Go Back   ADVrider > Riding > Face plant
Old 04-18-2013, 04:47 PM   #31
Madrox OP
Like a bat out of hell
Oddometer: 171
Originally Posted by viverrid View Post
I'm surprised that the hole caused that much damage, and that you had a line just right to miss the front tire but hit the rear. I too think it looks like you were to left of center, but I'm not going to argue with you about it.
Entirely possible I did go left of center, my intended line was not though.
Madrox is offline   Reply With Quote
Old 04-18-2013, 04:50 PM   #32
NJ-Brett
Brett
Oddometer: 6,515
You would think a sharp edged hole would make a smaller dent in the rim, not a huge bend in it like that.
NJ-Brett is offline   Reply With Quote
Old 04-18-2013, 05:35 PM   #33
DavidBanner
Oddometer: 1,163
this is mysterious.
that's a lotsa damage to an alloy wheel from such an itty-bitty road imperfection that frankly looks pretty rideable.
my eye is drawn to the chicken-strip dinner special you've got going on there.
DavidBanner is offline   Reply With Quote
Old 04-18-2013, 05:37 PM   #34
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,702
you crossing "the yellow line of death or vegtabledom" on a corner was your biggest mistake.
Glad your ok.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 04-18-2013, 08:26 PM   #35
QSrider
QSrider's Avatar
Oddometer: 48
BMW motorcycle rims are soft and BMW car rims are soft too... Really soft. DAMHIK
_____________________
2001 BMW F650GS Dakar
2003 BMW R1150RT
QSrider is offline   Reply With Quote
Old 04-19-2013, 12:12 AM   #36
PeterW
Oddometer: 2,697
My take on this one is that the OP got it about right, hit that hole at exactly the wrong speed and in exactly the wrong place, the rear rim buckled and the tire deflated and that spat him into the weeds.
That said, my normal weekend ride would collect things like that several times, though generally at slightly lower speeds and with me more upright - and my bike is probably a bit more durable. I think in this case "bad luck" about covers it - I'd still bitch at whoever deals with road maintenance though :)
You walked away, it's not all bad.
Pete
PeterW is offline   Reply With Quote
Old 04-19-2013, 05:37 AM   #37
Madrox OP
Oddometer: 171
Chicken strip dinner special? Not quite sure what that means but it sounds funny as hell. Anyway, the crash really reinforced some things I had caught myself getting lax with which is a good thing. Definitely going to look at it as a learning experience. Wheel's still a massive WTF though.
Old 04-19-2013, 12:45 PM   #38
t-bills
mcs are dangerous
t-bills's Avatar
Oddometer: 291
Clearly this is a case where you should have layed 'er down and climbed up on 'er.
A buddy of mine hit a paver on the interstate with his Hyosung. His wheel looked very similar to that. I can't say I'm too surprised it wadded up the rim. Sorry to hear of your off. Best of luck getting it all sorted out.
t-bills is offline   Reply With Quote
Old 04-19-2013, 03:18 PM   #39
DOGSROOT
OUTSIDE
DOGSROOT's Avatar
Oddometer: 808
Brutal.
The fallout from this little incident is gonna cost Magda the election.
Oh well.
Glad you're OK, Madrox!
In what sense can economics still claim to be a science if its predictive capacity is so dismally low?
Timothy Garton Ash
This drug won't cure you...but it will put your symptoms to shame
DOGSROOT is offline   Reply With Quote
Old 04-19-2013, 05:11 PM   #40
delta21
Oddometer: 473
+1.
Cold weather+metal grate+rubber tire= not much traction.
Glad you are ok!
Originally Posted by BeMeUp View Post
A possible senario; wheel impacts hole then grate while leaned over breaking the bead and instantly deflating tire. Back end goes airborn still leaned over. When wheel next makes contact with pavement/ grate tire is deflated and rim sustains the noted damage. Two seprate impacts micro seconds apart.
delta21 is offline   Reply With Quote
Old 04-19-2013, 05:44 PM   #41
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,261
Also
I gotta say, you picked the best spot to slide out. There are trees everywhere else in that pic except where you ended up.
Sometimes, being lucky is the best thing that can happen.
SilkMoneyLove is offline   Reply With Quote
Old 04-21-2013, 04:12 AM   #42
joef
joef's Avatar
Oddometer: 539
Looks like the drain took you out and your rear wheel discovered a rock
joef is offline   Reply With Quote
Times are GMT -7.   It's 03:47 AM.
