over the last couple of months. I have been enjoying the grindingly complex process of simply buying a house. Not sure its ever going to happen.
That said, The 690 is currently waiting patiently in its mobile garage next to the berg (back of my sprinter)...waiting for the new headgasket, suspension work, and likely a fairing kit. Thinking that the bike is going to go on to do some touring duty for a while though it may get tapped again in the future for another event.
things to do:
rebuild or swap suspension
Install RR fairing kit, LED headlights.
Change out head gasket and pray nothing is cracked..worse case something is damaged and a big bore kit is called for
euro plate holder.
Would like to go ride the new trans canada route. we will see.
Your exhaust seems to running a bit hot. I guess its an FMF and a few seem to have this problem.
sent using my fingers and voodoo magic.
fluff34567 is offline   Reply With Quote
Old 04-16-2013, 11:23 PM   #8268
ktmmitch
Oddometer: 694
Originally Posted by Kirk the Jerk View Post
What do you mean by "pip?" This?
yes,thats it
ktmmitch is online now   Reply With Quote
Old 04-16-2013, 11:38 PM   #8269
Fabless
Oddometer: 34
Not recommended: foot brake lever upgrade
I would strongly discourage upgrading the foot brake lever. The aftermarket billet brake lever merely transmits force back to the next weakest link in the chain, i.e. the brake lever bolt, which is not particularly strong and will likely snap right off the first time you fall on anything rocky.
A safety wire is a better solution; considerably cheaper as well.
-Fabless
Originally Posted by Yellow Pig View Post
If anything upgrade the foot brake lever, it's made of butter.
Here is mine after barely clipping a loose rock:
Fabless is offline   Reply With Quote
Old 04-17-2013, 01:28 AM   #8270
Hoots
Hoots's Avatar
Oddometer: 1,588
Originally Posted by fabless View Post
i would strongly discourage upgrading the foot brake lever. The aftermarket billet brake lever merely transmits force back to the next weakest link in the chain, i.e. The brake lever bolt, which is not particularly strong and will likely snap right off the first time you fall on anything rocky.
-fabless
+1
Hoots is offline   Reply With Quote
Old 04-17-2013, 02:40 AM   #8271
sprouty115
sprouty115's Avatar
Oddometer: 1,641
I was thinking the same thing - either it's super lean and needs a re-map or the packing needs to be replaced.
sprouty115 is offline   Reply With Quote
Old 04-17-2013, 02:46 AM   #8272
Hoots
Hoots's Avatar
Oddometer: 1,588
Which steering dampers do people find work best with the 690?
Is the Scott/Ohlin version from RR as good as any other?
Old 04-17-2013, 04:46 AM   #8273
poondangle
Slow
poondangle's Avatar
Oddometer: 1,591
Can you post a pic up here? I'm interested to see how it's different...
Here's what I sent
Here is the email response from ASV:
Date: April 16, 2013, 3:58:11 PM EDT
To:
Subject: RE: 2013 ktm 690 levers
Don't make a clutch lever for that yet and that has the Brembo MX brake
lever on it. Very happy you sent me these, thank you.
$50 F1 lever - BLF13, $70 F3 lever - BHF32, $100 C6 lever - BDC603
These are your options for the brake lever.
Thank you,
Jason Gilbert - Sales jason@asvinventions.com
877-278-7000 x 108
714-330-2446 (cell)
714-861-1408 (fax)
ASV Inventions
17811 Georgetown Lane
Huntington Beach, CA 92647
www.asvinventions.com
www.universalmotocross.com
poondangle screwed with this post 04-17-2013 at 05:27 AM
poondangle is offline   Reply With Quote
Old 04-17-2013, 06:25 AM   #8274
Sobiloff
Sobiloff's Avatar
Oddometer: 11
Originally Posted by slidefighter View Post
Lee...
Nice garage, too!
Blake Sobiloff
2008 KTM 690 Enduro
Sobiloff is offline   Reply With Quote
Old 04-17-2013, 06:41 AM   #8275
Aaron from Texas
Oddometer: 489
Originally Posted by poondangle View Post
Here's what I sent
Oh, wow, that is quite different. Thanks...
1987 Honda XL600R
Old 04-17-2013, 06:57 AM   #8276
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Better IMHO.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 04-17-2013, 07:21 AM   #8277
scholz
bush league
scholz's Avatar
Oddometer: 55
Not a big deal to you guys probably but kind of a milestone for me. Finally got tired of waiting for some upgrade parts to come in, so I buttoned her back up and did my first throttle check and 15 minute idle reset. Made a little smoke, bit of an odor on the brand new Wings exhaust, worked up the temps to two bars from the top, but otherwise idled nicely throughout. Too late at night in the suburbs to take her out tonight, but tomorrow after work is a whole 'nother thing! Again, many thanks to all who take the time to share their expertise.
Lee...
What turn signals do you have? I just installed the wings and melted my stock one. Thanks!
scholz is offline   Reply With Quote
Old 04-17-2013, 07:49 AM   #8278
slidefighter
Gather it up, keep on...
slidefighter's Avatar
Oddometer: 412
Scholz: Try this site: http://www.motorcycle-superstore.com/14/71/984/42267/ITEM/BikeMaster-Universal-Mini-Stalk-Turn-Signal.aspx
They are inexpensive, two wire signals and bolt right up. Literally, if you Google "small turn signals motorcycles" you will see a host of options for small turn signals. I just liked the looks of these.
Lee...
Slidefighter
"Never adopt an ideology that masks a lack of courage"
slidefighter is offline   Reply With Quote
Old 04-17-2013, 08:17 AM   #8279
wsmc831
wsmc831's Avatar
Oddometer: 799
If you plan on doing offroad, you'll probably want turn signals that don't break.
http://www.extremedualsport.com/Prod...8/Default.aspx
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is online now   Reply With Quote
Old 04-17-2013, 09:20 AM   #8280
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,045
-Fabless
Like this?
The stock one broke just looking at it! I have snagged/hit/pivoted the bike on the cleanspeed pedal hundreds if not thousands of times now with no ill effects since I installed it (3 years ago) and I wholeheartedly recommend it (or the RallyRaid version) to anyone who rides more than street.
The Letter J is offline   Reply With Quote
Times are GMT -7.   It's 10:26 AM.
